[mapserver-commits] r9116 - sandbox/davidK
Sun Jun 21 19:08:13 EDT 2009
Author: davidK
Date: 2009-06-21 19:08:13 -0400 (Sun, 21 Jun 2009)
New Revision: 9116
   sandbox/davidK/mapkml.cpp
   sandbox/davidK/mapkmlrenderer.cpp
   sandbox/davidK/mapkmlrenderer.h
added support for symbol rendering
Modified: sandbox/davidK/mapkml.cpp
--- sandbox/davidK/mapkml.cpp	2009-06-21 18:47:46 UTC (rev 9115)
+++ sandbox/davidK/mapkml.cpp	2009-06-21 23:08:13 UTC (rev 9116)
@@ -76,6 +76,8 @@
 void msRenderPixmapSymbolKml(imageObj *img, double x, double y,
     	symbolObj *symbol, symbolStyleObj *style)
+	KmlRenderer* renderer = getKmlRenderer(img);
+	renderer->renderPixmapSymbol(img, x, y, symbol, style);
 void* msCreatePixmapSymbolTileKml(int width, int height,
Modified: sandbox/davidK/mapkmlrenderer.cpp
--- sandbox/davidK/mapkmlrenderer.cpp	2009-06-21 18:47:46 UTC (rev 9115)
+++ sandbox/davidK/mapkmlrenderer.cpp	2009-06-21 23:08:13 UTC (rev 9116)
@@ -9,7 +9,8 @@
 #define	LAYER_FOLDER_STYLE_URL	"#LayerFolder"
 KmlRenderer::KmlRenderer(int width, int height, colorObj* color/*=NULL*/)
-	:	XmlDoc(NULL), LayerNode(NULL), FirstLayer(true)
+	:	XmlDoc(NULL), LayerNode(NULL), FirstLayer(true), RasterizerOutputFormat(NULL),
+		UseInternalRasterizer(false)
 	//	Create document.
     XmlDoc = xmlNewDoc(BAD_CAST "1.0");
@@ -40,6 +41,9 @@
 		msFreeHashTable(StyleHashTable);
 	xmlCleanupParser();
+	if (RasterizerOutputFormat)
+		msFreeOutputFormat(RasterizerOutputFormat);
 imageObj* KmlRenderer::createImage(int width, int height, outputFormatObj *format, colorObj* bg)
@@ -159,12 +163,22 @@
 	if (FirstLayer)
+		FirstLayer = false;
 		if (layer->map->name)
 			xmlNewChild(DocNode, NULL, BAD_CAST "name", BAD_CAST layer->map->name);
 		// First rendered layer - check mapfile projection
 		checkProjection(&layer->map->projection);
-		FirstLayer = false;
+		for (int i=0; i<layer->map->numoutputformats; i++)
+			outputFormatObj *iFormat = layer->map->outputformatlist[i];
+			if(!strcasecmp(iFormat->driver,"cairo/png"))
+				RasterizerOutputFormat = msCloneOutputFormat(iFormat);
@@ -385,5 +399,139 @@
 		xmlNewChild(node, NULL, BAD_CAST "altitudeMode", BAD_CAST "clampToGround");
+void KmlRenderer::renderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style)
+		if (UseInternalRasterizer)
+		else
+			char *symbolUrl = lookupSymbolStyle(symbol, style);
+			xmlNodePtr placemarkNode = createPlacemarkNode(LayerNode, symbolUrl);
+			xmlNewChild(placemarkNode, NULL, BAD_CAST "name", NULL);
+			xmlNodePtr pointNode = xmlNewChild(placemarkNode, NULL, BAD_CAST "Point", NULL);
+			addAddRenderingSpecifications(pointNode);
+			pointObj pt;
+			pt.x = x; pt.y = y;
+			addCoordsNode(pointNode, &pt, 1);
+char* KmlRenderer::lookupSymbolStyle(symbolObj *symbol, symbolStyleObj *style)
+	<Style id="randomColorIcon">
+	  <IconStyle>
+		 <color>ff00ff00</color>
+		 <colorMode>random</colorMode>
+		 <scale>1.1</scale>
+		 <Icon>
+			<href>http://maps.google.com/mapfiles/kml/pal3/icon21.png</href>
+		 </Icon>
+	  </IconStyle>
+	</Style>
+	char styleName[128];
+	sprintf(styleName, "symbol_%s_%.1f", symbol->name, style->scale);
+	char *styleUrl = msLookupHashTable(StyleHashTable, styleName);
+	if (!styleUrl)
+		char styleValue[32];
+		sprintf(styleValue, "#%s", styleName);
+		hashObj *hash = msInsertHashTable(StyleHashTable, styleName, styleValue);
+		styleUrl = hash->data;
+		// Insert new IconStyle node into Document node
+		xmlNodePtr styleNode = xmlNewChild(DocNode, NULL, BAD_CAST "Style", NULL);
+		xmlNewProp(styleNode, BAD_CAST "id", BAD_CAST styleName);
+		xmlNodePtr iconStyleNode = xmlNewChild(styleNode, NULL, BAD_CAST "IconStyle", NULL);
+		char scale[16];
+		sprintf(scale, "%.1f", style->scale);
+		xmlNewChild(iconStyleNode, NULL, BAD_CAST "scale", BAD_CAST scale);
+		char iconFileName[512];
+		sprintf(iconFileName, "symbol_%s_%.1f", symbol->name, style->scale); // __TODO__ add WEB IMAGEURL path
+		if (createIconImage(iconFileName, symbol, style) != MS_SUCCESS)
+			char errMsg[512];
+			sprintf(errMsg, "Error creating icon file '%s'", iconFileName);
+			msSetError(MS_IOERR, errMsg, "KmlRenderer::lookupSymbolStyle()" );
+			return NULL;
+		xmlNodePtr iconNode = xmlNewChild(iconStyleNode, NULL, BAD_CAST "Icon", NULL);
+		xmlNewChild(iconNode, NULL, BAD_CAST "href", BAD_CAST iconFileName);
+	return styleUrl;
+int KmlRenderer::createIconImage(char *fileName, symbolObj *symbol, symbolStyleObj *style)
+	// internal renderer used for rasterizing
+	renderObj *r = RasterizerOutputFormat->r;
+	RasterizerOutputFormat->imagemode = MS_IMAGEMODE_RGBA;
+	imageObj *tmpImg = r->createImage(symbol->sizex, symbol->sizey, RasterizerOutputFormat, NULL);
+	double scale = style->scale; // save symbol scale
+	style->scale = 1.0; // render symbol in default size
+	double cx = symbol->sizex / 2;
+	double cy = symbol->sizey / 2;
+	switch(symbol->type)
+		case (MS_SYMBOL_TRUETYPE):
+			r->renderTruetypeSymbol(tmpImg, cx, cy, symbol, style);
+			break;
+		case (MS_SYMBOL_PIXMAP):
+			r->renderPixmapSymbol(tmpImg, cx, cy, symbol, style);
+			break;
+		case (MS_SYMBOL_ELLIPSE):
+			r->renderEllipseSymbol(tmpImg, cx, cy, symbol, style);
+			break;
+		case (MS_SYMBOL_VECTOR):
+			r->renderVectorSymbol(tmpImg, cx, cy, symbol, style);
+			break;
+		default:
+			break;
+	style->scale = scale; // restore symbol scale
+	FILE *fOut = fopen(fileName, "wb");
+	if (!fOut)
+		return MS_FAILURE;
+	tmpImg->format = RasterizerOutputFormat;
+	int status = MS_FAILURE;
+    if(r->supports_pixel_buffer)
+        rasterBufferObj data;
+        r->getRasterBuffer(tmpImg,&data);
+        status = msSaveRasterBuffer(&data, fOut, RasterizerOutputFormat );
+	else
+        status = r->saveImage(tmpImg, fOut, RasterizerOutputFormat);
+	fclose(fOut);
+	return status;
 #endif
\ No newline at end of file
Modified: sandbox/davidK/mapkmlrenderer.h
--- sandbox/davidK/mapkmlrenderer.h	2009-06-21 18:47:46 UTC (rev 9115)
+++ sandbox/davidK/mapkmlrenderer.h	2009-06-21 23:08:13 UTC (rev 9116)
@@ -23,6 +23,12 @@
 	int			FirstLayer;
+	// internal output format containing cairo renderer used for rasterizing and rendering symbols
+	outputFormatObj	*RasterizerOutputFormat;
+	// true - features are rasterized, false - features are written directly in kml
+	int			UseInternalRasterizer;
 	enum altitudeModeEnum { undefined, clampToGround, relativeToGround, absolute };
 protected:
@@ -33,6 +39,8 @@
 	char* lookupLineStyle(strokeStyleObj *strokeStyle);
 	char* lookupPolyStyle(colorObj *color);
+	char* lookupSymbolStyle(symbolObj *symbol, symbolStyleObj *style);
 	void addCoordsNode(xmlNodePtr parentNode, pointObj *pts, int numPts);
 	void setupRenderingParams(hashTableObj *layerMetadata);
@@ -40,6 +48,8 @@
 	int checkProjection(projectionObj *projection);
+	int createIconImage(char *fileName, symbolObj *symbol, symbolStyleObj *style);
 public:
 	KmlRenderer(int width, int height, colorObj* color = NULL);
@@ -57,6 +67,8 @@
 	void renderGlyphs(imageObj *img, double x, double y, labelStyleObj *style, char *text);
+	void renderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj *style);
 	int getTruetypeTextBBox(imageObj *img,char *font, double size, char *string,
 		rectObj *rect, double **advances);
