[mapserver-commits] r8692 - trunk/docs/tutorial
Mon Mar 9 09:58:35 EDT 2009
Author: pnaciona
Date: 2009-03-09 09:58:35 -0400 (Mon, 09 Mar 2009)
New Revision: 8692
Added:
   trunk/docs/tutorial/section2.html
Add tutorial section 2
Added: trunk/docs/tutorial/section2.html
--- trunk/docs/tutorial/section2.html	                        (rev 0)
+++ trunk/docs/tutorial/section2.html	2009-03-09 13:58:35 UTC (rev 8692)
@@ -0,0 +1,121 @@
+<html>
+  <head>
+    <title>MapServer 5.x Tutorial</title>
+    <link type="text/css" rel="stylesheet" href="ms35.css" />
+  </head>
+  <body bgcolor="#ffffff">
+    <table align="center" width="600" border="0">
+      <tr>
+        <td>
+          <h1 align="center">MapServer 5.x Tutorial</h1>
+          <h3 align="center">
+            Section 2: CGI variables and the User Interface
+          </h3>
+          <p>So far we have only looked at the mapfile when creating maps. In
+            creating web mapping applications, it is usually our intention to
+            make maps that can be changed by the user (of the application)
+            interactively. That is, a user should be able to change the content
+            of (or the information in) the map. To accomplish this interactivity,
+            we use the MapServer HTML templates.
+          </p>
+          <p>A MapServer HTML template is essentially an HTML file with a few
+            MapServer specific tags--these tags are the MapServer CGI variables
+            band are enclosed in square brackets "[]".  When the MapServer CGI
+            program processes an application, it first parses the query_string
+            and the mapfile and produces the necessary output. Some of this
+            output will need to be written to the HTML template file which you
+            would have to also specify in the mapfile using the web template
+            keyword (or in a separate HTML initialization file). The CGI program
+            will replace all the variables in the HTML template with the proper
+            value before sending it back to the web browser. If you are to
+            directly view an HTML template on a web browser, there won't be any
+            maps rendered and you will instead get blank images and other junk.
+          </p>
+          <p>MapServer provides several variables for web mapping--the "img"
+            variable which you've seen in Example 1.9 is but one example.  There
+            area few core CGI variables originally designed as part of the
+            mapping interface but practically all the mapfile parameters can be
+            defined as variables. The definitive reference to the CGI variables
+            can be found at
+            <a href="http://mapserver.gis.umn.edu/doc/cgi-reference.html">
+              http://mapserver.gis.umn.edu/doc/cgi-reference.html</a>.
+          </p>
+          <p>We can also define our own variable--MapServer will pass it
+            along to our application.  For example, we can create a variable
+            called "root" to represent the root directory of this tutorial--the
+            value for "root" will then be "/tutorial". When the MapServer CGI
+            program processes our HTML template, it will replace every instance
+            of he "[root]" tag with "/tutorial".  You will see this in action for
+            each of the following examples.
+          </p>
+          <p>So, let's build an interactive interface for our application...</p>
+          <p>Users of a web mapping application should be able to pan and zoom on
+            the map...<br>
+            <a
+             href="/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-1.html">Example 2.1 - Pan and Zoom Controls</a>
+          </p>
+          <p>... they also should be able to turn on and off layers on a map.<br>
+            <a
+              href="/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-2.html">
+              Example 2.2 - Layer Control
+            </a>
+          </p>
+          <p>A map should always include a scalebar.<br>
+            <a
+              href="/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-3.html">
+              Example 2.3 - Adding a Scalebar</a><br>
+          </p>
+          <p>If users are to navigate through the map, a reference map should be
+            provided.<br>
+            <a
+              href="/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-4.html"> Example 2.4 - Adding a Reference Map</a><br>
+          </p>
+          <p>And like any good maps, it should include a legend.<br>
+            <a
+              href="/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example2.map&layer=states&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web=template+example2-5.html">
+              Example 2.5- Adding a Legend</a>
+          </p>
+          <form method="get" action="/cgi-bin/mapserv.exe">
+            <!-- The following two variables are user defined variables.
+                 MapServer will pass its value to the HTML template if the
+                 proper tags are found, in square brackets "[]"  -->
+            <input type="hidden" name="root" value="/tutorial">
+            <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
+            <!-- The map and layer variables are internal MapServer variables.
+                 They are required by the mapping application. -->
+            <input type="hidden" name="map" value="/ms4w/apps/tutorial/htdocs/example2.map">
+            <input type="hidden" name="layer" value="states">
+            <input type="hidden" name="zoom" value="0">
+            Proceed to:
+            <!-- The map_web_template variable will replace the TEMPLATE
+                 parameter in the WEB object of the MAP file... -->
+            <select name="map_web">
+              <option value="template example2-1.html">
+                Example 2.1: Pan & Zoom Controls
+              </option>
+              <option value="template example2-2.html">
+                Example 2.2: Layer Control
+              </option>
+              <option value="template example2-3.html">
+                Example 2.3: Scalebar
+              </option>
+              <option value="template example2-4.html">
+                Example 2.4: Reference Map
+              </option>
+              <option value="template example2-5.html">
+                Example 2.5: Legend
+              </option>
+            </select> &nbsp;
+            <input type="submit" name="submit" value="Go there!">
+          </form>
+          <hr size="1">
+          <p class="Small" align="center">
+            <a href="sections.html">Back to Sections Page</a> |
+            <a href="section1.html">Back to Section 1</a> |
+            <a href="section3.html">Go to Section 3</a>
+          </p>
+        </td>
+      </tr>
+    </table>
+  </body>
+</html>
