[mapserver-commits] r8707 - trunk/docs/tutorial
Mon Mar 9 13:12:56 EDT 2009
Author: pnaciona
Date: 2009-03-09 13:12:56 -0400 (Mon, 09 Mar 2009)
New Revision: 8707
   trunk/docs/tutorial/section1.txt
updated tutorial section 1... fixed links
Modified: trunk/docs/tutorial/section1.txt
--- trunk/docs/tutorial/section1.txt	2009-03-09 16:12:10 UTC (rev 8706)
+++ trunk/docs/tutorial/section1.txt	2009-03-09 17:12:56 UTC (rev 8707)
@@ -4,10 +4,10 @@
 - Take a shapefile. Any shapefile. We can use MapServer to display that shapefile on a web browser. Look...
-    - :ref:`Example 1.1 - A map with a single layer <example1-1>`
+    - :ref:`Example 1.1 - A map with a single layer <example1-1>`
 - We can display the same shapefile repeatedly. We can display the polygon attributes on one LAYER and and the line attributes on another...
-    - :ref:`Example 1.2 - A map with two layers <example1-2>`
+    - :ref:`Example 1.2 - A map with two layers <example1-2>`
 - And we can select which parts of the shapefile to display. We do this using the CLASS object...
     - :ref:`Example 1.3 - Using classes to make a "useful" map <example1-3>`
@@ -16,16 +16,16 @@
     - :ref:`Example 1.4 - Labeling layers and label layers <example1-4>`
 - Or add raster data such as satellite images, aerial photographs, or shaded reliefs...
-    - :ref:`Example 1.5- Adding a raster layer <example1-5>`
+    - :ref:`Example 1.5 - Adding a raster layer <example1-5>`
 - We can reproject our data from just about any projection to just about any... Yeah, check it out!
     - :ref:`Example 1.6 - Projection/Reprojection <example1-6`
 - And we can use layers from other map servers on the internet (as long as they are WMS servers)...
-    - :ref:`Example 1.7- Adding a WMS layer <example1-7>`
+    - :ref:`Example 1.7 - Adding a WMS layer <example1-7>`
 - MapServer can output to various formats such as PDF and GeoTIFF.
     - :ref:`Example 1.8 - A different output format <example1-8>`
 - MapServer not only generates static maps, it can also create interactive maps...
-    - :ref:`Example 1.9- The difference between map and browse mode <example1-9>`
\ No newline at end of file
+    - :ref:`Example 1.9 - The difference between map and browse mode <example1-9>`
