[mapserver-commits] r8679 - trunk/docs/tutorial
Sun Mar 8 16:49:13 EDT 2009
Author: jmckenna
Date: 2009-03-08 16:49:13 -0400 (Sun, 08 Mar 2009)
New Revision: 8679
Added:
   trunk/docs/tutorial/background.txt
   trunk/docs/tutorial/index.txt
add beginnings of tutorial rst files
Added: trunk/docs/tutorial/background.txt
--- trunk/docs/tutorial/background.txt	                        (rev 0)
+++ trunk/docs/tutorial/background.txt	2009-03-08 20:49:13 UTC (rev 8679)
@@ -0,0 +1,109 @@
+.. _background:
+Tutorial Timeframe
+While some users can go through this tutorial in one day, those who work on each
+example in detail can probably expect to finish in one week.
+<top>
+Tutorial Data
+The dataset used in this tutorial was taken from the U.S. Department of the
+Interior's National Atlas of the United States. You can visit their web site
+at http://www.nationalatlas.gov. The dataset was clipped to the upper great
+lakes region (Minnesota, Michigan, and Wisconsin) to reduce storage size.
+Additional raster images were added courtesy of the TerraSIP project at the
+University of Minnesota. When using this tutorial, you are encouraged to use
+your own dataset.
+Like MapServer itself, this tutorial is open and customizable to anyone.
+This was done in the hope that someone (or some folks) will help design and
+develop it further.
+Before Using the Tutorial
+There are some prerequisites to using this tutorial:
+1. Users will need to have a web server installed and running on your computer.
+   This web server has to have support for common gateway interface (CGI) programs.
+2. Users should have a basic understanding of web servers and internet security.
+   A poorly configured web server can easily be attacked by malicious people.
+   At the very least your software installation will be corrupted and you'll
+   lose hours of productivity, at worst your computer can be used to attack
+   other computers on the internet.
+3. It is recommended that users of this tutorial read the
+   :ref:`Introduction to MapServer <introduction>` before proceeding with this
+   tutorial.
+4. To use this tutorial, users will need to have a web server and a MapServer
+   CGI program (mapserv or mapserv.exe) installed in their systems. MapServer
+   source code is available for download :ref:`here <download>`. Documentation
+   exists on how to compile and install MapServer:
+   * for UNIX users, please read the :ref:`MapServer UNIX Compilation and Installation HOWTO <unix>`.
+   * Windows users should read the :ref:`MapServer Win32 Compilation and Installation HOWTO <win32>`
+   In addition, Windows users can also download precompiled binaries from
+   :ref:`here <download>`.
+Windows, UNIX/Linux Issues
+Paths
+This tutorial was created in Linux/UNIX but should work with minimal changes on
+Windows platform. The main differences are the paths in the map files. Windows
+users need to specify the drive letter of the hard disk where their tutorial
+files reside. Here's an example:
+A UNIX map file might include a parameter like this:
+  .. code-block:: mapfile
+     SHAPEPATH "/data/projects/tutorial/data"
+In Windows, the same parameters might look like this:
+     SHAPEPATH "C:/data/projects/tutorial/data"
+or:
+     SHAPEPATH "C:\data\projects\tutorial\data".
+Notice that either slash or backslash works in Windows. The usual backslash may
+work well for you if you want to make a distinction between virtual (as in URLs
+or web addresses) and local paths in your map file. However, if you plan to move
+your application to UNIX at some point, you'll have the tedious task of switching
+all backslashes to slashes.
+While we're on the subject of paths, keep in mind that paths in mapfiles are
+typically relative to the system's root directory: the slash ("/") in UNIX or
+some drive letter ("C:") in Windows. This is true except when specifically asked
+to enter a URL or when referencing a URL. When working with HTML template files,
+paths are relative to the web server's root directory.  i.e., "/projects/tutorial35/"
+is relative to "http://terrasip.gis.umn.edu/". Please read
+http://www.alistapart.com/stories/slashforward/ for a few insights on URLs.
+Executable
+Another issue is that UNIX executable files don't require a .EXE or .COM extensions, but
+they do in Windows. If you are using Windows, append .exe to all instances of
+"/cgi-bin/mapserv" or "/cgi-bin/mapserv50" to make it "/cgi-bin/mapserv.exe" or
+"/cgi-bin/mapserv50.exe".
+Other Resources
+Other documentation exist to give you better understanding of the many customizations
+MapServer offer. Please visit the MapServer documentation page at
+http://www.mapserver.org. There you will find several HOWTO documents, from getting
+started to using MapScript, a scripting interface for MapServer.
\ No newline at end of file
Added: trunk/docs/tutorial/index.txt
--- trunk/docs/tutorial/index.txt	                        (rev 0)
+++ trunk/docs/tutorial/index.txt	2009-03-08 20:49:13 UTC (rev 8679)
@@ -0,0 +1,30 @@
+.. _tutorial:
+ MapServer Tutorial
+:Author: Pericles S. Nacionales
+:Contact: pnaciona at gmail.com
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
+:Revision: $Revision: 8577 $
+:Date: $Date: 2009-02-18 11:38:50 -0500 (Wed, 18 Feb 2009) $
+This tutorial was designed to give new users a quick (relatively speaking)
+introduction to the concepts behind MapServer. It is arranged into four sections
+with each section having one or more examples and increasing in complexity.
+Users can jump to any section at any time although it is recommended that
+absolute beginners work on the first three sections sequentially.
+Section one focuses on basic MapServer configuration concepts such as layer
+and class ordering, using vector and raster data, projections and labeling.
+Section two provides examples on how to use HTML templates to create a simple
+interface for an interactive web mapping application. Section three introduces
+the use of HTML templates to provide a "query" interface. Finally, section four
+introduces some advanced user interface concepts.
+.. toctree::
+   :maxdepth: 1
+   background
