[mapserver-commits] r8432 - trunk/docs/input/vector
Tue Jan 13 17:55:50 EST 2009
Author: jmckenna
Date: 2009-01-13 17:55:49 -0500 (Tue, 13 Jan 2009)
New Revision: 8432
Added:
   trunk/docs/input/vector/gpx.txt
   trunk/docs/input/vector/index.txt
add gpx format
Added: trunk/docs/input/vector/gpx.txt
--- trunk/docs/input/vector/gpx.txt	                        (rev 0)
+++ trunk/docs/input/vector/gpx.txt	2009-01-13 22:55:49 UTC (rev 8432)
@@ -0,0 +1,129 @@
+.. _gpx:
+ GPS Exchange Format (GPX)
+GPX (the GPS Exchange Format) is a light-weight XML data format containing
+GPS data (waypoints, routes, and tracks).  For more information see the
+official `GPX site`_.
+.. _`GPX site`: http://www.topografix.com/gpx.asp
+File listing
+All waypoints, routes, and tracks are stored in a single .gpx file.
+Data Access / Connection Method
+* GPX access is available through OGR. See the OGR `driver page`_
+  for specific driver information.
+* A relative path to the .gpx file can be used in the mapfile LAYER's
+  CONNECTION string.
+* The feature type is specified in the DATA parameter
+    * the "tracks" feature type will usually be the track line
+    * the "track_points" feature type will usually be the points that make up
+      the track line
+.. _`driver page`: http://www.gdal.org/ogr/drv_gpx.html
+OGRINFO Examples
+First you should make sure that your GDAL/OGR build contains the
+"GPX" driver, by using the '--formats' command:
+  >ogrinfo --formats
+     Loaded OGR Format Drivers:
+     -> "CSV" (read/write)
+     -> "GML" (read/write)
+     -> "GPX" (read/write)
+     -> "KML" (read/write)
+If you don't have the driver, you might want to try the `FWTools`_ or `MS4W`_
+packages, which include the driver.
+.. _`FWTools`: http://fwtools.maptools.org/
+.. _`MS4W`: http://www.maptools.org/ms4w/
+Once you have the GPX driver you are ready to try an ogrinfo command on your
+file to get a list of feature types:
+  >ogrinfo test.gpx
+     INFO: Open of `test.gpx'
+           using driver `GPX' successful.
+     1: waypoints (Point)
+     2: routes (Line String)
+     3: tracks (Multi Line String)
+     4: route_points (Point)
+     5: track_points (Point)
+Now use ogrinfo to get information on one of the feature types:
+  >ogrinfo test.gpx track_points -summary
+     Layer name: track_points
+     Geometry: Point
+     Feature Count: 661
+     Extent: (-66.694270, 47.985570) - (-66.675222, 47.990791)
+     Layer SRS WKT:
+     GEOGCS["WGS 84",
+         DATUM["WGS_1984",
+             SPHEROID["WGS 84",6378137,298.257223563,
+                 AUTHORITY["EPSG","7030"]],
+             AUTHORITY["EPSG","6326"]],
+         PRIMEM["Greenwich",0,
+             AUTHORITY["EPSG","8901"]],
+         UNIT["degree",0.01745329251994328,
+             AUTHORITY["EPSG","9122"]],
+         AUTHORITY["EPSG","4326"]]
+     track_fid: Integer (0.0)
+     track_seg_id: Integer (0.0)
+     track_seg_point_id: Integer (0.0)
+     ele: Real (0.0)
+     time: DateTime (0.0)
+     magvar: Real (0.0)
+     geoidheight: Real (0.0)
+     name: String (0.0)
+     cmt: String (0.0)
+     desc: String (0.0)
+     src: String (0.0)
+Mapfile Example
+Since you have confirmed that OGR can read your GPX file, now you can
+create a MapServer layer:
+     LAYER
+       NAME gpx
+       TYPE POINT
+       STATUS ON
+       CONNECTIONTYPE OGR
+       CONNECTION test.gpx
+       DATA "track_points"
+       CLASS
+         NAME "gpx"
+         STYLE
+           SYMBOL 'circle'
+           COLOR 0 119 255
+           SIZE 2
+         END
+       END
+     END # layer
\ No newline at end of file
Modified: trunk/docs/input/vector/index.txt
--- trunk/docs/input/vector/index.txt	2009-01-13 21:28:19 UTC (rev 8431)
+++ trunk/docs/input/vector/index.txt	2009-01-13 22:55:49 UTC (rev 8432)
@@ -72,5 +72,5 @@
    ntf
    sdts
    tiger
+   gpx
