[mapserver-commits] r9197 - trunk/docs/en/mapfile
Tue Jul 21 12:27:29 EDT 2009
Author: aboudreault
Date: 2009-07-21 12:27:29 -0400 (Tue, 21 Jul 2009)
New Revision: 9197
   trunk/docs/en/mapfile/label.txt
Added the repeatdistance label parameter in doc
Modified: trunk/docs/en/mapfile/label.txt
--- trunk/docs/en/mapfile/label.txt	2009-07-21 16:15:20 UTC (rev 9196)
+++ trunk/docs/en/mapfile/label.txt	2009-07-21 16:27:29 UTC (rev 9197)
@@ -192,6 +192,13 @@
      shape attribute will be clamped to the min/max values at rendering time.
      There is no expected impact on performance for using label priorities.
+REPEATDISTANCE [integer]
+    - Introduced in version 5.6. The label will be repeated on every line of
+      a multiline shape and will be repeated multiple times along a given
+      line at an interval of REPEATDISTANCE pixels.
+      The associated RFC document for this feature is :ref:`RFC57`.
 SHADOWCOLOR [r] [g] [b]
     Color of drop shadow.
