[mapserver-commits] r8789 - trunk/docs/development/rfc
Thu Mar 12 15:42:01 EDT 2009
Author: dmorissette
Date: 2009-03-12 15:42:01 -0400 (Thu, 12 Mar 2009)
New Revision: 8789
   trunk/docs/development/rfc/ms-rfc-55.txt
Added documentation notes
Modified: trunk/docs/development/rfc/ms-rfc-55.txt
--- trunk/docs/development/rfc/ms-rfc-55.txt	2009-03-12 19:34:33 UTC (rev 8788)
+++ trunk/docs/development/rfc/ms-rfc-55.txt	2009-03-12 19:42:01 UTC (rev 8789)
@@ -135,6 +135,16 @@
 The rendering parameters listed above that did not follow scaling in the
 past will be fixed to follow the scaling.
+Documentation notes
+In addition to documenting the new feature, a note should be added
+somewhere in the mapserver docs that as of this change, the size values
+will reflect valid sizes (according to the SIZEUNITS settings, MS_PIXELS
+by default) only when the RESOLUTION is set to the default 72 or equal
+to the DEFRESOLUTION setting.
 Files Impacted
