[mapserver-commits] r9174 - branches/branch-5-0/mapserver
Mon Jul 13 16:42:18 EDT 2009
Author: dmorissette
Date: 2009-07-13 16:42:17 -0400 (Mon, 13 Jul 2009)
New Revision: 9174
   branches/branch-5-0/mapserver/HISTORY.TXT
   branches/branch-5-0/mapserver/cgiutil.c
   branches/branch-5-0/mapserver/mapserver.h
Fix for CVE-2009-0840 security vulnerability (#2943)
Modified: branches/branch-5-0/mapserver/HISTORY.TXT
--- branches/branch-5-0/mapserver/HISTORY.TXT	2009-07-13 20:34:07 UTC (rev 9173)
+++ branches/branch-5-0/mapserver/HISTORY.TXT	2009-07-13 20:42:17 UTC (rev 9174)
@@ -10,6 +10,11 @@
 For a complete change history, please see the Subversion log comments.
+Current Version (SVN branch, may never be released):
+- Fix for CVE-2009-0840 security vulnerability (#2943)
 Version 5.0.3 (2008-06-04)
Modified: branches/branch-5-0/mapserver/cgiutil.c
--- branches/branch-5-0/mapserver/cgiutil.c	2009-07-13 20:34:07 UTC (rev 9173)
+++ branches/branch-5-0/mapserver/cgiutil.c	2009-07-13 20:42:17 UTC (rev 9174)
@@ -1,4 +1,5 @@
+ * $Id$
  * Project:  MapServer
  * Purpose:  cgiRequestObj and CGI parameter parsing.
@@ -41,7 +42,8 @@
 static char *readPostBody( cgiRequestObj *request )
   char *data;
-  int data_max, data_len, chunk_size;
+  size_t data_max, data_len;
+  int chunk_size;
   msIO_needBinaryStdin();
@@ -49,11 +51,17 @@
   /*      If the length is provided, read in one gulp.                    */
   if( getenv("CONTENT_LENGTH") != NULL ) {
-    data_max = atoi(getenv("CONTENT_LENGTH"));
+    data_max = (size_t) atoi(getenv("CONTENT_LENGTH"));
+    /* Test for suspicious CONTENT_LENGTH (negative value or SIZE_MAX) */
+    if( data_max >= SIZE_MAX ) {
+      msIO_printf("Content-type: text/html%c%c",10,10);
+      msIO_printf("Suspicious Content-Length.\n");
+      exit( 1 );
     data = (char *) malloc(data_max+1);
     if( data == NULL ) {
-      msIO_printf("malloc() failed, Content-Length: %d unreasonably large?\n", data_max );
+      msIO_printf("malloc() failed, Content-Length: %u unreasonably large?\n", data_max );
       exit( 1 );
@@ -70,7 +78,9 @@
   /*      Otherwise read in chunks to the end.                            */
-  data_max = 10000;
+#define DATA_ALLOC_SIZE 10000
+  data_max = DATA_ALLOC_SIZE;
   data_len = 0;
@@ -78,12 +88,19 @@
     data_len += chunk_size;
     if( data_len == data_max ) {
-      data_max = data_max + 10000;
+      /* Realloc buffer, making sure we check for possible size_t overflow */
+        if ( data_max > SIZE_MAX - (DATA_ALLOC_SIZE+1) ) {
+        msIO_printf("Possible size_t overflow, cannot reallocate input buffer, POST body too large?\n" );
+        exit(1);
+      data_max = data_max + DATA_ALLOC_SIZE;
       data = (char *) realloc(data, data_max+1);
-        msIO_printf("out of memory trying to allocate %d input buffer, POST body too large?\n", data_max+1 );
+        msIO_printf("out of memory trying to allocate %u input buffer, POST body too large?\n", data_max+1 );
         exit(1);
Modified: branches/branch-5-0/mapserver/mapserver.h
--- branches/branch-5-0/mapserver/mapserver.h	2009-07-13 20:34:07 UTC (rev 9173)
+++ branches/branch-5-0/mapserver/mapserver.h	2009-07-13 20:42:17 UTC (rev 9174)
@@ -65,6 +65,10 @@
 /* definition of  ms_int32/ms_uint32 */
 #include <limits.h>
+#ifndef _WIN32
+#include <stdint.h>
+#endif
 #if ULONG_MAX == 0xffffffff
 typedef long            ms_int32;
 typedef unsigned long   ms_uint32;
@@ -72,7 +76,6 @@
 typedef int             ms_int32;
 typedef unsigned int    ms_uint32;
 #else
-#include <stdint.h>
 typedef int32_t         ms_int32;
 typedef uint32_t        ms_uint32;
 #endif
