[mapserver-commits] r8705 - trunk/docs/tutorial
Mon Mar 9 12:09:20 EDT 2009
Author: jmckenna
Date: 2009-03-09 12:09:20 -0400 (Mon, 09 Mar 2009)
New Revision: 8705
Added:
   trunk/docs/tutorial/example1-5.txt
add raster tutorial page
Added: trunk/docs/tutorial/example1-5.txt
--- trunk/docs/tutorial/example1-5.txt	                        (rev 0)
+++ trunk/docs/tutorial/example1-5.txt	2009-03-09 16:09:20 UTC (rev 8705)
@@ -0,0 +1,140 @@
+.. _example1-5:
+Example 1.5
+Adding a Raster Layer
+.. image:: http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-5.map&layer=states&layer=states_line&layer=states_label&layer=modis&mode=map
+In addition to vector data support (point, lines, polygons, and annotations),
+MapServer can also display raster data. Through the use of GDAL library, MapServer
+can input and output multiple raster formats. Whereas in versions prior to 4.x raster
+input is limited to single layer, grayscale or indexed color images, recent MapServer
+versions support RGB and multispectral (multi-layer) images. This example shows how to
+select what layers to display when using multispectral data.
+.. note::
+     There might be a noticeable performance hit when using RGB and multispectral images.
+Because MapServer 5.x uses GD version 2.0.x library to generate output images, it
+supports RGB (24-bit or true color) output as well. So, along with 8-bit (indexed
+color or grayscale) PNG, you can now also use PNG24 (true color) for output. This
+example uses PNG24 as IMAGETYPE.
+.. note::
+     As with RGB input, there might be a noticeable performance hit when using PNG24.
+MapServer can actually use GDAL to generate output images as well, but that's another
+topic. If you want to know more about it, look at the :ref:`OUTPUTFORMAT <outputformat>`
+object in the mapfile reference.
+MapFile
+This is what the mapfile looks like: :ref:`Example1-5.map <example1-5-map>`
+The mapfile structure, by objects, looks like this:
+                                               MAP
+               LAYER #1-------------LAYER #2----|----LAYER #3--------LAYER #4
+            (states_poly)           (modis)       (states_line)   (states_label)
+  (land) CLASS-|-CLASS (water)                       |-CLASS         |-CLASS
+       STYLE-|   |-STYLE                               |-STYLE     STYLE-|-LABEL
+When you look at the mapfile, you'll see that the new LAYER object is added below
+(after) the state POLYGON layer. Why? MapServer displays layers in reverse order:
+last in, first out (LIFO). The first layer defined in the mapfile is drawn at
+the bottom of the map.
+So, if we have drawn the state POLYGON layer, it would be on the bottom. Since the
+raster layer gets drawn on top of it, we won't see it. That's why the first layer
+gets the STATUS value of OFF. The state LINE layer is defined below the raster
+layer so it gets drawn on top (and you can see it). This is why we separated the
+state LINE layer from the state POLYGON layer. Of course the labels get drawn
+on top of everything.
+MapServer can automatically turn layers on or off based on the status of other
+layers (say you want the states polygon layer turned off when the raster layer
+is turned on). This is done by using the REQUIRES parameter. Keep this in
+mind as you might want to use it once you start creating your own MapServer
+applications.
+Parameters
+Let's have a look at the new parameters introduced in the mapfile:
+**IMAGETYPE**
+  This is not new but the value "PNG24" is. PNG24 is the 24-bit or true-color
+  version of the PNG format. Instead of being limited to 256 color combinations
+  for our output image, MapServer now have millions. By the way, try changing
+  this value back to PNG. Notice the time it takes to generate the image using
+  either formats. In choosing between true color and indexed color, take into
+  account the time it takes to generate the image.
+**SYMBOLSET**
+  Points to the path of the symbol definition file. The symbols in this file
+  are referenced by the SYMBOL parameter in the :ref:`CLASS <class>` object.
+  It's not really needed at this point but I thought I'd throw this here now.
+  Please refer to the :ref:`Cartographic Symbol Reference <sym_construction>`
+  for further information.
+**DATA raster/mod09a12003161_ugl_ll_8bit.tif**
+  In the newly added LAYER object, the DATA parameter points to a GeoTIFF image.
+  Like vector datasets, MapServer supports multiple raster file formats. This
+  support is accomplished through use of the GDAL library. For more information
+  on the different raster formats supported by MapServer and for general
+  discussion on the use of rasters in MapServer, please read the
+  :ref:`Raster Data Reference <raster>`.
+**TYPE RASTER**
+  When using raster data (images) we use the value RASTER for the parameter
+  TYPE, as opposed to the POLYGON, LINE, and POINT values for vector data and
+  ANNOTATION for label IDs.
+**PROCESSING "BANDS=1,2,3"**
+  This LAYER object parameter was added in MapServer 4.x. The
+  :ref:<PROCESSING> keyword has many values but in this case we are using it to
+  select which bands in a multispectral image to display. The values here are
+  strings that will be passed to the GDAL library.
+**OFFSITE**
+  This parameter tells MapServer what pixel values to render as background
+  (or ignore). You can get the pixel values using image processing or image
+  manipulation programs (i.e. Imagine, Photoshop, Gimp).
+RGB vs Indexed Color Image
+To compare map creation speed when using RGB image as opposed to indexed color
+image, replace the following lines in the mapfile:
+.. code-block:: mapfile
+  DATA "raster/mod09a12003161_ugl_ll_8bit.tif"
+  STATUS DEFAULT
+  TYPE RASTER
+  PROCESSING "BANDS=1,2,3"
+  OFFSITE 71 74 65
+with these:
+  DATA "raster/mod09a12003161_ugl_ll_idxa.tif"
+  STATUS DEFAULT
+  TYPE RASTER
+  OFFSITE 70 74 66
+Also, try changing the IMAGETYPE from PNG24 to PNG.
\ No newline at end of file
