[mapserver-commits] r8427 - trunk/docs/mapscript/php
Mon Jan 12 12:59:39 EST 2009
Author: aboudreault
Date: 2009-01-12 12:59:38 -0500 (Mon, 12 Jan 2009)
New Revision: 8427
   trunk/docs/mapscript/php/index.txt
Added updateFromString() method in php/mapscript
Modified: trunk/docs/mapscript/php/index.txt
--- trunk/docs/mapscript/php/index.txt	2009-01-12 16:57:27 UTC (rev 8426)
+++ trunk/docs/mapscript/php/index.txt	2009-01-12 17:59:38 UTC (rev 8427)
@@ -707,6 +707,9 @@
 Methods
+int updateFromString(string snippet)
+    Update a layer from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
 int set(string property_name, new_value)
     Set object property to a new value. Returns -1 on error.
@@ -1007,6 +1010,9 @@
 Methods
+    Update a class from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
@@ -1201,6 +1207,9 @@
 Methods
+    Update a label from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
@@ -1274,6 +1283,9 @@
 Methods
+    Update a web object from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
@@ -1305,6 +1317,10 @@
 Methods
+    Update a referenceMap object from a string snippet.
+    Returns MS_SUCCESS/MS_FAILURE.
@@ -1835,6 +1851,9 @@
 Methods
+    Update a scalebar from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
@@ -1876,6 +1895,9 @@
 Methods
+    Update a legend from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
@@ -1903,6 +1925,9 @@
 Methods
+    Update a queryMap object from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
@@ -1956,6 +1981,9 @@
 Methods
+    Update a style from a string snippet. Returns MS_SUCCESS/MS_FAILURE.
