[mapserver-commits] r8778 - trunk/docs/tutorial
Wed Mar 11 17:06:20 EDT 2009
Author: jmckenna
Date: 2009-03-11 17:06:20 -0400 (Wed, 11 Mar 2009)
New Revision: 8778
   trunk/docs/tutorial/example1-2.txt
fix link to old demo
Modified: trunk/docs/tutorial/example1-2.txt
--- trunk/docs/tutorial/example1-2.txt	2009-03-11 19:15:07 UTC (rev 8777)
+++ trunk/docs/tutorial/example1-2.txt	2009-03-11 21:06:20 UTC (rev 8778)
@@ -10,7 +10,7 @@
 As in the first example, this image was generated by linking the source of the
 <img> tag to this URL:
-`<http://terrasip.gis.umn.edu/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-2.map&mode=map>`_.
+`<http://demo.mapserver.org/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-2.map&layer=states_poly&layer=states_line&mode=map>`_.
 This is how most of the examples in this section work.
 Anyway, you'll notice that the map here is the same as the first example. Yes,
