[mapserver-commits] r8755 - trunk/mapserver
Tue Mar 10 09:35:20 EDT 2009
Author: jlacroix
Date: 2009-03-10 09:35:19 -0400 (Tue, 10 Mar 2009)
New Revision: 8755
   trunk/mapserver/mapbits.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapshape.c
Add msSetAllBits function to set all bit in a bitmask array to 1 or 0
Modified: trunk/mapserver/mapbits.c
--- trunk/mapserver/mapbits.c	2009-03-10 13:24:04 UTC (rev 8754)
+++ trunk/mapserver/mapbits.c	2009-03-10 13:35:19 UTC (rev 8755)
@@ -104,6 +104,14 @@
   else
     *array &= ~(1 << (index % MS_ARRAY_BIT));        /* clear bit */
+void msSetAllBits(ms_bitarray array, int numbits, int value)
+  if (value)
+      memset(array, 0xff, ((numbits + 7) / 8) ); /* set bit */
+  else
+      memset(array, 0x0,  ((numbits + 7) / 8) ); /* clear bit */
 void msFlipBit(ms_bitarray array, int index)
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-03-10 13:24:04 UTC (rev 8754)
+++ trunk/mapserver/mapserver.h	2009-03-10 13:35:19 UTC (rev 8755)
@@ -1779,6 +1779,7 @@
 MS_DLL_EXPORT ms_bitarray msAllocBitArray(int numbits);
 MS_DLL_EXPORT int msGetBit(ms_bitarray array, int index);
 MS_DLL_EXPORT void msSetBit(ms_bitarray array, int index, int value);
+MS_DLL_EXPORT void msSetAllBits(ms_bitarray array, int index, int value);
 MS_DLL_EXPORT void msFlipBit(ms_bitarray array, int index);
 MS_DLL_EXPORT int msGetNextBit(ms_bitarray array, int index, int size);
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2009-03-10 13:24:04 UTC (rev 8754)
+++ trunk/mapserver/mapshape.c	2009-03-10 13:35:19 UTC (rev 8755)
@@ -1756,9 +1756,7 @@
       msSetError(MS_MEMERR, NULL, "msShapefileWhichShapes()");
       return(MS_FAILURE);
-    for(i=0;i<shpfile->numshapes;i++) {
-      msSetBit(shpfile->status, i, 1);
+    msSetAllBits(shpfile->status, shpfile->numshapes, 1);
   else {
