[mapserver-commits] r8665 - trunk/docs/development/rfc
Sun Mar 8 13:59:34 EDT 2009
Author: sdlime
Date: 2009-03-08 13:59:33 -0400 (Sun, 08 Mar 2009)
New Revision: 8665
   trunk/docs/development/rfc/ms-rfc-52.txt
Updated version of single-pass querying RFC.
Modified: trunk/docs/development/rfc/ms-rfc-52.txt
--- trunk/docs/development/rfc/ms-rfc-52.txt	2009-03-08 16:01:32 UTC (rev 8664)
+++ trunk/docs/development/rfc/ms-rfc-52.txt	2009-03-08 17:59:33 UTC (rev 8665)
@@ -5,6 +5,7 @@
 :Authors: Steve Lime
 :Contact: sdlime at comcast.net
 :Last Edited: 2009/03/08
+:Status: Draft
 :Version: MapServer 6.0
 :Id:
@@ -27,13 +28,13 @@
 could be retained. However, even moderately sized result sets could consume
 loads of system memory and this approach is impractical for very large data
 sets. One *could* apply limits on the number features allowed in the cache
-and fall back to the two-pass approach if necessary. However, that doesn't
+and fall back to the two-pass approach if necessary. However, this doesn't
 help the worst case scenarios where the two-pass performance penalty is the
 greatest.
-Another approach would be to integrate the processing done by the query
-functions into the mainstream feature retrieval system already in place for
-drawing and querying (e.g. msLayerWhichShapes() and msLayerNextShape()). The
+Another more performant approach would be to integrate the processing done by
+the query functions into the mainstream feature retrieval system already in place
+for drawing and querying (e.g. msLayerWhichShapes() and msLayerNextShape()). The
 current query functions basically just operate before or after those functions
 anyway. For example, msQueryByAttributes() alters a layer's FILTER before
 calling msLayerWhichShapes(). All of the query functions so some post processing
@@ -55,13 +56,80 @@
   typedef struct {
     int type; /* one of a number of enumerated query types */
+    rectObj extent;
     char **layers; /* these mimic the qxxxxxx CGI arguments used for querying */
     char *string;
     char *item;
+    char *slayer;
     featureListNodeObjPtr shape, currentshape; /* for querying by shape or other layer */
-    double mindist;
   } queryObj;
-Query presentation code would simply
\ No newline at end of file
+Query presentation code would simply open a layer, pass a query object to
+msLayerWhichShapes() and then do msLayerNextShape() repeatedly.
+Backwards Compatability Issues
+The current two-pass system actually does present certain advantages and may be
+difficult to overcome with the second techincal solution.
+1. We know if a query was successful or not *before* presentation takes place
+and can throw an error (e.g. using the EMPTY in the webObj) easily. While we
+still will know if a query returned no results, but we may be well into
+presentation by that time and will need new ways to deal with this. The EMPTY
+parameter would probably become obsolete. Essentionally no results would not
+be an error condition- perhaps a good thing.
+2. Since the number of results found in each layer after the first pass is known
+we populate a number of counter variables (e.g. total number of results) that
+are accessible via template tags. While the counters would still work as normal
+the totals would not be available. There are workarounds in some cases but not
+in others.
+3. One of the most useful MapServer query modes is QUERY which finds the closest
+feature across one or more layers. It's the "more" that is problematic. The
+functions msLayerWhichShapes() and msLayerNextShapes() operate on a single layer
+while this particular query operates across layers. This type of query would have
+to be handled as a special case through a msFindClosestFeature() function.
+4. The FEATUREQUERY modes in MapServer will provide a challenge. These are essentially
+two queries done one after the other. Features from one layer are used to select
+features from another (e.g. find all lakes within a county). This cannot be done
+using a single msLayerWhichShapes() and msLayerNextShapes() iteration so we'd need
+a function to move features from the initial query into a second queryObj for the
+second. Special consideration would be necessary in template processing to optionally
+output the selection features.
+5. MapScript access to query functions. Presently, the various MapScript query
+methods are simply wrappers for the corresponding C function. Since the C functions
+essentionally go away this interface will undoubtedly need to change. We can
+preserve the methods (they would just set queryObj members, perhaps more), but the
+access to results would change. A typical usage would be:
+  # do the query
+  $layer->queryByShape(...); # should open the layer(s) and call msLayerWhichShapes()
+  while($shape = $layer->nextShape()) {
+    # do something with it
+  $layer->close();
+I would propose adding a new method to handle the "closest" case that would just
+return a shapeObj (no more MS_SINGLE or MS_MULTIPLE).
+Files Impacted
+* mapserver.h: new queryObj, new enumeration, various fuctions coming and going
+* maplayer.c: additions to msLayerWhichShapes(), msLayerNextShapes()
+* maptemplate.c: refatoring of code to process tempates (2 places)
+* mapgml.c: refactoring of code to output GML 2 & 3
+* mapquery.c: pretty much a complete gutting
+* mapdraw.c: refactoring of code that deals with drawing a querymap
