[mapserver-commits] r9076 - sandbox/davidK
Wed Jun 3 18:04:10 EDT 2009
Author: davidK
Date: 2009-06-03 18:04:10 -0400 (Wed, 03 Jun 2009)
New Revision: 9076
   sandbox/davidK/mapoutput.c
Modified: sandbox/davidK/mapoutput.c
--- sandbox/davidK/mapoutput.c	2009-06-03 22:03:32 UTC (rev 9075)
+++ sandbox/davidK/mapoutput.c	2009-06-03 22:04:10 UTC (rev 9076)
@@ -30,6 +30,8 @@
 #include <assert.h>
 #include "mapserver.h"
+#include "mapkml.h"
 MS_CVSID("$Id$")
 static outputFormatObj *msAllocOutputFormat( mapObj *map, const char *name,
@@ -272,6 +274,18 @@
         format->r = msCreateRenderer(MS_RENDER_WITH_OGL);
 #endif
+	#if defined(USE_KML)
+    if( strcasecmp(driver,"KML") == 0 )
+        format = msAllocOutputFormat( map, "kml", driver );
+        format->mimetype = strdup("application/vnd.google-earth.kml+xml");
+        format->imagemode = MS_IMAGEMODE_RGB;
+        format->extension = strdup("kml");
+        format->renderer = MS_RENDER_WITH_KML;
+        format->r = msCreateRenderer(MS_RENDER_WITH_KML);
+#endif
@@ -1088,6 +1102,41 @@
         return r;
 #endif
+#ifdef USE_KML
+    case MS_RENDER_WITH_KML:
+		r->supports_transparent_layers = 1;
+		r->supports_pixel_buffer = 0;
+		r->supports_imagecache = 0;
+    	r->startNewLayer = msStartNewLayerKml;
+    	r->closeNewLayer = msCloseNewLayerKml;
+        r->renderLine=&msRenderLineKml;
+        r->createImage=&msCreateImageKml;
+        r->saveImage=&msSaveImageKml;
+        r->transformShape=&msTransformShapeKml;
+        r->renderPolygon=&msRenderPolygonKml;
+        r->renderGlyphs=&msRenderGlyphsKml;
+        r->renderEllipseSymbol = &msRenderEllipseSymbolKml;
+        r->renderVectorSymbol = &msRenderVectorSymbolKml;
+        r->renderPixmapSymbol = &msRenderPixmapSymbolKml;
+        r->mergeRasterBuffer = &msMergeRasterBufferKml;
+        r->getTruetypeTextBBox = &msGetTruetypeTextBBoxKml;
+        r->createPixmapSymbolTile = &msCreatePixmapSymbolTileKml;
+        r->createVectorSymbolTile = &msCreateVectorSymbolTileKml;
+        r->createEllipseSymbolTile = &msCreateEllipseSymbolTileKml;
+        r->createTruetypeSymbolTile = &msCreateTruetypeSymbolTileKml;
+        r->renderTile = &msRenderTileKml;
+        r->renderPolygonTiled = &msRenderPolygonTiledKml;
+        r->renderLineTiled = &msRenderLineTiledKml;
+        r->freeTile = &msFreeTileKml;
+        r->freeSymbol = &msFreeSymbolKml;
+        r->freeImage=&msFreeImageKml;
+        return r;
+#endif
     default:
         return NULL;
