[mapserver-commits] r9131 - branches/branch-5-4/mapserver
Wed Jul 1 00:20:32 EDT 2009
Author: sdlime
Date: 2009-07-01 00:20:32 -0400 (Wed, 01 Jul 2009)
New Revision: 9131
   branches/branch-5-4/mapserver/HISTORY.TXT
   branches/branch-5-4/mapserver/mapprimitive.c
Removed isOuterRing() test from getPolygonCenterOfGravity(), really slowed things down. (#3053)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT	2009-06-30 14:53:49 UTC (rev 9130)
+++ branches/branch-5-4/mapserver/HISTORY.TXT	2009-07-01 04:20:32 UTC (rev 9131)
@@ -13,8 +13,12 @@
 Current Version:
 - Add centroid geomtransform (#2825)
+- Fixed performance bottleneck when computing a polygon center of gravity for
+  label point computation. (#3053)
 - Save ALIGN parameter if it is set to CENTER or RIGHT (#3057)
 - PHP: add a getResults method on the layer object (#2967)
Modified: branches/branch-5-4/mapserver/mapprimitive.c
--- branches/branch-5-4/mapserver/mapprimitive.c	2009-06-30 14:53:49 UTC (rev 9130)
+++ branches/branch-5-4/mapserver/mapprimitive.c	2009-07-01 04:20:32 UTC (rev 9131)
@@ -1010,22 +1010,20 @@
   double largestArea=0;
   for(i=0; i<p->numlines; i++) {
-    if(isOuterRing(p, i)) {
-      tsx = tsy = s = 0; /* reset the ring sums */
-      for(j=0; j<p->line[i].numpoints-1; j++) {
-        a = p->line[i].point[j].x*p->line[i].point[j+1].y - p->line[i].point[j+1].x*p->line[i].point[j].y;
-        s += a;
-        tsx += (p->line[i].point[j].x + p->line[i].point[j+1].x)*a;
-        tsy += (p->line[i].point[j].y + p->line[i].point[j+1].y)*a;
-      area = MS_ABS(s/2);
-      if(area > largestArea) {
-        largestArea = area;
-        sx = s>0?tsx:-tsx;
-        sy = s>0?tsy:-tsy;
+    tsx = tsy = s = 0; /* reset the ring sums */
+    for(j=0; j<p->line[i].numpoints-1; j++) {
+      a = p->line[i].point[j].x*p->line[i].point[j+1].y - p->line[i].point[j+1].x*p->line[i].point[j].y;
+      s += a;
+      tsx += (p->line[i].point[j].x + p->line[i].point[j+1].x)*a;
+      tsy += (p->line[i].point[j].y + p->line[i].point[j+1].y)*a;
+    area = MS_ABS(s/2);
+    if(area > largestArea) {
+      largestArea = area;
+      sx = s>0?tsx:-tsx;
+      sy = s>0?tsy:-tsy;
   lp->x = sx/(6*largestArea);
