[mapserver-commits] r8725 - trunk/docs/development/rfc
svn at osgeo.org
svn at osgeo.org
Mon Mar 9 15:30:29 EDT 2009
Author: dmorissette
Date: 2009-03-09 15:30:26 -0400 (Mon, 09 Mar 2009)
New Revision: 8725
Added:
trunk/docs/development/rfc/ms-rfc-55.txt
trunk/docs/development/rfc/index.txt
Initial revision of RFC-55
Modified: trunk/docs/development/rfc/index.txt
--- trunk/docs/development/rfc/index.txt 2009-03-09 19:30:02 UTC (rev 8724)
+++ trunk/docs/development/rfc/index.txt 2009-03-09 19:30:26 UTC (rev 8725)
@@ -63,4 +63,6 @@
ms-rfc-51
ms-rfc-52
ms-rfc-53
+ ms-rfc-54
+ ms-rfc-55
Added: trunk/docs/development/rfc/ms-rfc-55.txt
--- trunk/docs/development/rfc/ms-rfc-55.txt (rev 0)
+++ trunk/docs/development/rfc/ms-rfc-55.txt 2009-03-09 19:30:26 UTC (rev 8725)
@@ -0,0 +1,103 @@
+.. _rfc55:
+MS RFC 55: Improve control of output resolution
+:Date: 2009/03/09
+:Authors: Daniel Morissette
+:Contact: dmorissette at mapgears.com
+:Last Edited: 2009/03/09
+:Status: Draft
+:Version: MapServer 6.0
+:Id: $Id: $
+Overview
+MapServer is often used to produce a printable map corresponding to the
+map currently being displayed in the Web interface.
+Printed maps will usually require a resolution higher than the default 72
+pixels per inch which is commonly used for the screen (e.g. 150 or 300 dpi).
+In general printing is done by setting the map.resolution and requesting a
+larger size image for the same map extents. Setting map.resolution to a higher
+value ensures that the layers minscaledenom/maxscaledenom are properly
+evaluated for the larger image, but one thing is missing: symbology (line
+widths, symbol and font sizes, etc) is not adjusted to reflect the resolution
+change and the result is a map in which symbology looks smaller than what it
+looked on screen.
+This RFC proposes a mechanism to fix this by automatically scaling the
+symbology when resolution changes so that the map maintains the same look
+at each resolution.
+Technical Solution
+A new optional DEFRESOLUTION keywork will be added in the mapObj with
+a default value if 72 if not set. DEFRESOLUTION is the reference or default
+resolution for which all symbology sizes are defined in the mapfile.
+At rendering time, if RESOLUTION is set to something different from
+DEFRESOLUTION, then the symbology in the layer definitions will be
+adjusted by a factor corresponding to RESOLUTION/DEFRESOLUTION.
+More specifically, this is done by multiplying the layer->scalefactor value
+by the resolution/defresolution ratio in msPrepareImage().
+Usage example
+Example 1:
+Let's say we've got a mapfile that we use to produce a 400x400 pixels
+image for use on the Web, with both defresolution and resolution set to 72.
+In order to produce a 300dpi image for printing, the application code
+should request an image of 1667 x 1667 pixels (400*300/72=1667) and set
+resolution=300. MapServer will automagically scale all symbology sizes
+by a factor of 300/72=4.1667.
+Example 2:
+An application is using a mapfile developed for map.resolution=96 with
+MapServer 5.x. In order to take advantage of the new feature, one should
+set DEFRESOLUTION=96 in the mapfile, and at rendering time, setting
+RESOLUTION=300 will result in all symbology being scaled by a factor
+of 300/96=3.125.
+Backwards Compatability Issues
+Existing apps or mapfiles that set RESOLUTION to a value other than 72
+**without** setting DEFRESOLUTION will end up with their symbology scaled.
+This change in behavior is more likely to be considered as a feature
+than as a bug in most cases, but in case this is a problem for an
+existing app then the fix will be to simply add a DEFRESOLUTION to the
+mapfile which matches the resolution for which all mapfile classes
+and styles are defined.
+Files Impacted
+* mapserver.h: new defresolution member in mapObj
+* mapfile.c, maplexer.l, etc: new DEFRESOLUTION mapfile keyword
+* mapdraw.c: adjust scalefactor as needed in msPrepareImage()
+* mapscript/php3/php_mapscript.c: expose new defresolution member
+Ticket Id
+None yet.
+Voting History
+No vote yet.
More information about the mapserver-commits
