[mapserver-commits] r8721 - trunk/mapserver
Mon Mar 9 15:09:55 EDT 2009
Author: aboudreault
Date: 2009-03-09 15:09:55 -0400 (Mon, 09 Mar 2009)
New Revision: 8721
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/configure
   trunk/mapserver/configure.in
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapdraw.c
   trunk/mapserver/mapgd.c
   trunk/mapserver/mapimagemap.c
   trunk/mapserver/maplegend.c
   trunk/mapserver/mappdf.c
   trunk/mapserver/mapresample.c
   trunk/mapserver/mapscale.c
   trunk/mapserver/mapserv.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapswf.c
   trunk/mapserver/maputil.c
   trunk/mapserver/mapwcs.c
Added resolution writing in image files (#2891)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/HISTORY.TXT	2009-03-09 19:09:55 UTC (rev 8721)
@@ -11,6 +11,9 @@
 Current Version (SVN trunk):
+- Added resolution writing in image files (#2891)
 - Refactor legend icon drawing (remove renderer specific versions)
   Add label styling or markers for annotation layer legend icons (#2917)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/configure	2009-03-09 19:09:55 UTC (rev 8721)
@@ -7403,6 +7403,79 @@
      GD_DEF="$GD_DEF -DUSE_GD_FT"
   fi
+    GD_RESOLUTION_SUPPORT=no
+  as_ac_Lib=`echo "ac_cv_lib_$GD_CHECKLIB''_gdImageSetResolution" | $as_tr_sh`
+{ echo "$as_me:$LINENO: checking for gdImageSetResolution in -l$GD_CHECKLIB" >&5
+echo $ECHO_N "checking for gdImageSetResolution in -l$GD_CHECKLIB... $ECHO_C" >&6; }
+if { as_var=$as_ac_Lib; eval "test \"\${$as_var+set}\" = set"; }; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-l$GD_CHECKLIB $GD_STATIC $GD_LIB $GD_XTRA_LIBS $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Override any GCC internal prototype to avoid an error.
+   Use char because int might match the return type of a GCC
+   builtin and then its argument prototype would still apply.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+char gdImageSetResolution ();
+int
+main ()
+return gdImageSetResolution ();
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (ac_try="$ac_link"
+case "(($ac_try" in
+  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+  *) ac_try_echo=$ac_try;;
+esac
+eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5
+  (eval "$ac_link") 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } && {
+	 test -z "$ac_c_werror_flag" ||
+	 test ! -s conftest.err
+       } && test -s conftest$ac_exeext &&
+       $as_test_x conftest$ac_exeext; then
+  eval "$as_ac_Lib=yes"
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+	eval "$as_ac_Lib=no"
+fi
+rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
+      conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+ac_res=`eval echo '${'$as_ac_Lib'}'`
+	       { echo "$as_me:$LINENO: result: $ac_res" >&5
+echo "${ECHO_T}$ac_res" >&6; }
+if test `eval echo '${'$as_ac_Lib'}'` = yes; then
+  GD_RESOLUTION_SUPPORT=yes
+fi
+  if test "$GD_RESOLUTION_SUPPORT" = "yes"; then
+     GD_DEF="$GD_DEF -DUSE_GD_RESOLUTION"
+  fi
     as_ac_Lib=`echo "ac_cv_lib_$GD_CHECKLIB''_gdImageOpenPolygon" | $as_tr_sh`
 { echo "$as_me:$LINENO: checking for gdImageOpenPolygon in -l$GD_CHECKLIB" >&5
 echo $ECHO_N "checking for gdImageOpenPolygon in -l$GD_CHECKLIB... $ECHO_C" >&6; }
@@ -8209,6 +8282,79 @@
 fi
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+esac
+  ac_status=$?
+else
+fi
+fi
+fi
+  fi
   if test -n "$GD_DEF" ; then
       GD_LIB="-lgd $GD_LIB"
       { echo "$as_me:$LINENO: result:         using GD ($GD_DEF) from system libs." >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/configure.in	2009-03-09 19:09:55 UTC (rev 8721)
@@ -649,6 +649,14 @@
   fi
+  dnl check for Resolution support
+  AC_CHECK_LIB($GD_CHECKLIB, gdImageSetResolution, GD_RESOLUTION_SUPPORT=yes,, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
+  fi
   dnl check for gdImageOpenPolygon (means GD version 2.0.29 or higher)
   AC_CHECK_LIB($GD_CHECKLIB, gdImageOpenPolygon, GD_DEF="$GD_DEF -DGD_HAS_FTEX_XSHOW",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
@@ -692,6 +700,14 @@
   dnl getter functions.
   AC_CHECK_LIB(gd, gdFontGetTiny, GD_DEF="$GD_DEF -DGD_HAS_GETBITMAPFONTS",, $GD_LIB $GD_XTRA_LIBS)
+  fi
       AC_MSG_RESULT([        using GD ($GD_DEF) from system libs.])
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapagg.cpp	2009-03-09 19:09:55 UTC (rev 8721)
@@ -871,7 +871,7 @@
 // Returns a pointer to a newly created imageObj structure.
 // a pointer to the AGG renderer is stored in the imageObj, used for caching
-imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl)
+imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution)
     imageObj *pNewImage = NULL;
@@ -880,7 +880,7 @@
       return NULL;
-    pNewImage = msImageCreateGD(width, height, format, imagepath, imageurl);
+    pNewImage = msImageCreateGD(width, height, format, imagepath, imageurl, resolution);
     if(!pNewImage)
       return pNewImage;
@@ -916,6 +916,10 @@
         agg::rgba8 bc = getAGGColor(background,100);
         ren->clear(bc);
+#ifdef USE_GD_RESOLUTION
+   /* Set the resolution */
+    gdImageSetResolution(image->img.gd, image->resolution, image->resolution);
+#endif
     image->buffer_format=MS_RENDER_WITH_AGG;
     msImageInitGD(image, background);
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapdraw.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -150,7 +150,7 @@
     else if( MS_RENDERER_GD(map->outputformat) )
         image = msImageCreateGD(map->width, map->height, map->outputformat,
-				map->web.imagepath, map->web.imageurl);
+				map->web.imagepath, map->web.imageurl, map->resolution);
         if( image != NULL ) msImageInitGD( image, &map->imagecolor );
         msPreAllocateColorsGD(image, map);
@@ -158,14 +158,14 @@
     else if( MS_RENDERER_AGG(map->outputformat) )
         image = msImageCreateAGG(map->width, map->height, map->outputformat,
         if( image != NULL ) msImageInitAGG( image, &map->imagecolor );
 #endif
     else if( MS_RENDERER_IMAGEMAP(map->outputformat) )
         image = msImageCreateIM(map->width, map->height, map->outputformat,
         if( image != NULL ) msImageInitIM( image );
     else if( MS_RENDERER_RAWDATA(map->outputformat) )
@@ -674,7 +674,7 @@
     if(layer->opacity > 0 && layer->opacity < 100) {
       msApplyOutputFormat(&transFormat, image->format, MS_TRUE, MS_NOOVERRIDE, MS_NOOVERRIDE);
-      image_draw = msImageCreateGD( image->width, image->height, transFormat, image->imagepath, image->imageurl );
+      image_draw = msImageCreateGD( image->width, image->height, transFormat, image->imagepath, image->imageurl, map->resolution );
       if(!image_draw) {
         msSetError(MS_GDERR, "Unable to initialize image.", "msDrawLayer()");
         return(MS_FAILURE);
@@ -700,7 +700,7 @@
-      image_draw = msImageCreateAGG(image->width, image->height, transFormat, image->imagepath, image->imageurl);
+      image_draw = msImageCreateAGG(image->width, image->height, transFormat, image->imagepath, image->imageurl, map->resolution);
       if(!image_draw) {
         return(MS_FAILURE);
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapgd.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -269,7 +269,7 @@
  * Utility function to create a GD image. Returns
  * a pointer to an imageObj structure.
-imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl)
+imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution)
   imageObj  *image;
@@ -297,7 +297,8 @@
     image->height = height;
     image->imagepath = NULL;
     image->imageurl = NULL;
+    image->resolution = resolution;
     if(imagepath) image->imagepath = strdup(imagepath);
     if(imageurl) image->imageurl = strdup(imageurl);
@@ -318,6 +319,11 @@
 void msImageInitGD( imageObj *image, colorObj *background )
+#endif
   if(image->format->imagemode == MS_IMAGEMODE_PC256) {
     gdImageColorAllocate(image->img.gd, background->red, background->green, background->blue);
     return;
@@ -379,6 +385,11 @@
   image->width = gdImageSX(img);
   image->height = gdImageSY(img);
+  image->resolution = gdImageResolutionX(img);
+#else
+  image->resolution = 72;
+#endif
   /* Create an outputFormatObj for the format. */
   image->format = msCreateDefaultOutputFormat( NULL, driver );
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapimagemap.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -293,7 +293,7 @@
 imageObj *msImageCreateIM(int width, int height, outputFormatObj *format,
-                          char *imagepath, char *imageurl)
+                          char *imagepath, char *imageurl, unsigned int resolution)
     imageObj  *image=NULL;
     if (setvbuf(stdout, NULL, _IONBF , 0)){
@@ -330,6 +330,8 @@
 	    if( strcasecmp("ON",msGetOutputFormatOption( format, "DXF", "OFF" )) == 0){
 		    dxf = 1;
 		    im_iprintf(&layerStr, "  2\nLAYER\n 70\n  10\n");
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/maplegend.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -203,10 +203,10 @@
   /* create image */
 #ifdef USE_AGG
   if(MS_RENDERER_AGG(map->outputformat))
-    image = msImageCreateAGG(width, height, map->outputformat, map->web.imagepath, map->web.imageurl);
+     image = msImageCreateAGG(width, height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
   else
 #endif
-    image = msImageCreateGD(width, height, map->outputformat, map->web.imagepath, map->web.imageurl);
+    image = msImageCreateGD(width, height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
   /* drop this reference to output format */
   msApplyOutputFormat( &format, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE );
@@ -453,10 +453,10 @@
   /* initialize the legend image */
 #ifdef USE_AGG
-    image = msImageCreateAGG(size_x, size_y, format, map->web.imagepath, map->web.imageurl);
+    image = msImageCreateAGG(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution);
   else
 #endif
-    image = msImageCreateGD(size_x, size_y, format, map->web.imagepath, map->web.imageurl);
+    image = msImageCreateGD(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution);
   msApplyOutputFormat(&format, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE);
Modified: trunk/mapserver/mappdf.c
--- trunk/mapserver/mappdf.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mappdf.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -226,7 +226,7 @@
         oImage->img.pdf->imagetmp = (imageObj *)
                           msCreateDefaultOutputFormat(map, driver),
     return oImage;
@@ -1460,7 +1460,7 @@
         image_tmp = msImageCreateGD(map->width, map->height,
     else
Modified: trunk/mapserver/mapresample.c
--- trunk/mapserver/mapresample.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapresample.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -1563,7 +1563,7 @@
     srcImage = msImageCreate( nLoadImgXSize, nLoadImgYSize,
                               sDummyMap.outputformat, NULL, NULL,
-                              &sDummyMap );
+                              &sDummyMap);
     if (srcImage == NULL)
         return -1; /* msSetError() should have been called already */
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapscale.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -258,7 +258,7 @@
    /* create image */
   image = msImageCreateGD(map->scalebar.width, sy, format,
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapserv.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -1494,10 +1494,10 @@
 #ifdef USE_AGG
       if(MS_RENDERER_AGG(mapserv->map->outputformat))
-        img = msImageCreateAGG(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl);
+         img = msImageCreateAGG(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl, mapserv->map->resolution);
       else
 #endif
-        img = msImageCreateGD(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl);
+        img = msImageCreateGD(mapserv->map->legend.keysizex, mapserv->map->legend.keysizey, format, mapserv->map->web.imagepath, mapserv->map->web.imageurl, mapserv->map->resolution);
   /* allocate the background color */
 #ifdef USE_AGG
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapserver.h	2009-03-09 19:09:55 UTC (rev 8721)
@@ -1369,6 +1369,7 @@
 %immutable;
 #endif
   int width, height;
+  unsigned int resolution;
   char *imagepath, *imageurl;
   outputFormatObj *format;
@@ -1899,7 +1900,7 @@
 /*      Prototypes for functions in mapimagemap.c                       */
-MS_DLL_EXPORT imageObj *msImageCreateIM(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl);
+MS_DLL_EXPORT imageObj *msImageCreateIM(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution);
 MS_DLL_EXPORT imageObj *msImageLoadIM( const char *filename );
 MS_DLL_EXPORT imageObj *msImageLoadGD( const char *filename );
 MS_DLL_EXPORT imageObj *msImageLoadGDCtx( gdIOCtx *ctx, const char *driver );
@@ -1926,7 +1927,7 @@
 MS_DLL_EXPORT imageObj *msImageLoadGDCtx(gdIOCtx* ctx, const char *driver);
 MS_DLL_EXPORT int msCompareColors(colorObj *c1, colorObj *c2);
 MS_DLL_EXPORT void msPreAllocateColorsGD(imageObj *image, mapObj *map);
-MS_DLL_EXPORT imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl);
+MS_DLL_EXPORT imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution);
 MS_DLL_EXPORT void msImageInitGD( imageObj *image, colorObj *background );
 MS_DLL_EXPORT int msImageSetPenGD(gdImagePtr img, colorObj *color);
@@ -1957,7 +1958,7 @@
 /*      Prototypes for functions in mapagg.cpp                          */
-MS_DLL_EXPORT imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl);
+MS_DLL_EXPORT imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution);
 MS_DLL_EXPORT void msImageInitAGG( imageObj *image, colorObj *background );
 MS_DLL_EXPORT int msSaveImageAGG(imageObj *img, char *filename, outputFormatObj *format);
Modified: trunk/mapserver/mapswf.c
--- trunk/mapserver/mapswf.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapswf.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -1061,7 +1061,8 @@
+    image->resolution = map->resolution;
     if (imagepath)
@@ -1145,7 +1146,7 @@
         ((SWFObj *)image->img.swf)->imagetmp = (imageObj *)
     free(driver);
     return image;
@@ -2830,7 +2831,7 @@
         bFreeImage = 1;
     else
@@ -3425,7 +3426,7 @@
         imagetmp = msImageCreateGD(map->width, map->height,
         bFreeImage = 1;
     else
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/maputil.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -1324,14 +1324,14 @@
     if( MS_RENDERER_GD(format) )
         image = msImageCreateGD(width, height, format,
-                                imagepath, imageurl);
+                                imagepath, imageurl, map->resolution);
         if( image != NULL && map) msImageInitGD( image, &map->imagecolor );
 #ifdef USE_AGG
     else if( MS_RENDERER_AGG(format) )
         image = msImageCreateAGG(width, height, format,
         if( image != NULL && map) msImageInitAGG( image, &map->imagecolor );
 #endif
@@ -1375,7 +1375,8 @@
         if (imagepath)
         if (imageurl)
@@ -1386,7 +1387,7 @@
     else if( MS_RENDERER_IMAGEMAP(format) )
         image = msImageCreateIM(width, height, format,
 #ifdef USE_MING_FLASH
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2009-03-09 19:04:47 UTC (rev 8720)
+++ trunk/mapserver/mapwcs.c	2009-03-09 19:09:55 UTC (rev 8721)
@@ -1723,11 +1723,11 @@
     msSetError(MS_WCSERR, "The map outputformat is missing!", "msWCSGetCoverage()");
     return msWCSException(map, NULL, NULL, params->version );
   } else if( MS_RENDERER_GD(map->outputformat) ) {
-    image = msImageCreateGD(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl);
+    image = msImageCreateGD(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
 #ifdef USE_AGG
   } else if( MS_RENDERER_AGG(map->outputformat) ) {
-    image = msImageCreateAGG(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl);
+     image = msImageCreateAGG(map->width, map->height, map->outputformat, map->web.imagepath, map->web.imageurl, map->resolution);
 #endif
   } else if( MS_RENDERER_RAWDATA(map->outputformat) ) {
