[mapserver-commits] r9082 - trunk/docs/en/mapfile
Fri Jun 5 05:03:03 EDT 2009
Author: tbonfort
Date: 2009-06-05 05:03:03 -0400 (Fri, 05 Jun 2009)
New Revision: 9082
   trunk/docs/en/mapfile/style.txt
add centroid geomtransform
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2009-06-05 08:58:48 UTC (rev 9081)
+++ trunk/docs/en/mapfile/style.txt	2009-06-05 09:03:03 UTC (rev 9082)
@@ -70,12 +70,13 @@
       The associated RFC document for this feature is :ref:`RFC19`.
-GEOMTRANSFORM [start|end|vertices|bbox]
+GEOMTRANSFORM [start|end|vertices|bbox|centroid]
     - Used to indicate that the current feature will be transformed before the actual
       style is applied. Only applies to versions from 5.4
     - "bbox": uses the current style for rendering the bounding box of the underlying
       geometry
+    - "centroid": renders a marker at the centroid of the underlying shape.
     - "start" and "end": uses the current style to render a marker on the first or last
       vertex of the current geometry. When used with ANGLE AUTO, this can be used to
       render arrowheads or tails on line segments.
