[mapserver-commits] r8452 - trunk/docs/ogc
Fri Jan 23 15:08:00 EST 2009
Author: assefa
Date: 2009-01-23 15:08:00 -0500 (Fri, 23 Jan 2009)
New Revision: 8452
   trunk/docs/ogc/sld.txt
Update urls to refect server upgrade
Modified: trunk/docs/ogc/sld.txt
--- trunk/docs/ogc/sld.txt	2009-01-23 18:42:36 UTC (rev 8451)
+++ trunk/docs/ogc/sld.txt	2009-01-23 20:08:00 UTC (rev 8452)
@@ -69,7 +69,7 @@
 Test the `remote SLD request`_.
-.. _`remote SLD request`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple.xml
+.. _`remote SLD request`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple.xml
 The SLD in the above request follows:
@@ -213,22 +213,22 @@
 - line with one filter: `sld 6a`_ / `full request 6a`_
 .. _`sld 6a`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_one_filter.xml
-.. _`full request 6a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_one_filter.xml
+.. _`full request 6a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_one_filter.xml
 - line with multiple filters: `sld 6b`_ / `full request 6b`_
 .. _`sld 6b`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_multi_filter.xml
-.. _`full request 6b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_multi_filter.xml
+.. _`full request 6b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_multi_filter.xml
 - line with one filter and an else filter: `sld 6c`_ / `full request 6c`_
 .. _`sld 6c`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_one_filter_and_else.xml
-.. _`full request 6c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_one_filter_and_else.xml
+.. _`full request 6c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_one_filter_and_else.xml
 - spatial filter using BBOX: `sld 6d`_/ `full request 6d`_
 .. _`sld 6d`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple_spatial3.xml
-.. _`full request 6d`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple_spatial3.xml
+.. _`full request 6d`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple_spatial3.xml
   - The above example enables spatial filtering using the BBOX parameter as a
     Filter for a selected area (Africa). Note that an ElseFilter will not work
@@ -255,17 +255,17 @@
 - simple line: `sld 7a`_ / `full request 7a`_
 .. _`sld 7a`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple.xml
-.. _`full request 7a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple.xml
+.. _`full request 7a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_simple.xml
 - line with width: `sld 7b`_ / `full request 7b`_
 .. _`sld 7b`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_width.xml
-.. _`full request 7b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_width.xml
+.. _`full request 7b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_width.xml
 - dashed line: `sld 7c`_ / `full request 7c`_
 .. _`sld 7c`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_dash.xml
-.. _`full request 7c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_dash.xml
+.. _`full request 7c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen_Outline&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_line_dash.xml
 **Table 8. PolygonSymbolizer**
@@ -290,22 +290,22 @@
 - simple solid fill: `sld 8a`_ / `full request 8a`_
 .. _`sld 8a`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_solid_fill.xml
-.. _`full request 8a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_solid_fill.xml
+.. _`full request 8a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_solid_fill.xml
 - solid fill with outline: `sld 8b`_ / `full request 8b`_
 .. _`sld 8b`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_solid_fill_outline.xml
-.. _`full request 8b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_solid_fill_outline.xml
+.. _`full request 8b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_solid_fill_outline.xml
 - fill with mark symbol: `sld 8c`_ / `full request 8c`_
 .. _`sld 8c`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol.xml
-.. _`full request 8c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol.xml
+.. _`full request 8c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol.xml
 - fill with external symbol: `sld 8d`_/ `full request 8d`_
 .. _`sld 8d`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol_external.xml
-.. _`full request 8d`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol_external.xml
+.. _`full request 8d`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol_external.xml
 **Table 9. PointSymbolizer**
@@ -327,17 +327,17 @@
 - filled mark symbol: `sld 9a`_ / `full request 9a`_
 .. _`sld 9a`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol.xml
-.. _`full request 9a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol.xml
+.. _`full request 9a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol.xml
 - default settings (square, size 6, color 128/128/128): `sld 9b`_ / `full request 9b`_
 .. _`sld 9b`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol_default_settings.xml
-.. _`full request 9b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol_default_settings.xml
+.. _`full request 9b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol_default_settings.xml
 - external symbol: `sld 9c`_ / `full request 9c`_
 .. _`sld 9c`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol_external.xml
-.. _`full request 9c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol_external.xml
+.. _`full request 9c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPOI&BBOX=-84.7978536015,41.440374,-75.737539764,45.97524&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_symbol_external.xml
 **Table 10. TextSymbolizer**
@@ -385,18 +385,18 @@
 - annotation layer : test for label, font, point placement, color, angle: `sld 10a`_ / `full request 10a`_
 .. _`sld 10a`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_annotation.xml
-.. _`full request 10a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPlaces&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_annotation.xml
+.. _`full request 10a`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPlaces&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_annotation.xml
 - annotation layer with text and symbols using 2 symbolizers: `sld 10b`_ / `full request 10b`_
 .. _`sld 10b`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_with_symbols.xml
-.. _`full request 10b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPlaces&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_with_symbols.xml
+.. _`full request 10b`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldPlaces&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_with_symbols.xml
 - line layer with text using 2 symbolizers: `sld 10c`_ / `full request 10c`_
 .. _`sld 10c`: http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_line.xml
-.. _`full request 10c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldRoads&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_line.xml
+.. _`full request 10c`: http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldRoads&BBOX=-81.366241839,42.39269586,-77.8780568047,44.13861927&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&TRANSPARENT=TRUE&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_text_line.xml
 **Table 11. RasterSymbolizer**
