[mapserver-commits] r8696 - trunk/docs/tutorial
Mon Mar 9 10:15:03 EDT 2009
Author: pnaciona
Date: 2009-03-09 10:15:03 -0400 (Mon, 09 Mar 2009)
New Revision: 8696
   trunk/docs/tutorial/example1-3.txt
update tutorial example 1.3
Modified: trunk/docs/tutorial/example1-3.txt
--- trunk/docs/tutorial/example1-3.txt	2009-03-09 14:13:46 UTC (rev 8695)
+++ trunk/docs/tutorial/example1-3.txt	2009-03-09 14:15:03 UTC (rev 8696)
@@ -11,7 +11,7 @@
 .. image:: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-3.map&layer=states_poly&layer=states_line&mode=map
-This is what the mapfile looks like: `<http://biometry.gis.umn.edu/tutorial/example1-3.map>`_.
+This is what the mapfile looks like: `Example1-3.map <http://biometry.gis.umn.edu/tutorial/example1-3.map>`_.
 The mapfile structure, by objects, looks like this:
@@ -44,8 +44,7 @@
 **EXPRESSION**
           For each class, we specify what attribute value to use. This is the
-          simplest form of EXPRESSION. EXPRESSIONs can be even more complex than
+          simplest form of EXPRESSION. EXPRESSIONs can be even more complex than
           this, allowing one to evaluate regular or logical expressions. Please
           look at the mapfile reference page to see what you can do
           with EXPRESSION.
\ No newline at end of file
