[mapserver-commits] r8467 - trunk/docs/utilities
Wed Jan 28 13:50:54 EST 2009
Author: jmckenna
Date: 2009-01-28 13:50:54 -0500 (Wed, 28 Jan 2009)
New Revision: 8467
   trunk/docs/utilities/shptree.txt
point to wiki page
Modified: trunk/docs/utilities/shptree.txt
--- trunk/docs/utilities/shptree.txt	2009-01-28 17:58:12 UTC (rev 8466)
+++ trunk/docs/utilities/shptree.txt	2009-01-28 18:50:54 UTC (rev 8467)
@@ -12,6 +12,9 @@
 Do not use the default with point files, a value between 6 and 10 seems to work ok.
 Your millage may vary and you'll need to do some experimenting.
+The `shptree wiki page <http://trac.osgeo.org/mapserver/wiki/ShpTree>`__ may
+also contain information on this utility.
 Description
 This utility is a must for any MapServer application that uses shapefiles.  Shptree
