[mapserver-commits] r8758 - sandbox/single-pass/mapserver
Tue Mar 10 09:39:35 EDT 2009
Author: sdlime
Date: 2009-03-10 09:39:35 -0400 (Tue, 10 Mar 2009)
New Revision: 8758
   sandbox/single-pass/mapserver/mapgml.c
   sandbox/single-pass/mapserver/mapquery.c
Applied RFC 52 changes to all query types and the WFS GML driver.
Modified: sandbox/single-pass/mapserver/mapgml.c
--- sandbox/single-pass/mapserver/mapgml.c	2009-03-10 13:38:43 UTC (rev 8757)
+++ sandbox/single-pass/mapserver/mapgml.c	2009-03-10 13:39:35 UTC (rev 8758)
@@ -1262,12 +1262,12 @@
       msFree(value);
       /* actually open the layer */
-      status = msLayerOpen(lp);
-      if(status != MS_SUCCESS) return(status);
+      // status = msLayerOpen(lp);
+      // if(status != MS_SUCCESS) return(status);
       /* retrieve all the item names */
-      status = msLayerGetItems(lp);
+      // status = msLayerGetItems(lp);
       /* populate item and group metadata structures (TODO: test for NULLs here, shouldn't happen) */
       itemList = msGMLGetItems(lp, "G");
@@ -1275,6 +1275,7 @@
       groupList = msGMLGetGroups(lp, "G");
       geometryList = msGMLGetGeometries(lp, "G");
+      msLayerRewind(lp);
       for(j=0; j<lp->resultcache->numresults; j++) {
         status = msLayerGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
Modified: sandbox/single-pass/mapserver/mapquery.c
--- sandbox/single-pass/mapserver/mapquery.c	2009-03-10 13:38:43 UTC (rev 8757)
+++ sandbox/single-pass/mapserver/mapquery.c	2009-03-10 13:39:35 UTC (rev 8758)
@@ -219,8 +219,8 @@
   if(status != MS_SUCCESS) return(MS_FAILURE);
-  /* build item list (no annotation) since we do have to classify the shape */
-  status = msLayerWhichItems(lp, MS_TRUE, MS_FALSE, NULL);
+  /* need all the items */
+  status = msLayerWhichItemsNew(lp, MS_TRUE, MS_TRUE, MS_TRUE, NULL);
   if(!addtoquery || lp->resultcache == NULL) {
@@ -253,7 +253,7 @@
     msMergeRect(&(lp->resultcache->bounds), &shape.bounds);
   msFreeShape(&shape);
-  msLayerClose(lp);
+  // msLayerClose(lp);
   return(MS_SUCCESS);
@@ -337,8 +337,8 @@
-  /* build item list (no annotation) */
   /* identify target shapes */
@@ -420,12 +420,12 @@
+  /* Was anything found? If so, don't close the layer. */
+  if(lp->resultcache && lp->resultcache->numresults > 0)
+    return(MS_SUCCESS);
   msLayerClose(lp);
-  /* was anything found?  */
-  if(lp->resultcache && lp->resultcache->numresults > 0)
-    return(MS_SUCCESS);
   msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByAttributes()");
   return(MS_FAILURE);
@@ -489,7 +489,7 @@
     /* build item list, we need all items */
-    status = msLayerWhichItemsNew(lp, MS_TRUE, MS_FALSE, MS_TRUE, NULL);
@@ -502,7 +502,7 @@
 #endif
     status = msLayerWhichShapes(lp, searchrect);
     if(status == MS_DONE) { /* no overlap */
-      msLayerClose(lp);
+      msLayerClose(lp); /* Ok to close here, no results... */
       continue;
     } else if(status != MS_SUCCESS) {
       msLayerClose(lp);
@@ -677,8 +677,8 @@
+    /* we need all items */
     /* for each selection shape (TODO: use cached features if they exist) */
@@ -845,12 +845,11 @@
       msFreeShape(&selectshape);
     } /* next selection shape */
-    msLayerClose(lp);
+    // TODO: check to see if any results were found, if not then close...
   } /* next layer */
-  msLayerClose(slp);
+  /* Was anything found? If so then don't close the layer. */
   for(l=start; l>=stop; l--) {
     if(l == slayer) continue; /* skip the selection layer */
@@ -858,6 +857,8 @@
       return(MS_SUCCESS);
+  msLayerClose(slp);
   msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByFeatures()");
   return(MS_FAILURE);
@@ -956,8 +957,8 @@
+    /* build item list, need all of them */
@@ -1032,7 +1033,7 @@
     if(status != MS_DONE) return(MS_FAILURE);
-    msLayerClose(lp);
     if((lp->resultcache->numresults > 0) && (mode == MS_SINGLE) && (maxresults == 0))
       break;   /* no need to search any further */
@@ -1131,8 +1132,8 @@
@@ -1225,7 +1226,8 @@
-    msLayerClose(lp);
+    if(GET_LAYER(map, l)->resultcache->numresults == 0)
+      msLayerClose(lp); /* no need to hold anything open */
   } /* next layer */
@@ -1321,8 +1323,8 @@
@@ -1456,7 +1458,8 @@
-      msLayerClose(lp);
     } /* next layer */
     /*todo call should be moved somewhere else*/
@@ -1468,7 +1471,6 @@
         return(MS_SUCCESS);
     msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByOperator()");
     return(MS_FAILURE);
 #else
