[mapserver-commits] r8741 - trunk/mapserver
Mon Mar 9 17:04:52 EDT 2009
Author: jlacroix
Date: 2009-03-09 17:04:52 -0400 (Mon, 09 Mar 2009)
New Revision: 8741
   trunk/mapserver/mapbits.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapshape.h
   trunk/mapserver/maptree.c
   trunk/mapserver/maptree.h
Change mapbit.c bitmask type from char to new 32bit ms_bitarray
Modified: trunk/mapserver/mapbits.c
--- trunk/mapserver/mapbits.c	2009-03-09 21:03:31 UTC (rev 8740)
+++ trunk/mapserver/mapbits.c	2009-03-09 21:04:52 UTC (rev 8741)
@@ -10,7 +10,7 @@
  * Copyright (c) 1996-2005 Regents of the University of Minnesota.
  * Permission is hereby granted, free of charge, to any person obtaining a
  * copy of this software and associated documentation files (the "Software"),
  * to deal in the Software without restriction, including without limitation
@@ -36,24 +36,30 @@
 #include <limits.h>
-/* #define msGetBit(array, index) (*((array) + (index)/CHAR_BIT) & ( 1 << ((index) % CHAR_BIT))) */
+ * Hardcoded size of our bit array.
+ * See function msGetNextBit for another hardcoded value.
+#define MS_ARRAY_BIT 32
+/* #define msGetBit(array, index) (*((array) + (index)/MS_ARRAY_BIT) & ( 1 << ((index) % MS_ARRAY_BIT))) */
 size_t msGetBitArraySize(int numbits)
-  return((numbits + CHAR_BIT - 1) / CHAR_BIT);
+  return((numbits + MS_ARRAY_BIT - 1) / MS_ARRAY_BIT);
-char *msAllocBitArray(int numbits)
+ms_bitarray msAllocBitArray(int numbits)
-  char *array = calloc((numbits + CHAR_BIT - 1) / CHAR_BIT, sizeof(char));
+  ms_bitarray array = calloc((numbits + MS_ARRAY_BIT - 1) / MS_ARRAY_BIT, MS_ARRAY_BIT);
   return(array);
-int msGetBit(char *array, int index)
+int msGetBit(ms_bitarray array, int index)
-  array += index / CHAR_BIT;
-  return (*array & (1 << (index % CHAR_BIT))) != 0;    /* 0 or 1 */
+  array += index / MS_ARRAY_BIT;
+  return (*array & (1 << (index % MS_ARRAY_BIT))) != 0;    /* 0 or 1 */
@@ -63,16 +69,16 @@
 ** If hits end of bitmap without finding set bit, will return -1.
-int msGetNextBit(char *array, int i, int size) {
+int msGetNextBit(ms_bitarray array, int i, int size) {
-  register char b;
+  register ms_uint32 b;
   while(i < size) {
-    b = *(array + (i/CHAR_BIT));
-    if( b && (b >> (i % CHAR_BIT)) ) {
+    b = *(array + (i/MS_ARRAY_BIT));
+    if( b && (b >> (i % MS_ARRAY_BIT)) ) {
       /* There is something in this byte */
       /* And it is not to the right of us */
-      if( b & ( 1 << (i % CHAR_BIT)) ) {
+      if( b & ( 1 << (i % MS_ARRAY_BIT)) ) {
         /* There is something at this bit! */
         return i;
@@ -82,7 +88,7 @@
     else {
       /* Nothing in this byte, move to start of next byte */
-      i += CHAR_BIT - (i % CHAR_BIT);
+      i += MS_ARRAY_BIT - (i % MS_ARRAY_BIT);
@@ -90,17 +96,17 @@
   return -1;
-void msSetBit(char *array, int index, int value)
+void msSetBit(ms_bitarray array, int index, int value)
   if (value)
-    *array |= 1 << (index % CHAR_BIT);           /* set bit */
+    *array |= 1 << (index % MS_ARRAY_BIT);           /* set bit */
   else
-    *array &= ~(1 << (index % CHAR_BIT));        /* clear bit */
+    *array &= ~(1 << (index % MS_ARRAY_BIT));        /* clear bit */
-void msFlipBit(char *array, int index)
+void msFlipBit(ms_bitarray array, int index)
-  *array ^= 1 << (index % CHAR_BIT);                   /* flip bit */
+  *array ^= 1 << (index % MS_ARRAY_BIT);                   /* flip bit */
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-03-09 21:03:31 UTC (rev 8740)
+++ trunk/mapserver/mapserver.h	2009-03-09 21:04:52 UTC (rev 8741)
@@ -88,6 +88,9 @@
 typedef uint32_t        ms_uint32;
 #endif
+/* ms_bitarray is used by the bit mask in mapbit.c */
+typedef ms_uint32 *     ms_bitarray;
 #include "maperror.h"
 #include "mapprimitive.h"
 #include "mapshape.h"
@@ -1773,11 +1776,11 @@
 MS_DLL_EXPORT imageObj *msDrawReferenceMap(mapObj *map);
 MS_DLL_EXPORT size_t msGetBitArraySize(int numbits); /* in mapbits.c */
-MS_DLL_EXPORT char *msAllocBitArray(int numbits);
-MS_DLL_EXPORT int msGetBit(char *array, int index);
-MS_DLL_EXPORT void msSetBit(char *array, int index, int value);
-MS_DLL_EXPORT void msFlipBit(char *array, int index);
-MS_DLL_EXPORT int msGetNextBit(char *array, int index, int size);
+MS_DLL_EXPORT ms_bitarray msAllocBitArray(int numbits);
+MS_DLL_EXPORT int msGetBit(ms_bitarray array, int index);
+MS_DLL_EXPORT void msSetBit(ms_bitarray array, int index, int value);
+MS_DLL_EXPORT void msFlipBit(ms_bitarray array, int index);
+MS_DLL_EXPORT int msGetNextBit(ms_bitarray array, int index, int size);
 MS_DLL_EXPORT int msLayerInitItemInfo(layerObj *layer);
 MS_DLL_EXPORT void msLayerFreeItemInfo(layerObj *layer);
Modified: trunk/mapserver/mapshape.h
--- trunk/mapserver/mapshape.h	2009-03-09 21:03:31 UTC (rev 8740)
+++ trunk/mapserver/mapshape.h	2009-03-09 21:04:52 UTC (rev 8741)
@@ -89,7 +89,7 @@
     int		*panRecOffset;
     int		*panRecSize;
-    char  *panRecLoaded;
+    ms_bitarray panRecLoaded;
     int   panRecAllLoaded;
     double	adBoundsMin[4];
@@ -165,7 +165,7 @@
   int lastshape;
-  char *status;
+  ms_bitarray status;
   rectObj statusbounds; /* holds extent associated with the status vector */
   int isopen;
Modified: trunk/mapserver/maptree.c
--- trunk/mapserver/maptree.c	2009-03-09 21:03:31 UTC (rev 8740)
+++ trunk/mapserver/maptree.c	2009-03-09 21:04:52 UTC (rev 8741)
@@ -378,7 +378,7 @@
   return(treeNodeAddShapeId(tree->root, id, rect, tree->maxdepth));
-static void treeCollectShapeIds(treeNodeObj *node, rectObj aoi, char *status)
+static void treeCollectShapeIds(treeNodeObj *node, rectObj aoi, ms_bitarray status)
   int i;
@@ -404,9 +404,9 @@
-char *msSearchTree(treeObj *tree, rectObj aoi)
+ms_bitarray msSearchTree(treeObj *tree, rectObj aoi)
-  char *status=NULL;
+  ms_bitarray status=NULL;
   status = msAllocBitArray(tree->numshapes);
   if(!status) {
@@ -452,7 +452,7 @@
   treeNodeTrim(tree->root);
-static void searchDiskTreeNode(SHPTreeHandle disktree, rectObj aoi, char *status)
+static void searchDiskTreeNode(SHPTreeHandle disktree, rectObj aoi, ms_bitarray status)
   int i;
   ms_int32 offset;
@@ -507,10 +507,10 @@
   return;
-char *msSearchDiskTree(char *filename, rectObj aoi, int debug)
+ms_bitarray msSearchDiskTree(char *filename, rectObj aoi, int debug)
   SHPTreeHandle	disktree;
   disktree = msSHPDiskTreeOpen (filename, debug);
   if(!disktree) {
@@ -763,7 +763,7 @@
 /* Function to filter search results further against feature bboxes */
-void msFilterTreeSearch(shapefileObj *shp, char *status, rectObj search_rect)
+void msFilterTreeSearch(shapefileObj *shp, ms_bitarray status, rectObj search_rect)
   int i;
   rectObj shape_rect;
Modified: trunk/mapserver/maptree.h
--- trunk/mapserver/maptree.h	2009-03-09 21:03:31 UTC (rev 8740)
+++ trunk/mapserver/maptree.h	2009-03-09 21:04:52 UTC (rev 8741)
@@ -85,13 +85,13 @@
 MS_DLL_EXPORT void msTreeTrim(treeObj *tree);
 MS_DLL_EXPORT void msDestroyTree(treeObj *tree);
-MS_DLL_EXPORT char *msSearchTree(treeObj *tree, rectObj aoi);
-MS_DLL_EXPORT char *msSearchDiskTree(char *filename, rectObj aoi, int debug);
+MS_DLL_EXPORT ms_bitarray msSearchTree(treeObj *tree, rectObj aoi);
+MS_DLL_EXPORT ms_bitarray msSearchDiskTree(char *filename, rectObj aoi, int debug);
 MS_DLL_EXPORT treeObj *msReadTree(char *filename, int debug);
 MS_DLL_EXPORT int msWriteTree(treeObj *tree, char *filename, int LSB_order);
-MS_DLL_EXPORT void msFilterTreeSearch(shapefileObj *shp, char *status, rectObj search_rect);
+MS_DLL_EXPORT void msFilterTreeSearch(shapefileObj *shp, ms_bitarray status, rectObj search_rect);
 #ifdef __cplusplus
