[mapserver-commits] r8458 - trunk/mapserver
Tue Jan 27 09:16:37 EST 2009
Author: aboudreault
Date: 2009-01-27 09:16:37 -0500 (Tue, 27 Jan 2009)
New Revision: 8458
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/configure
   trunk/mapserver/configure.in
Fixed build problem using --with-gd=static and freetype (#2697)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-01-26 21:09:54 UTC (rev 8457)
+++ trunk/mapserver/HISTORY.TXT	2009-01-27 14:16:37 UTC (rev 8458)
@@ -11,6 +11,9 @@
 Current Version (5.3-dev, SVN trunk):
+- Fixed build problem using --with-gd=static and freetype (#2697)
 - RFC49 implementation (#2865)
 - Fixed Blobs not filtered in OracleSpatial Attribute/WFS queries (#2829)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2009-01-26 21:09:54 UTC (rev 8457)
+++ trunk/mapserver/configure	2009-01-27 14:16:37 UTC (rev 8458)
@@ -7258,7 +7258,8 @@
 fi
-    as_ac_Lib=`echo "ac_cv_lib_$GD_CHECKLIB''_gdImageStringFT" | $as_tr_sh`
+    GD_FT_SUPPORT=no
+  as_ac_Lib=`echo "ac_cv_lib_$GD_CHECKLIB''_gdImageStringFT" | $as_tr_sh`
 { echo "$as_me:$LINENO: checking for gdImageStringFT in -l$GD_CHECKLIB" >&5
 echo $ECHO_N "checking for gdImageStringFT in -l$GD_CHECKLIB... $ECHO_C" >&6; }
 if { as_var=$as_ac_Lib; eval "test \"\${$as_var+set}\" = set"; }; then
@@ -7322,10 +7323,86 @@
 	       { echo "$as_me:$LINENO: result: $ac_res" >&5
 echo "${ECHO_T}$ac_res" >&6; }
 if test `eval echo '${'$as_ac_Lib'}'` = yes; then
-  GD_DEF="$GD_DEF -DUSE_GD_FT"
+  GD_FT_SUPPORT=yes
 fi
+    if test -n "$GD_STATIC" ; then
+     GD_LIB="$GD_LIB -lfontconfig"
+     unset ac_cv_lib_c___gdImageStringFT
+{ echo "$as_me:$LINENO: checking for gdImageStringFT in -l$GD_CHECKLIB" >&5
+echo $ECHO_N "checking for gdImageStringFT in -l$GD_CHECKLIB... $ECHO_C" >&6; }
+if { as_var=$as_ac_Lib; eval "test \"\${$as_var+set}\" = set"; }; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-l$GD_CHECKLIB $GD_STATIC $GD_LIB $GD_XTRA_LIBS $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Override any GCC internal prototype to avoid an error.
+   Use char because int might match the return type of a GCC
+   builtin and then its argument prototype would still apply.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+char gdImageStringFT ();
+int
+main ()
+return gdImageStringFT ();
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (ac_try="$ac_link"
+case "(($ac_try" in
+  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+  *) ac_try_echo=$ac_try;;
+esac
+eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5
+  (eval "$ac_link") 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } && {
+	 test -z "$ac_c_werror_flag" ||
+	 test ! -s conftest.err
+       } && test -s conftest$ac_exeext &&
+       $as_test_x conftest$ac_exeext; then
+  eval "$as_ac_Lib=yes"
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+	eval "$as_ac_Lib=no"
+fi
+rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
+      conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+ac_res=`eval echo '${'$as_ac_Lib'}'`
+	       { echo "$as_me:$LINENO: result: $ac_res" >&5
+echo "${ECHO_T}$ac_res" >&6; }
+if test `eval echo '${'$as_ac_Lib'}'` = yes; then
+  GD_FT_SUPPORT=yes
+fi
+  fi
+  if test "$GD_FT_SUPPORT" = "yes"; then
+     GD_DEF="$GD_DEF -DUSE_GD_FT"
+  fi
     as_ac_Lib=`echo "ac_cv_lib_$GD_CHECKLIB''_gdImageOpenPolygon" | $as_tr_sh`
 { echo "$as_me:$LINENO: checking for gdImageOpenPolygon in -l$GD_CHECKLIB" >&5
 echo $ECHO_N "checking for gdImageOpenPolygon in -l$GD_CHECKLIB... $ECHO_C" >&6; }
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2009-01-26 21:09:54 UTC (rev 8457)
+++ trunk/mapserver/configure.in	2009-01-27 14:16:37 UTC (rev 8458)
@@ -615,7 +615,7 @@
 if test -n "$with_gd" -a "$with_gd" != "yes" ; then
   dnl check gd lib that was found on --with-gd=
   if test "$GD_STATIC" = "yes" ; then
     dnl To test against static GD, do AC_CHECK_LIB calls against -lc and
     dnl include libgd.a in GD_LIB param
@@ -628,15 +628,27 @@
     # GD_LIB was already set above
     GD_STATIC=""
   fi
   AC_CHECK_LIB($GD_CHECKLIB, gdImageGif, GD_DEF="$GD_DEF -DUSE_GD_GIF",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
   AC_CHECK_LIB($GD_CHECKLIB, gdImagePng, GD_DEF="$GD_DEF -DUSE_GD_PNG",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
   AC_CHECK_LIB($GD_CHECKLIB, gdImageJpeg, GD_DEF="$GD_DEF -DUSE_GD_JPEG",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
   AC_CHECK_LIB($GD_CHECKLIB, gdImageWBMP, GD_DEF="$GD_DEF -DUSE_GD_WBMP",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
-  dnl check for Freetype 2.x support
-  AC_CHECK_LIB($GD_CHECKLIB, gdImageStringFT, GD_DEF="$GD_DEF -DUSE_GD_FT",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
+  dnl check for Freetype 2.x support
+  GD_FT_SUPPORT=no
+  AC_CHECK_LIB($GD_CHECKLIB, gdImageStringFT, GD_FT_SUPPORT=yes,, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
+  dnl If GD static is requested, it may needs libfontconfig.
+  fi
+  fi
   dnl check for gdImageOpenPolygon (means GD version 2.0.29 or higher)
   AC_CHECK_LIB($GD_CHECKLIB, gdImageOpenPolygon, GD_DEF="$GD_DEF -DGD_HAS_FTEX_XSHOW",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
