[mapserver-commits] r8475 - sandbox/hobu/ISC_5.4/mapserver
Wed Jan 28 23:28:31 EST 2009
Author: hobu
Date: 2009-01-28 23:28:31 -0500 (Wed, 28 Jan 2009)
New Revision: 8475
   sandbox/hobu/ISC_5.4/mapserver/mapstring.c
port r6917
Modified: sandbox/hobu/ISC_5.4/mapserver/mapstring.c
--- sandbox/hobu/ISC_5.4/mapserver/mapstring.c	2009-01-29 02:58:22 UTC (rev 8474)
+++ sandbox/hobu/ISC_5.4/mapserver/mapstring.c	2009-01-29 04:28:31 UTC (rev 8475)
@@ -1452,8 +1452,10 @@
   if(fribidi_parse_charset ((char*)encoding))
     return msGetFriBidiEncodedString(string, encoding);
 #endif
-  len = strlen(string);
+  //len = strlen(string);
+  len = _ISC_msGetLength(string, encoding);
   if (len == 0 || (encoding && strcasecmp(encoding, "UTF-8")==0))
       return strdup(string);    /* Nothing to do: string already in UTF-8 */
@@ -1876,3 +1878,55 @@
     /*no newline found in text*/
     return strdup(text);
+const char *_ISC_2ByteFizedWidthFormats[] = { "UTF-16", "UTF-16LE", "UTF-16BE", "UCS-2", "UCS-2LE", "UCS-2BE", "UCS-2-INTERNAL", NULL };
+size_t _ISC_msGetLength(const char *string, const char *encoding)
+    char *enc;
+    int n, found;
+    enc = strdup(encoding);
+    n = 0;
+    /* convert to uppercase and trim trailing junk */
+    while (enc[n] != '\0')
+        char a = enc[n];
+        if (a == ' ' || a == '/')
+            enc[n] = '\0';
+            break;
+        else if (a >= 'a' && a <= 'z')
+            a -= 32;
+            enc[n] = a;
+        n++;
+    /* look for matching 2 byte format */
+    found = n = 0;
+    for (; _ISC_2ByteFizedWidthFormats[n] != NULL && !found; n++)
+        if (!strcmp(enc, _ISC_2ByteFizedWidthFormats[n]))
+            found = 1;
+    /* free the result of the strdup call */
+    msFree(enc);
+    if (found)
+        /* look for 2 byte null terminator */
+        unsigned short *wstring = (unsigned short *)string;
+        n = 0;
+        while (wstring[n] != 0) n++;
+        return (size_t)(2 * (n - 1));
+    return strlen(string);
