[mapserver-commits] r8767 - sandbox/single-pass/mapserver
Tue Mar 10 11:31:51 EDT 2009
Author: pramsey
Date: 2009-03-10 11:31:51 -0400 (Tue, 10 Mar 2009)
New Revision: 8767
   sandbox/single-pass/mapserver/mappostgis.c
PostGIS driver now supports new query workload.
Modified: sandbox/single-pass/mapserver/mappostgis.c
--- sandbox/single-pass/mapserver/mappostgis.c	2009-03-10 14:16:49 UTC (rev 8766)
+++ sandbox/single-pass/mapserver/mappostgis.c	2009-03-10 15:31:51 UTC (rev 8767)
@@ -1394,8 +1394,11 @@
             uid = 0;
-        shape->index = uid;
+        shape->index = layerinfo->rownum;
+/* Non one-pass version */
+/*        shape->index = uid; */
         if( layer->debug > 2 ) {
             msDebug("msPostGISReadShape: [index] %d\n",  shape->index);
@@ -1781,8 +1784,10 @@
 #ifdef USE_POSTGIS
     PGresult *pgresult;
     msPostGISLayerInfo *layerinfo;
-    int result, num_tuples;
-    char *strSQL = 0;
+	int result;
+	/*, num_tuples;
+    char *strSQL = 0;*/
     assert(layer != NULL);
     assert(layer->layerinfo != NULL);
@@ -1791,17 +1796,23 @@
         msDebug("msPostGISLayerGetShape called for record = %i\n", record);
-    /* Fill out layerinfo with our current DATA state. */
-    if ( msPostGISParseData(layer) != MS_SUCCESS) {
-        return MS_FAILURE;
-    ** This comes *after* parsedata, because parsedata fills in
-    ** layer->layerinfo.
     layerinfo = (msPostGISLayerInfo*) layer->layerinfo;
+	/* TODO test here for valid pgresult */
+    pgresult = layerinfo->pgresult;
+    layerinfo->rownum = record; /* Only return one result. */
+    /* We don't know the shape type until we read the geometry. */
+    shape->type = MS_SHAPE_NULL;
+	/* TODO: trap bad reads (record number doesn't match result set */
+    result = msPostGISReadShape(layer, shape);
+    return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : MS_SUCCESS;
+/* This is the old version of the function */
+#if 0
     /* Build a SQL query based on our current state. */
     strSQL = msPostGISBuildSQL(layer, 0, &record);
     if ( ! strSQL ) {
@@ -1850,6 +1861,9 @@
     return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : ( (num_tuples > 0) ? MS_SUCCESS : MS_DONE );
+#endif
 #else
     msSetError( MS_MISCERR,
                 "PostGIS support is not available.",
