[mapserver-commits] r8784 - trunk/docs/development/rfc
Thu Mar 12 14:03:53 EDT 2009
Author: dmorissette
Date: 2009-03-12 14:03:53 -0400 (Thu, 12 Mar 2009)
New Revision: 8784
   trunk/docs/development/rfc/ms-rfc-55.txt
Fix a few typos
Modified: trunk/docs/development/rfc/ms-rfc-55.txt
--- trunk/docs/development/rfc/ms-rfc-55.txt	2009-03-12 12:09:58 UTC (rev 8783)
+++ trunk/docs/development/rfc/ms-rfc-55.txt	2009-03-12 18:03:53 UTC (rev 8784)
@@ -7,7 +7,7 @@
 :Date: 2009/03/09
 :Authors: Daniel Morissette
 :Contact: dmorissette at mapgears.com
-:Last Edited: 2009/03/10
+:Last Edited: 2009/03/12
 :Status: Draft
 :Version: MapServer 6.0
 :Id: $Id: $
@@ -35,7 +35,7 @@
 Technical Solution
-A new optional DEFRESOLUTION keywork will be added in the mapObj with
+A new optional DEFRESOLUTION keyword will be added in the mapObj with
 a default value if 72 if not set. DEFRESOLUTION is the reference or default
 resolution for which all symbology sizes are defined in the mapfile.
@@ -94,7 +94,7 @@
 of 300/96=3.125.
-Backwards Compatability Issues
+Backwards Compatibility Issues
 Existing apps or mapfiles that set RESOLUTION to a value other than 72
