[mapserver-commits] r9200 - trunk/mapserver
Wed Jul 22 00:20:44 EDT 2009
Author: sdlime
Date: 2009-07-22 00:20:44 -0400 (Wed, 22 Jul 2009)
New Revision: 9200
   trunk/mapserver/mapgraticule.c
   trunk/mapserver/maplayer.c
   trunk/mapserver/mapmygis.c
   trunk/mapserver/mapogr.cpp
   trunk/mapserver/maporaclespatial.c
   trunk/mapserver/mappostgis.c
   trunk/mapserver/maprasterquery.c
   trunk/mapserver/mapsde.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapshape.c
   trunk/mapserver/mapwfslayer.c
Added hooks for msLayerResultsGetShape(). #3069
Modified: trunk/mapserver/mapgraticule.c
--- trunk/mapserver/mapgraticule.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapgraticule.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -547,13 +547,12 @@
   layer->vtable->LayerIsOpen = msGraticuleLayerIsOpen;
   layer->vtable->LayerWhichShapes = msGraticuleLayerWhichShapes;
   layer->vtable->LayerNextShape = msGraticuleLayerNextShape;
+  /* layer->vtable->LayerResultsGetShape, use default */
   layer->vtable->LayerGetShape = msGraticuleLayerGetShape;
   layer->vtable->LayerClose = msGraticuleLayerClose;
   layer->vtable->LayerGetItems = msGraticuleLayerGetItems;
   layer->vtable->LayerGetExtent = msGraticuleLayerGetExtent;
   layer->vtable->LayerGetAutoStyle = msGraticuleLayerGetAutoStyle;
   /* layer->vtable->LayerCloseConnection, use default */;
   layer->vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
   /* layer->vtable->LayerApplyFilterToLayer, use default */
Modified: trunk/mapserver/maplayer.c
--- trunk/mapserver/maplayer.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/maplayer.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -146,6 +146,21 @@
+** Used to retrieve a shape from a result set by index. Result sets are created by the various
+** msQueryBy...() functions. The index is assigned by the data source.
+int msLayerResultsGetShape(layerObj *layer, shapeObj *shape, int tile, long record)
+  if ( ! layer->vtable) {
+    int rv =  msInitializeVirtualTable(layer);
+    if (rv != MS_SUCCESS)
+      return rv;
+  return layer->vtable->LayerResultsGetShape(layer, shape, tile, record);
 ** Used to retrieve a shape by index. All data sources must be capable of random access using
 ** a record number of some sort.
@@ -373,7 +388,7 @@
     freeitems = MS_TRUE;
-  /* layer-level item use */
+  /* layer-level item use (TODO: consider making sure the item is valid before adding to the list some how) */
   if(layer->classitem) layer->classitemindex = string2list(layer->items, &(layer->numitems), layer->classitem);
   if(layer->filteritem) layer->filteritemindex = string2list(layer->items, &(layer->numitems), layer->filteritem);
   if(layer->labelitem) layer->labelitemindex = string2list(layer->items, &(layer->numitems), layer->labelitem);
@@ -868,57 +883,52 @@
  * Dummies / default actions for layers
-int
-LayerDefaultInitItemInfo(layerObj *layer)
+int LayerDefaultInitItemInfo(layerObj *layer)
-    return MS_SUCCESS;
+  return MS_SUCCESS;
-void
-LayerDefaultFreeItemInfo(layerObj *layer)
+void LayerDefaultFreeItemInfo(layerObj *layer)
-    return;
+  return;
 int LayerDefaultOpen(layerObj *layer)
-    return MS_FAILURE;
+  return MS_FAILURE;
-int
-LayerDefaultIsOpen(layerObj *layer)
+int LayerDefaultIsOpen(layerObj *layer)
-    return MS_FALSE;
+  return MS_FALSE;
-int
-LayerDefaultWhichShapes(layerObj *layer, rectObj rect)
+int LayerDefaultWhichShapes(layerObj *layer, rectObj rect)
-int
-LayerDefaultNextShape(layerObj *layer, shapeObj *shape)
+int LayerDefaultNextShape(layerObj *layer, shapeObj *shape)
+int LayerDefaultResultsGetShape(layerObj *layer, shapeObj *shape, int tile, long record)
-int
-LayerDefaultGetShape(layerObj *layer, shapeObj *shape,
-                     int tile, long record)
+int LayerDefaultGetShape(layerObj *layer, shapeObj *shape, int tile, long record)
-int
-LayerDefaultClose(layerObj *layer)
+int LayerDefaultClose(layerObj *layer)
-int
-LayerDefaultGetItems(layerObj *layer)
+int LayerDefaultGetItems(layerObj *layer)
   return MS_SUCCESS; /* returning no items is legit */
@@ -947,47 +957,39 @@
 #endif
-int
-LayerDefaultGetExtent(layerObj *layer, rectObj *extent)
+int LayerDefaultGetExtent(layerObj *layer, rectObj *extent)
-int
-LayerDefaultGetAutoStyle(mapObj *map, layerObj *layer, classObj *c,
+int LayerDefaultGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, int tile, long record)
-    msSetError(MS_MISCERR, "'STYLEITEM AUTO' not supported for this data source.", "msLayerGetAutoStyle()");
+  msSetError(MS_MISCERR, "'STYLEITEM AUTO' not supported for this data source.", "msLayerGetAutoStyle()");
-int
-LayerDefaultCloseConnection(layerObj *layer)
+int LayerDefaultCloseConnection(layerObj *layer)
-int
-LayerDefaultCreateItems(layerObj *layer,
-                      const int nt)
+int LayerDefaultCreateItems(layerObj *layer, const int nt)
-    if (nt > 0) {
-        layer->items = (char **)calloc(nt, sizeof(char *)); /* should be more than enough space */
-        if(!layer->items) {
-            msSetError(MS_MEMERR, NULL, "LayerDefaultCreateItems()");
-            return(MS_FAILURE);
-        layer->numitems = 0;
+  if (nt > 0) {
+    layer->items = (char **)calloc(nt, sizeof(char *)); /* should be more than enough space */
+    if(!layer->items) {
+      msSetError(MS_MEMERR, NULL, "LayerDefaultCreateItems()");
+      return(MS_FAILURE);
+    layer->numitems = 0;
-int
-LayerDefaultGetNumFeatures(layerObj *layer)
+int LayerDefaultGetNumFeatures(layerObj *layer)
-    msSetError(MS_SHPERR, "Not an inline layer", "msLayerGetNumFeatures()");
+  msSetError(MS_SHPERR, "Not an inline layer", "msLayerGetNumFeatures()");
@@ -1020,122 +1022,116 @@
     return msInitializeVirtualTable(layer) ;
-static int
-populateVirtualTable(layerVTableObj *vtable)
+static int populateVirtualTable(layerVTableObj *vtable)
-    assert(vtable != NULL);
+  assert(vtable != NULL);
-    vtable->LayerInitItemInfo = LayerDefaultInitItemInfo;
-    vtable->LayerFreeItemInfo = LayerDefaultFreeItemInfo;
-    vtable->LayerOpen = LayerDefaultOpen;
-    vtable->LayerIsOpen = LayerDefaultIsOpen;
-    vtable->LayerWhichShapes = LayerDefaultWhichShapes;
+  vtable->LayerInitItemInfo = LayerDefaultInitItemInfo;
+  vtable->LayerFreeItemInfo = LayerDefaultFreeItemInfo;
+  vtable->LayerOpen = LayerDefaultOpen;
+  vtable->LayerIsOpen = LayerDefaultIsOpen;
+  vtable->LayerWhichShapes = LayerDefaultWhichShapes;
-    vtable->LayerNextShape = LayerDefaultNextShape;
-    vtable->LayerGetShape = LayerDefaultGetShape;
-    vtable->LayerClose = LayerDefaultClose;
-    vtable->LayerGetItems = LayerDefaultGetItems;
-    vtable->LayerGetExtent = LayerDefaultGetExtent;
+  vtable->LayerNextShape = LayerDefaultNextShape;
+  vtable->LayerResultsGetShape = LayerDefaultResultsGetShape;
+  vtable->LayerGetShape = LayerDefaultGetShape;
+  vtable->LayerClose = LayerDefaultClose;
+  vtable->LayerGetItems = LayerDefaultGetItems;
+  vtable->LayerGetExtent = LayerDefaultGetExtent;
-    vtable->LayerGetAutoStyle = LayerDefaultGetAutoStyle;
-    vtable->LayerCloseConnection = LayerDefaultCloseConnection;
-    vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
+  vtable->LayerGetAutoStyle = LayerDefaultGetAutoStyle;
+  vtable->LayerCloseConnection = LayerDefaultCloseConnection;
+  vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
-    vtable->LayerApplyFilterToLayer = msLayerApplyPlainFilterToLayer;
+  vtable->LayerApplyFilterToLayer = msLayerApplyPlainFilterToLayer;
-    vtable->LayerCreateItems = LayerDefaultCreateItems;
+  vtable->LayerCreateItems = LayerDefaultCreateItems;
-    vtable->LayerGetNumFeatures = LayerDefaultGetNumFeatures;
+  vtable->LayerGetNumFeatures = LayerDefaultGetNumFeatures;
-static int
-createVirtualTable(layerVTableObj **vtable)
+static int createVirtualTable(layerVTableObj **vtable)
-    *vtable = malloc(sizeof(**vtable));
-    if ( ! *vtable) {
-    return populateVirtualTable(*vtable);
+  *vtable = malloc(sizeof(**vtable));
+  if ( ! *vtable) {
+  return populateVirtualTable(*vtable);
-static int
-destroyVirtualTable(layerVTableObj **vtable)
+static int destroyVirtualTable(layerVTableObj **vtable)
-    memset(*vtable, 0, sizeof(**vtable));
-    msFree(*vtable);
-    *vtable = NULL;
+  memset(*vtable, 0, sizeof(**vtable));
+  msFree(*vtable);
+  *vtable = NULL;
-int
-msInitializeVirtualTable(layerObj *layer)
+int msInitializeVirtualTable(layerObj *layer)
-    if (layer->vtable) {
-        destroyVirtualTable(&layer->vtable);
-    createVirtualTable(&layer->vtable);
+  if (layer->vtable) {
+    destroyVirtualTable(&layer->vtable);
+  createVirtualTable(&layer->vtable);
+  if(layer->features && layer->connectiontype != MS_GRATICULE )
+    layer->connectiontype = MS_INLINE;
-    if(layer->features && layer->connectiontype != MS_GRATICULE )
-      layer->connectiontype = MS_INLINE;
+  if(layer->tileindex && layer->connectiontype == MS_SHAPEFILE)
+    layer->connectiontype = MS_TILED_SHAPEFILE;
-    if(layer->tileindex && layer->connectiontype == MS_SHAPEFILE)
-      layer->connectiontype = MS_TILED_SHAPEFILE;
+  if(layer->type == MS_LAYER_RASTER && layer->connectiontype != MS_WMS)
+    layer->connectiontype = MS_RASTER;
-    if(layer->type == MS_LAYER_RASTER && layer->connectiontype != MS_WMS)
-      layer->connectiontype = MS_RASTER;
-    switch(layer->connectiontype) {
-        case(MS_INLINE):
-            return(msINLINELayerInitializeVirtualTable(layer));
-            break;
-        case(MS_SHAPEFILE):
-            return(msShapeFileLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_TILED_SHAPEFILE):
-            return(msTiledSHPLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_SDE):
-            return(msSDELayerInitializeVirtualTable(layer));
-            break;
-        case(MS_OGR):
-            return(msOGRLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_POSTGIS):
-            return(msPostGISLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_WMS):
-              /* WMS should be treated as a raster layer */
-              return(msRASTERLayerInitializeVirtualTable(layer));
-              break;
-        case(MS_ORACLESPATIAL):
-            return(msOracleSpatialLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_WFS):
-            return(msWFSLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_GRATICULE):
-            return(msGraticuleLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_MYGIS):
-            return(msMYGISLayerInitializeVirtualTable(layer));
-            break;
-        case(MS_RASTER):
-            break;
-        case(MS_PLUGIN):
-            return(msPluginLayerInitializeVirtualTable(layer));
-            break;
-        default:
-                       "Unknown connectiontype, it was %d",
-                       "msInitializeVirtualTable()", layer->connectiontype);
-            break;
+  switch(layer->connectiontype) {
+    case(MS_INLINE):
+      return(msINLINELayerInitializeVirtualTable(layer));
+      break;
+    case(MS_SHAPEFILE):
+      return(msShapeFileLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_TILED_SHAPEFILE):
+      return(msTiledSHPLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_SDE):
+      return(msSDELayerInitializeVirtualTable(layer));
+      break;
+    case(MS_OGR):
+      return(msOGRLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_POSTGIS):
+      return(msPostGISLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_WMS):
+      /* WMS should be treated as a raster layer */
+      return(msRASTERLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_ORACLESPATIAL):
+      return(msOracleSpatialLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_WFS):
+      return(msWFSLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_GRATICULE):
+      return(msGraticuleLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_MYGIS):
+      return(msMYGISLayerInitializeVirtualTable(layer));
+      break;
+    case(MS_RASTER):
+      break;
+    case(MS_PLUGIN):
+      return(msPluginLayerInitializeVirtualTable(layer));
+      break;
+    default:
+      msSetError(MS_MISCERR, "Unknown connectiontype, it was %d", "msInitializeVirtualTable()", layer->connectiontype);
+      break;
     /* not reached */
     return MS_FAILURE;
@@ -1237,6 +1233,7 @@
     layer->vtable->LayerIsOpen = msINLINELayerIsOpen;
     /* layer->vtable->LayerWhichShapes, use default */
     layer->vtable->LayerNextShape = msINLINELayerNextShape;
+    layer->vtable->LayerResultsGetShape = msINLINELayerGetShape; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msINLINELayerGetShape;
     /* layer->vtable->LayerClose, use default */
     /* layer->vtable->LayerGetItems, use default */
Modified: trunk/mapserver/mapmygis.c
--- trunk/mapserver/mapmygis.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapmygis.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Implements the MySQL/"MyGIS" connection type support.
@@ -1980,23 +1980,18 @@
     layer->vtable->LayerIsOpen = msMYGISLayerIsOpen;
     layer->vtable->LayerWhichShapes = msMYGISLayerWhichShapes;
     layer->vtable->LayerNextShape = msMYGISLayerNextShape;
+    layer->vtable->LayerResultsGetShape = msMYGISLayerGetShapeVT; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msMYGISLayerGetShapeVT;
     layer->vtable->LayerClose = msMYGISLayerClose;
     layer->vtable->LayerGetItems = msMYGISLayerGetItems;
     layer->vtable->LayerGetExtent = msMYGISLayerGetExtent;
     /* layer->vtable->LayerGetAutoStyle, use default */
     layer->vtable->LayerCloseConnection = msMYGISLayerClose;
     /* layer->vtable->LayerCreateItems, use default */
     /* layer->vtable->LayerGetNumFeatures, use default */
     return MS_SUCCESS;
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapogr.cpp	2009-07-22 04:20:44 UTC (rev 9200)
@@ -3371,22 +3371,18 @@
     layer->vtable->LayerIsOpen = msOGRLayerIsOpen;
     layer->vtable->LayerWhichShapes = msOGRLayerWhichShapes;
     layer->vtable->LayerNextShape = msOGRLayerNextShape;
+    layer->vtable->LayerResultsGetShape = msOGRLayerGetShape; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msOGRLayerGetShape;
     layer->vtable->LayerClose = msOGRLayerClose;
     layer->vtable->LayerGetItems = msOGRLayerGetItems;
     layer->vtable->LayerGetExtent = msOGRLayerGetExtent;
     layer->vtable->LayerGetAutoStyle = msOGRLayerGetAutoStyle;
     layer->vtable->LayerApplyFilterToLayer = msLayerApplyCondSQLFilterToLayer;
     layer->vtable->LayerSetTimeFilter = msLayerMakeBackticsTimeFilter;
     return MS_SUCCESS;
Modified: trunk/mapserver/maporaclespatial.c
--- trunk/mapserver/maporaclespatial.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/maporaclespatial.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -2649,19 +2649,16 @@
     vtable->LayerIsOpen = msOracleSpatialLayerIsOpen;
     vtable->LayerWhichShapes = msOracleSpatialLayerWhichShapes;
     vtable->LayerNextShape = msOracleSpatialLayerNextShape;
+    vtable->LayerResultsGetShape = msOracleSpatialLayerGetShapeVT; /* no special version, use ...GetShape() */
     vtable->LayerGetShape = msOracleSpatialLayerGetShapeVT;
     vtable->LayerClose = msOracleSpatialLayerClose;
     vtable->LayerGetItems = msOracleSpatialLayerGetItems;
     vtable->LayerGetExtent = msOracleSpatialLayerGetExtent;
     vtable->LayerCloseConnection = msOracleSpatialLayerClose;
     return MS_SUCCESS;
@@ -2680,18 +2677,14 @@
     layer->vtable->LayerIsOpen = msOracleSpatialLayerIsOpen;
     layer->vtable->LayerWhichShapes = msOracleSpatialLayerWhichShapes;
     layer->vtable->LayerNextShape = msOracleSpatialLayerNextShape;
+    layer->vtable->LayerResultsGetShape = msOracleSpatialLayerGetShapeVT; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msOracleSpatialLayerGetShapeVT;
     layer->vtable->LayerClose = msOracleSpatialLayerClose;
     layer->vtable->LayerGetItems = msOracleSpatialLayerGetItems;
     layer->vtable->LayerGetExtent = msOracleSpatialLayerGetExtent;
     layer->vtable->LayerCloseConnection = msOracleSpatialLayerClose;
Modified: trunk/mapserver/mappostgis.c
--- trunk/mapserver/mappostgis.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mappostgis.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -2397,25 +2397,17 @@
     layer->vtable->LayerIsOpen = msPostGISLayerIsOpen;
     layer->vtable->LayerWhichShapes = msPostGISLayerWhichShapes;
     layer->vtable->LayerNextShape = msPostGISLayerNextShape;
+    layer->vtable->LayerResultsGetShape = msPostGISLayerGetShape; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msPostGISLayerGetShape;
     layer->vtable->LayerClose = msPostGISLayerClose;
     layer->vtable->LayerGetItems = msPostGISLayerGetItems;
     layer->vtable->LayerGetExtent = msPostGISLayerGetExtent;
     /* layer->vtable->LayerGetAutoStyle, not supported for this layer */
     layer->vtable->LayerCloseConnection = msPostGISLayerClose;
     layer->vtable->LayerSetTimeFilter = msPostGISLayerSetTimeFilter;
     return MS_SUCCESS;
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/maprasterquery.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -1431,20 +1431,16 @@
     layer->vtable->LayerIsOpen = msRASTERLayerIsOpen;
     layer->vtable->LayerWhichShapes = msRASTERLayerWhichShapes;
     layer->vtable->LayerNextShape = msRASTERLayerNextShape;
+    layer->vtable->LayerResultsGetShape = msRASTERLayerGetShape; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msRASTERLayerGetShape;
     layer->vtable->LayerClose = msRASTERLayerClose;
     layer->vtable->LayerGetItems = msRASTERLayerGetItems;
     layer->vtable->LayerGetExtent = msRASTERLayerGetExtent;
     layer->vtable->LayerCloseConnection = msRASTERLayerClose;
     /* we use backtics for proper tileindex shapefile functioning */
     layer->vtable->LayerSetTimeFilter = msRASTERLayerSetTimeFilter;
Modified: trunk/mapserver/mapsde.c
--- trunk/mapserver/mapsde.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapsde.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -2179,6 +2179,7 @@
     vtable->LayerIsOpen = msSDELayerIsOpen;
     vtable->LayerWhichShapes = msSDELayerWhichShapes;
     vtable->LayerNextShape = msSDELayerNextShape;
+    vtable->LayerResultsGetShape = msSDELayerGetShapeVT; /* no special version, use ...GetShape() */
     vtable->LayerGetShape = msSDELayerGetShapeVT;
     vtable->LayerClose = msSDELayerClose;
     vtable->LayerGetItems = msSDELayerGetItems;
@@ -2211,17 +2212,14 @@
     layer->vtable->LayerIsOpen = msSDELayerIsOpen;
     layer->vtable->LayerWhichShapes = msSDELayerWhichShapes;
     layer->vtable->LayerNextShape = msSDELayerNextShape;
+    layer->vtable->LayerResultsGetShape = msSDELayerGetShapeVT; /* no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msSDELayerGetShapeVT;
     layer->vtable->LayerClose = msSDELayerClose;
     layer->vtable->LayerGetItems = msSDELayerGetItems;
     layer->vtable->LayerGetExtent = msSDELayerGetExtent;
-    /* SDE uses pooled connections, close from msCloseConnections */
-    layer->vtable->LayerCloseConnection = msSDELayerCloseConnection;
+    layer->vtable->LayerCloseConnection = msSDELayerCloseConnection; /* SDE uses pooled connections, close from msCloseConnections */
     layer->vtable->LayerCreateItems = msSDELayerCreateItems;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapserver.h	2009-07-22 04:20:44 UTC (rev 9200)
@@ -1489,6 +1489,8 @@
     int (*LayerIsOpen)(layerObj *layer);
     int (*LayerWhichShapes)(layerObj *layer, rectObj rect);
     int (*LayerNextShape)(layerObj *layer, shapeObj *shape);
+    int (*LayerResultsGetShape)(layerObj *layer, shapeObj *shape,
+                         int tile, long record);
     int (*LayerGetShape)(layerObj *layer, shapeObj *shape,
     int (*LayerClose)(layerObj *layer);
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapshape.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -2345,48 +2345,44 @@
 void msTiledSHPLayerFreeItemInfo(layerObj *layer)
-	if(layer->iteminfo) {
-		free(layer->iteminfo);
-		layer->iteminfo = NULL;
+  if(layer->iteminfo) {
+    free(layer->iteminfo);
+    layer->iteminfo = NULL;
 int msTiledSHPLayerIsOpen(layerObj *layer)
-	if(layer->layerinfo)
-		return MS_TRUE;
-	else
-		return MS_FALSE;
+  if(layer->layerinfo)
+    return MS_TRUE;
+  else
+    return MS_FALSE;
 int msTiledSHPLayerInitializeVirtualTable(layerObj *layer)
-	assert(layer != NULL);
-	assert(layer->vtable != NULL);
+  assert(layer != NULL);
+  assert(layer->vtable != NULL);
-	layer->vtable->LayerInitItemInfo = msTiledSHPLayerInitItemInfo;
-	layer->vtable->LayerFreeItemInfo = msTiledSHPLayerFreeItemInfo;
-	layer->vtable->LayerOpen = msTiledSHPOpenFile;
-	layer->vtable->LayerIsOpen = msTiledSHPLayerIsOpen;
-	layer->vtable->LayerWhichShapes = msTiledSHPWhichShapes;
-	layer->vtable->LayerNextShape = msTiledSHPNextShape;
-	layer->vtable->LayerGetShape = msTiledSHPGetShape;
-	layer->vtable->LayerClose = msTiledSHPCloseVT;
-	layer->vtable->LayerGetItems = msTiledSHPLayerGetItems;
-	layer->vtable->LayerGetExtent = msTiledSHPLayerGetExtent;
+  layer->vtable->LayerInitItemInfo = msTiledSHPLayerInitItemInfo;
+  layer->vtable->LayerFreeItemInfo = msTiledSHPLayerFreeItemInfo;
+  layer->vtable->LayerOpen = msTiledSHPOpenFile;
+  layer->vtable->LayerIsOpen = msTiledSHPLayerIsOpen;
+  layer->vtable->LayerWhichShapes = msTiledSHPWhichShapes;
+  layer->vtable->LayerNextShape = msTiledSHPNextShape;
+  layer->vtable->LayerResultsGetShape = msTiledSHPGetShape; /* no special version, use ...GetShape() */
+  layer->vtable->LayerGetShape = msTiledSHPGetShape;
+  layer->vtable->LayerClose = msTiledSHPCloseVT;
+  layer->vtable->LayerGetItems = msTiledSHPLayerGetItems;
+  layer->vtable->LayerGetExtent = msTiledSHPLayerGetExtent;
-	/* layer->vtable->LayerGetAutoStyle, use default */
-	/* layer->vtable->LayerCloseConnection, use default */;
-	layer->vtable->LayerSetTimeFilter = msLayerMakeBackticsTimeFilter;
-	/* layer->vtable->LayerCreateItems, use default */
+  /* layer->vtable->LayerGetAutoStyle, use default */
+  /* layer->vtable->LayerCloseConnection, use default */;
+  layer->vtable->LayerSetTimeFilter = msLayerMakeBackticsTimeFilter;
+  /* layer->vtable->LayerCreateItems, use default */
 /* SHAPEFILE Layer virtual table functions */
@@ -2605,6 +2601,7 @@
   layer->vtable->LayerIsOpen = msShapeFileLayerIsOpen;
   layer->vtable->LayerWhichShapes = msShapeFileLayerWhichShapes;
   layer->vtable->LayerNextShape = msShapeFileLayerNextShape;
+  layer->vtable->LayerResultsGetShape = msShapeFileLayerGetShape; /* no special version, use ...GetShape() */
   layer->vtable->LayerGetShape = msShapeFileLayerGetShape;
   layer->vtable->LayerClose = msShapeFileLayerClose;
   layer->vtable->LayerGetItems = msShapeFileLayerGetItems;
Modified: trunk/mapserver/mapwfslayer.c
--- trunk/mapserver/mapwfslayer.c	2009-07-21 19:34:36 UTC (rev 9199)
+++ trunk/mapserver/mapwfslayer.c	2009-07-22 04:20:44 UTC (rev 9200)
@@ -1183,17 +1183,14 @@
     layer->vtable->LayerIsOpen = msWFSLayerIsOpen;
     layer->vtable->LayerWhichShapes = msWFSLayerWhichShapes;
     layer->vtable->LayerNextShape = msOGRLayerNextShape; /* yes, OGR */
+    layer->vtable->LayerResultsGetShape = msOGRLayerGetShape; /* yes, OGR but no special version, use ...GetShape() */
     layer->vtable->LayerGetShape = msOGRLayerGetShape; /* yes, OGR */
     layer->vtable->LayerClose = msWFSLayerClose;
     layer->vtable->LayerGetItems = msWFSLayerGetItems;
     layer->vtable->LayerGetExtent = msOGRLayerGetExtent; /* yes, OGR */
