[mapserver-commits] r8661 - sandbox/graphics
Sun Mar 8 11:39:41 EDT 2009
Author: tbonfort
Date: 2009-03-08 11:39:41 -0400 (Sun, 08 Mar 2009)
New Revision: 8661
   sandbox/graphics/README.CONFIGURE
add notes on cairo configuration options
Modified: sandbox/graphics/README.CONFIGURE
--- sandbox/graphics/README.CONFIGURE	2009-03-08 15:31:31 UTC (rev 8660)
+++ sandbox/graphics/README.CONFIGURE	2009-03-08 15:39:41 UTC (rev 8661)
@@ -86,6 +86,7 @@
   --without-pdf           Disable PDF support.
   --with-pdf[=DIR]        Include PDF support (DIR is PDFlib's install dir).
   --with-agg[=DIR]        Include AGG support (DIR is AGG's install dir).
+  --with-cairo            Include Cairo support (PDF and SVG support)
   --without-eppl          Disable EPPL7 support.
   --with-eppl             Include EPPL7 support.
   --with-proj[=DIR]       Include PROJ.4 support (DIR is PROJ.4's install dir).
@@ -479,6 +480,18 @@
 system verison of libpng and zlib.
+CAIRO Support:
+  --without-cairo         Disable Cairo support (default)
+  --with-cairo[=/path/to/cairo.pc] Enable Cairo Support
+- Cairo support is required for PDF or SVG output
+- pkg-config is used to obtain the compilation options for cairo. If your
+  libs and headers are installed in a non-standard location, you can pass
+  the full path to the cairo.pc configuration package
 OGC WMS Server Compatibility:
