[mapserver-commits] r8791 - sandbox/graphics
svn at osgeo.org
svn at osgeo.org
Sat Mar 14 04:26:18 EDT 2009
Author: tbonfort
Date: 2009-03-14 04:26:17 -0400 (Sat, 14 Mar 2009)
New Revision: 8791
sandbox/graphics/mapdraw.c
revert code fromatting changes
Modified: sandbox/graphics/mapdraw.c
--- sandbox/graphics/mapdraw.c 2009-03-13 21:32:38 UTC (rev 8790)
+++ sandbox/graphics/mapdraw.c 2009-03-14 08:26:17 UTC (rev 8791)
@@ -15,7 +15,7 @@
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
+ * The above copyright notice and this permission notice shall be included in
* all copies of this Software or works derived from this Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
@@ -40,19 +40,19 @@
* format type specific) which is why this function is here instead of the GD, PDF or SWF source files.
void msClearLayerPenValues(layerObj *layer) {
- int i, j;
+ int i, j;
for(i=0; i<layer->numclasses; i++) {
layer->class[i]->label.backgroundcolor.pen = MS_PEN_UNSET; /* set in billboardXX function */
layer->class[i]->label.backgroundshadowcolor.pen = MS_PEN_UNSET;
layer->class[i]->label.color.pen = MS_PEN_UNSET; /* set in MSXXDrawText function */
layer->class[i]->label.outlinecolor.pen = MS_PEN_UNSET;
- layer->class[i]->label.shadowcolor.pen = MS_PEN_UNSET;
+ layer->class[i]->label.shadowcolor.pen = MS_PEN_UNSET;
for(j=0; j<layer->class[i]->numstyles; j++) {
layer->class[i]->styles[j]->backgroundcolor.pen = MS_PEN_UNSET; /* set in various symbol drawing functions */
layer->class[i]->styles[j]->color.pen = MS_PEN_UNSET;
- layer->class[i]->styles[j]->outlinecolor.pen = MS_PEN_UNSET;
+ layer->class[i]->styles[j]->outlinecolor.pen = MS_PEN_UNSET;
@@ -116,7 +116,7 @@
msClearScalebarPenValues(&(map->scalebar));
msClearReferenceMapPenValues(&(map->reference));
msClearQueryMapPenValues(&(map->querymap));
/* msPrepareImage()
@@ -127,7 +127,7 @@
* msMapRestoreRealExtent() once they are done with the image.
* This should be set to MS_TRUE only when called from msDrawMap(), see bug 945.
-imageObj *msPrepareImage(mapObj *map, int allow_nonsquare)
+imageObj *msPrepareImage(mapObj *map, int allow_nonsquare)
int i, status;
imageObj *image=NULL;
@@ -162,23 +162,23 @@
else if( MS_RENDERER_GD(map->outputformat) )
- image = msImageCreateGD(map->width, map->height, map->outputformat,
- map->web.imagepath, map->web.imageurl);
+ image = msImageCreateGD(map->width, map->height, map->outputformat,
+ map->web.imagepath, map->web.imageurl);
if( image != NULL ) msImageInitGD( image, &map->imagecolor );
msPreAllocateColorsGD(image, map);
#ifdef USE_AGG
else if( MS_RENDERER_AGG(map->outputformat) )
- image = msImageCreateAGG(map->width, map->height, map->outputformat,
+ image = msImageCreateAGG(map->width, map->height, map->outputformat,
if( image != NULL ) msImageInitAGG( image, &map->imagecolor );
#endif
else if( MS_RENDERER_IMAGEMAP(map->outputformat) )
- image = msImageCreateIM(map->width, map->height, map->outputformat,
+ image = msImageCreateIM(map->width, map->height, map->outputformat,
if( image != NULL ) msImageInitIM( image );
else if( MS_RENDERER_RAWDATA(map->outputformat) )
@@ -212,7 +212,7 @@
image = NULL;
if(!image) {
msSetError(MS_GDERR, "Unable to initialize image.", "msPrepareImage()");
return(NULL);
@@ -231,7 +231,7 @@
double cellsize_x = (map->extent.maxx - map->extent.minx)/map->width;
double cellsize_y = (map->extent.maxy - map->extent.miny)/map->height;
- if( cellsize_y != 0.0
+ if( cellsize_y != 0.0
&& (fabs(cellsize_x/cellsize_y) > 1.00001
|| fabs(cellsize_x/cellsize_y) < 0.99999) )
@@ -269,7 +269,7 @@
geo_cellsize = sqrt(cellsize_x*cellsize_x + cellsize_y*cellsize_y)
/ sqrt(2.0);
/* compute layer scale factors now */
for(i=0;i<map->numlayers; i++) {
@@ -290,7 +290,7 @@
* The type of the image created is based on the imagetype parameter in the map file.
* mapObj *map - map object loaded in MapScript or via a mapfile to use
- * int querymap - is this map the result of a query operation, MS_TRUE|MS_FALSE
+ * int querymap - is this map the result of a query operation, MS_TRUE|MS_FALSE
imageObj *msDrawMap(mapObj *map, int querymap)
@@ -328,12 +328,12 @@
#if defined(USE_WMS_LYR) || defined(USE_WFS_LYR)
/* How many OWS (WMS/WFS) layers do we have to draw?
* Note: numOWSLayers is the number of actual layers and numOWSRequests is
- * the number of HTTP requests which could be lower if multiple layers
+ * the number of HTTP requests which could be lower if multiple layers
* are merged into the same request.
numOWSLayers=0;
for(i=0; i<map->numlayers; i++) {
- if(map->layerorder[i] != -1 &&
+ if(map->layerorder[i] != -1 &&
msLayerIsVisible(map, GET_LAYER(map,map->layerorder[i])))
numOWSLayers++;
@@ -408,14 +408,14 @@
if(!msLayerIsVisible(map, lp)) continue;
if(lp->connectiontype == MS_WMS) {
-#ifdef USE_WMS_LYR
+#ifdef USE_WMS_LYR
if(MS_RENDERER_GD(image->format) || MS_RENDERER_RAWDATA(image->format))
status = msDrawWMSLayerLow(map->layerorder[i], pasOWSReqInfo, numOWSRequests, map, lp, image);
#ifdef USE_AGG
else if(MS_RENDERER_AGG(image->format))
#endif
-#ifdef USE_MING_FLASH
+#ifdef USE_MING_FLASH
else if(MS_RENDERER_SWF(image->format))
status = msDrawWMSLayerSWF(map->layerorder[i], pasOWSReqInfo, numOWSRequests, map, lp, image);
#endif
@@ -427,9 +427,9 @@
msSetError(MS_WMSCONNERR, "Output format '%s' doesn't support WMS layers.", "msDrawMap()", image->format->name);
status = MS_FAILURE;
if(status == MS_FAILURE) {
- msSetError(MS_WMSCONNERR,
+ msSetError(MS_WMSCONNERR,
"Failed to draw WMS layer named '%s'. This most likely happened because "
"the remote WMS server returned an invalid image, and XML exception "
"or another unexpected result in response to the GetMap request. Also check "
@@ -468,7 +468,7 @@
if(map->debug >= MS_DEBUGLEVEL_TUNING || lp->debug >= MS_DEBUGLEVEL_TUNING) {
msGettimeofday(&endtime, NULL);
- msDebug("msDrawMap(): Layer %d (%s), %.3fs\n",
+ msDebug("msDrawMap(): Layer %d (%s), %.3fs\n",
map->layerorder[i], lp->name?lp->name:"(null)",
(endtime.tv_sec+endtime.tv_usec/1.0e6)-
(starttime.tv_sec+starttime.tv_usec/1.0e6) );
@@ -513,7 +513,7 @@
if(map->debug >= MS_DEBUGLEVEL_TUNING) {
- msDebug("msDrawMap(): Drawing Label Cache, %.3fs\n",
+ msDebug("msDrawMap(): Drawing Label Cache, %.3fs\n",
@@ -528,10 +528,10 @@
if(map->debug >= MS_DEBUGLEVEL_TUNING || lp->debug >= MS_DEBUGLEVEL_TUNING) msGettimeofday(&starttime, NULL);
-#ifdef USE_WMS_LYR
+#ifdef USE_WMS_LYR
-#ifdef USE_AGG
+#ifdef USE_AGG
#endif
@@ -567,14 +567,14 @@
/* Do we need to fake out stuff for rotated support? */
/* This really needs to be done on every preceeding exit point too... */
if(map->gt.need_geotransform)
@@ -605,7 +605,7 @@
msGettimeofday(&mapendtime, NULL);
- msDebug("msDrawMap() total time: %.3fs\n",
+ msDebug("msDrawMap() total time: %.3fs\n",
(mapendtime.tv_sec+mapendtime.tv_usec/1.0e6)-
(mapstarttime.tv_sec+mapstarttime.tv_usec/1.0e6) );
@@ -615,7 +615,7 @@
* Test whether a layer should be drawn or not in the current map view and
- * at the current scale.
+ * at the current scale.
* Returns TRUE if layer is visible, FALSE if not.
int msLayerIsVisible(mapObj *map, layerObj *layer)
@@ -630,7 +630,7 @@
if(msEvalContext(map, layer, layer->requires) == MS_FALSE) return(MS_FALSE);
if(map->scaledenom > 0) {
/* layer scale boundaries should be checked first */
if((layer->maxscaledenom > 0) && (map->scaledenom > layer->maxscaledenom)) return(MS_FALSE);
if((layer->minscaledenom > 0) && (map->scaledenom <= layer->minscaledenom)) return(MS_FALSE);
@@ -644,7 +644,7 @@
continue; /* can skip this one, next class */
break; /* can't skip this class (or layer for that matter) */
if(i == layer->numclasses) return(MS_FALSE);
@@ -668,7 +668,7 @@
int oldAlphaBlending=0; /* allow toggling of gd alpha blending (bug 490) */
if(!msLayerIsVisible(map, layer))
- return MS_SUCCESS;
+ return MS_SUCCESS;
if(layer->opacity == 0) return MS_SUCCESS; /* layer is completely transparent, skip it */
@@ -681,19 +681,19 @@
if(MS_RENDERER_GD(image_draw->format)) {
** for layer-level opacity we render to a temp image
if(layer->opacity > 0 && layer->opacity < 100) {
msApplyOutputFormat(&transFormat, image->format, MS_TRUE, MS_NOOVERRIDE, MS_NOOVERRIDE);
image_draw = msImageCreateGD( image->width, image->height, transFormat, image->imagepath, image->imageurl );
if(!image_draw) {
msSetError(MS_GDERR, "Unable to initialize image.", "msDrawLayer()");
return(MS_FAILURE);
msImageInitGD(image_draw, &map->imagecolor);
if(image_draw->format->imagemode == MS_IMAGEMODE_PC256) /* gdImageCopyMerge() needs this later */
gdImageColorTransparent(image_draw->img.gd, 0);
@@ -717,14 +717,14 @@
return (MS_FAILURE);
} else {
- image_draw->format->r->startNewLayer(image_draw, layer->opacity);
+ image_draw->format->r->startNewLayer(image_draw,layer->opacity);
#ifdef USE_AGG
else if(MS_RENDERER_AGG(image_draw->format)) {
@@ -740,8 +740,8 @@
#endif
- ** redirect procesing of some layer types.
+ ** redirect procesing of some layer types.
if(layer->connectiontype == MS_WMS) {
#ifdef USE_WMS_LYR
@@ -750,7 +750,7 @@
msAlphaAGG2GD(image_draw);
#endif
retcode = msDrawWMSLayer(map, layer, image_draw);
-#else
+#else
retcode = MS_FAILURE;
#endif
} else if(layer->type == MS_LAYER_RASTER) {
@@ -788,9 +788,9 @@
else if( MS_RENDERER_PLUGIN(image_draw->format) && layer->opacity > 0 && layer->opacity < 100 ) {
if (!image_draw->format->r->supports_transparent_layers) {
- image_draw->format->r->mergeImages(image,image_draw,100,0,0);
+ image_draw->format->r->mergeImages(image,image_draw,100,0,0);
image_draw->format->r->freeImage( image_draw );
/* deref and possibly free temporary transparent output format. */
msApplyOutputFormat( &transFormat, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE );
} else {
@@ -842,13 +842,13 @@
if ((msLookupHashTable(&(layer->metadata), "SWFOUTPUT") &&
strcasecmp(msLookupHashTable(&(layer->metadata), "SWFOUTPUT"),"RASTER")==0) ||
- strcasecmp(msGetOutputFormatOption(image->format,"OUTPUT_MOVIE", ""),
+ strcasecmp(msGetOutputFormatOption(image->format,"OUTPUT_MOVIE", ""),
"MULTIPLE") != 0)
return msDrawVectorLayerAsRasterSWF(map, layer, image);
#endif
/* For PDF if the output_type is set to raster, draw the vector */
/* into a gd image. */
@@ -856,7 +856,7 @@
#ifdef USE_PDF
if(image && MS_RENDERER_PDF(image->format))
- if (strcasecmp(msGetOutputFormatOption(image->format,"OUTPUT_TYPE", ""),
+ if (strcasecmp(msGetOutputFormatOption(image->format,"OUTPUT_TYPE", ""),
"RASTER") == 0)
return msDrawVectorLayerAsRasterPDF(map, layer, image);
@@ -870,11 +870,11 @@
/* reset layer pen values just in case the map has been previously processed */
msClearLayerPenValues(layer);
/* open this layer */
status = msLayerOpen(layer);
if(status != MS_SUCCESS) return MS_FAILURE;
/* build item list */
/* For Flash, we use a metadata called SWFDUMPATTRIBUTES that */
@@ -882,15 +882,15 @@
/* flash movie for query purpose. */
if(image && MS_RENDERER_SWF(image->format))
- status = msLayerWhichItems(layer, MS_TRUE, annotate, msLookupHashTable(&(layer->metadata), "SWFDUMPATTRIBUTES"));
- else
+ status = msLayerWhichItems(layer, MS_TRUE, annotate, msLookupHashTable(&(layer->metadata), "SWFDUMPATTRIBUTES"));
+ else
status = msLayerWhichItems(layer, MS_TRUE, annotate, NULL);
if(status != MS_SUCCESS) {
msLayerClose(layer);
return MS_FAILURE;
/* identify target shapes */
if(layer->transform == MS_TRUE)
searchrect = map->extent;
@@ -899,12 +899,12 @@
searchrect.maxx = map->width-1;
searchrect.maxy = map->height-1;
#ifdef USE_PROJ
if((map->projection.numargs > 0) && (layer->projection.numargs > 0))
msProjectRect(&map->projection, &layer->projection, &searchrect); /* project the searchrect to source coords */
#endif
status = msLayerWhichShapes(layer, searchrect);
if(status == MS_DONE) { /* no overlap */
@@ -913,10 +913,10 @@
return MS_FAILURE;
/* step through the target shapes */
msInitShape(&shape);
nclasses = 0;
classgroup = NULL;
if (layer->classgroup && layer->numclasses > 0)
@@ -929,12 +929,11 @@
msFreeShape(&shape);
continue;
cache = MS_FALSE;
- if(layer->type == MS_LAYER_LINE && (layer->class[shape.classindex]->numstyles > 1 ||
- (layer->class[shape.classindex]->numstyles == 1 && layer->class[shape.classindex]->styles[0]->outlinewidth>0)))
+ if(layer->type == MS_LAYER_LINE && (layer->class[shape.classindex]->numstyles > 1||layer->class[shape.classindex]->styles[0]->outlinewidth>0))
cache = MS_TRUE; /* only line layers with multiple styles need be cached (I don't think POLYLINE layers need caching - SDL) */
/* With 'STYLEITEM AUTO', we will have the datasource fill the class' */
/* style parameters for this shape. */
if(layer->styleitem && strcasecmp(layer->styleitem, "AUTO") == 0) {
@@ -942,59 +941,43 @@
break;
/* __TODO__ For now, we can't cache features with 'AUTO' style */
cache = MS_FALSE;
if(annotate && (layer->class[shape.classindex]->text.string || layer->labelitem) && layer->class[shape.classindex]->label.size != -1)
shape.text = msShapeGetAnnotation(layer, &shape);
- if (cache) {
+ if(cache) {
int i;
- for (i = 0; i < layer->class[shape.classindex]->numstyles; i++) {
- styleObj *pStyle = layer->class[shape.classindex]->styles[i];
- colorObj tmp;
- if (pStyle->outlinewidth > 0) {
- * RFC 49 implementation
- * if an outlinewidth is used:
- * - augment the style's width to account for the outline width
- * - swap the style color and outlinecolor
- * - draw the shape (the outline) in the first pass of the
- * caching mechanism
- /* adapt width (must take scalefactor into account) */
- pStyle->width += (pStyle->outlinewidth / layer->scalefactor) * 2;
- pStyle->minwidth += pStyle->outlinewidth * 2;
- pStyle->maxwidth += pStyle->outlinewidth * 2;
- /*swap color and outlinecolor*/
- tmp = pStyle->color;
- pStyle->color = pStyle->outlinecolor;
- pStyle->outlinecolor = tmp;
+ for(i=0;i<layer->class[shape.classindex]->numstyles;i++) {
+ if(layer->class[shape.classindex]->styles[i]->outlinewidth>0) {
+ colorObj tmp;
+ styleObj *styleTmp = layer->class[shape.classindex]->styles[i];
+ //msDebug("layer width before:%f\n",styleTmp->width);
+ styleTmp->width+=styleTmp->outlinewidth/layer->scalefactor*2;
+ //msDebug("layer width after:%f\n",styleTmp->width);
+ styleTmp->minwidth+=styleTmp->outlinewidth*2;
+ styleTmp->maxwidth+=styleTmp->outlinewidth*2;
+ tmp = styleTmp->color;
+ styleTmp->color=styleTmp->outlinecolor;
+ styleTmp->outlinecolor=tmp;
+ //layer->class[shape.classindex]->styles[i]->width+=layer->class[shape.classindex]->styles[i]->outlinewidth;
- if (i == 0 || pStyle->outlinewidth > 0) {
- status = msDrawShape(map, layer, &shape, image, i, MS_TRUE); /* draw a single style */
+ status = msDrawShape(map, layer, &shape, image, 0,MS_TRUE); /* draw only the first style */
+ colorObj tmp;
+ styleTmp->width-=styleTmp->outlinewidth/layer->scalefactor*2;
+ styleTmp->minwidth-=styleTmp->outlinewidth*2;
+ styleTmp->maxwidth-=styleTmp->outlinewidth*2;
- * RFC 49 implementation: switch back the styleobj to its
- * original state, so the line fill will be drawn in the
- * second pass of the caching mechanism
- /* reset widths to original state */
- pStyle->width -= (pStyle->outlinewidth / layer->scalefactor) * 2;
- pStyle->minwidth -= pStyle->outlinewidth * 2;
- pStyle->maxwidth -= pStyle->outlinewidth * 2;
- /*reswap colors to original state*/
@@ -1010,18 +993,18 @@
continue;
if(cache) {
if(insertFeatureList(&shpcache, &shape) == NULL) {
retcode = MS_FAILURE; /* problem adding to the cache */
break;
maxnumstyles = MS_MAX(maxnumstyles, layer->class[shape.classindex]->numstyles);
if (classgroup)
msFree(classgroup);
@@ -1029,36 +1012,36 @@
return MS_FAILURE;
if(shpcache) {
int s;
for(s=0; s<maxnumstyles; s++) {
for(current=shpcache; current; current=current->next) {
if(layer->class[current->shape.classindex]->numstyles > s) {
- styleObj *pStyle = layer->class[current->shape.classindex]->styles[s];
- if(pStyle->_geomtransform!=MS_GEOMTRANSFORM_NONE)
+ styleObj *curStyle = layer->class[current->shape.classindex]->styles[s];
+ if(curStyle->_geomtransform!=MS_GEOMTRANSFORM_NONE)
continue; /*skip this as it has already been rendered*/
- if((pStyle->maxscaledenom != -1) && (map->scaledenom >= pStyle->maxscaledenom))
+ if((curStyle->maxscaledenom != -1) && (map->scaledenom >= curStyle->maxscaledenom))
continue;
- if((pStyle->minscaledenom != -1) && (map->scaledenom < pStyle->minscaledenom))
+ if((curStyle->minscaledenom != -1) && (map->scaledenom < curStyle->minscaledenom))
continue;
- if(s==0 && pStyle->outlinewidth>0 && MS_VALID_COLOR(pStyle->color)) {
- msDrawLineSymbol(&map->symbolset, image, ¤t->shape, pStyle, layer->scalefactor);
+ if(s==0 && curStyle->outlinewidth>0 && MS_VALID_COLOR(curStyle->color)) {
+ msDrawLineSymbol(&map->symbolset, image, ¤t->shape, curStyle, layer->scalefactor);
} else if(s>0)
freeFeatureList(shpcache);
- shpcache = NULL;
+ shpcache = NULL;
- msLayerClose(layer);
+ msLayerClose(layer);
return MS_SUCCESS;
@@ -1079,11 +1062,11 @@
if(!layer->resultcache || map->querymap.style == MS_NORMAL)
return(msDrawLayer(map, layer, image));
- if(!layer->data && !layer->tileindex && !layer->connection && !layer->features)
+ if(!layer->data && !layer->tileindex && !layer->connection && !layer->features)
return(MS_SUCCESS); /* no data associated with this layer, not an error since layer may be used as a template from MapScript */
if(layer->type == MS_LAYER_QUERY || layer->type == MS_LAYER_TILEINDEX) return(MS_SUCCESS); /* query and tileindex layers simply can't be drawn, not an error */
if( layer->type == MS_LAYER_RASTER ) {
msSetError( MS_QUERYERR, "Unable to draw raster layers (such as %s) as part of a query result.", "msDrawQueryLayer()", layer->name );
return MS_FAILURE;
@@ -1130,10 +1113,6 @@
if(layer->type == MS_LAYER_POLYGON) { /* alter BOTTOM style since that's almost always the fill */
- if (layer->class[i]->styles == NULL) {
- msSetError(MS_MISCERR, "Don't know how to draw class %s of layer %s without a style definition.", "msDrawQueryLayer()", layer->class[i]->name, layer->name);
- return(MS_FAILURE);
if(MS_VALID_COLOR(layer->class[i]->styles[0]->color)) {
colorbuffer[i] = layer->class[i]->styles[0]->color; /* save the color from the BOTTOM style */
layer->class[i]->styles[0]->color = map->querymap.color;
@@ -1189,12 +1168,12 @@
shape.classindex = layer->resultcache->results[i].classindex;
/* classindex may be -1 here if there was a template at the top level
* in this layer and the current shape selected even if it didn't
- * match any class
+ * match any class
- * FrankW: classindex is also sometimes 0 even if there are no classes, so
+ * FrankW: classindex is also sometimes 0 even if there are no classes, so
* we are careful not to use out of range class values as an index.
- if(shape.classindex==-1
+ if(shape.classindex==-1
|| shape.classindex >= layer->numclasses
|| layer->class[shape.classindex]->status == MS_OFF) {
@@ -1202,7 +1181,7 @@
cache = MS_FALSE;
- if(layer->type == MS_LAYER_LINE && layer->class[shape.classindex]->numstyles > 1)
+ if(layer->type == MS_LAYER_LINE && layer->class[shape.classindex]->numstyles > 1)
@@ -1234,7 +1213,7 @@
if(shpcache) {
int s;
for(s=1; s<maxnumstyles; s++) {
@@ -1249,9 +1228,9 @@
- shpcache = NULL;
+ shpcache = NULL;
/* if MS_HILITE, restore color and mindistance values */
@@ -1264,11 +1243,11 @@
layer->class[i]->styles[0]->outlinecolor = colorbuffer[i]; /* if no color, restore outlinecolor for the BOTTOM style */
} else {
if(MS_VALID_COLOR(layer->class[i]->styles[layer->class[i]->numstyles-1]->color))
- layer->class[i]->styles[layer->class[i]->numstyles-1]->color = colorbuffer[i];
+ layer->class[i]->styles[layer->class[i]->numstyles-1]->color = colorbuffer[i];
else if(MS_VALID_COLOR(layer->class[i]->styles[layer->class[i]->numstyles-1]->outlinecolor))
layer->class[i]->styles[layer->class[i]->numstyles-1]->outlinecolor = colorbuffer[i]; /* if no color, restore outlinecolor for the TOP style */
layer->class[i]->label.mindistance = mindistancebuffer[i];
@@ -1284,7 +1263,7 @@
* Generic function to render raster layers.
-int msDrawRasterLayer(mapObj *map, layerObj *layer, imageObj *image)
+int msDrawRasterLayer(mapObj *map, layerObj *layer, imageObj *image)
if (image && map && layer)
@@ -1315,7 +1294,7 @@
* msDrawWMSLayer()
- * Draw a single WMS layer.
+ * Draw a single WMS layer.
* Multiple WMS layers in a map are preloaded and then drawn using
* msDrawWMSLayerLow()
@@ -1358,7 +1337,7 @@
nStatus = msDrawWMSLayerLow(1, asReqInfo, numReq,
map, layer, image) ;
else if( MS_RENDERER_SWF(image->format) )
nStatus = msDrawWMSLayerSWF(1, asReqInfo, numReq,
map, layer, image);
@@ -1367,7 +1346,7 @@
/* PDF doesn't support WMS yet so return failure
else if( MS_RENDERER_PDF(image->format) )
- nReturnVal = msDrawWMSLayerPDF(image, labelPnt, string, label,
+ nReturnVal = msDrawWMSLayerPDF(image, labelPnt, string, label,
fontset, scalefactor);
nStatus = MS_FAILURE;
@@ -1375,8 +1354,8 @@
#endif
else
- "Output format '%s' doesn't support WMS layers.",
+ "Output format '%s' doesn't support WMS layers.",
"msDrawWMSLayer()", image->format->name);
nStatus = MS_SUCCESS; /* Should we fail if output doesn't support WMS? */
@@ -1392,7 +1371,7 @@
** Function to render an individual shape, the style variable enables/disables the drawing of a single style
** versus a single style. This is necessary when drawing entire layers as proper overlay can only be achived
-** through caching. "querymapMode" parameter is used to tell msBindLayerToShape to not override the
+** through caching. "querymapMode" parameter is used to tell msBindLayerToShape to not override the
** QUERYMAP HILITE color.
int msDrawShape(mapObj *map, layerObj *layer, shapeObj *shape, imageObj *image, int style, int querymapMode)
@@ -1403,22 +1382,22 @@
double angle, length = 0.0;
int bLabelNoClip = MS_FALSE;
int annocallret = MS_FAILURE; /* Retvals for find-label-pnt calls */
int hasGeomTransform = MS_FALSE;
shapeObj nonClippedShape;
pointObj center; /* circle origin */
double r; /* circle radius */
int csz; /* clip over size */
double buffer;
int status = MS_FAILURE;
labelPathObj *annopath = NULL; /* Curved label path. Bug #1620 implementation */
/* set clipping rectangle just a bit larger than the map extent */
-/* Steve's original code
- cliprect.minx = map->extent.minx - 2*map->cellsize;
+/* Steve's original code
+ cliprect.minx = map->extent.minx - 2*map->cellsize;
cliprect.miny = map->extent.miny - 2*map->cellsize;
cliprect.maxx = map->extent.maxx + 2*map->cellsize;
cliprect.maxy = map->extent.maxy + 2*map->cellsize;
@@ -1435,7 +1414,7 @@
if(layer->class[c]->styles[s]->rangeitem != NULL)
msShapeToRange((layer->class[c]->styles[s]), shape);
/* changed when Tomas added CARTOLINE symbols
* adjust the clipping rectangle so that clipped polygon shapes with thick lines
* do not enter the image */
@@ -1458,10 +1437,11 @@
if(msBindLayerToShape(layer, shape, querymapMode) != MS_SUCCESS)
return MS_FAILURE; /* error message is set in msBindLayerToShape() */
if(shape->text && (layer->class[c]->label.encoding || layer->class[c]->label.wrap
||layer->class[c]->label.maxlength)) {
char *newtext=msTransformLabelText(map,image,&(layer->class[c]->label),shape->text);
+ //if(!newtext) return MS_FAILURE;
free(shape->text);
shape->text = newtext;
@@ -1485,7 +1465,7 @@
if(layer->transform == MS_TRUE) {
center.x = MS_MAP2IMAGE_X(center.x, map->extent.minx, map->cellsize);
center.y = MS_MAP2IMAGE_Y(center.y, map->extent.maxy, map->cellsize);
- r /= map->cellsize;
+ r /= map->cellsize;
} else
msOffsetPointRelativeTo(¢er, layer);
@@ -1536,7 +1516,7 @@
msFreeShape(&annoshape);
msClipPolylineRect(shape, cliprect);
if(shape->numlines == 0) return(MS_SUCCESS);
@@ -1554,7 +1534,7 @@
if( annopath ) {
labelObj label = layer->class[c]->label;
if(layer->labelcache) {
if(msAddLabel(map, layer->index, c, shape->index, shape->tileindex, NULL, annopath, shape->text, length, &label) != MS_SUCCESS) return(MS_FAILURE);
} else {
@@ -1580,7 +1560,7 @@
/* succesfully calculated it previously */
if ((bLabelNoClip == MS_TRUE && annocallret == MS_SUCCESS) || (msPolylineLabelPoint(shape, &annopnt, layer->class[c]->label.minfeaturesize, &angle, &length) == MS_SUCCESS)) {
if(label.angle != 0)
label.angle -= map->gt.rotation_angle;
@@ -1737,7 +1717,7 @@
break; /* end MS_LAYER_POINT */
- case MS_LAYER_LINE:
+ case MS_LAYER_LINE:
if(shape->type != MS_SHAPE_POLYGON && shape->type != MS_SHAPE_LINE) {
msSetError(MS_MISCERR, "Only polygon or line shapes can be drawn using a line layer definition.", "msDrawShape()");
return(MS_FAILURE);
@@ -1786,7 +1766,7 @@
if(shape->numlines == 0) {
if(hasGeomTransform)
- msFreeShape(&nonClippedShape);
+ msFreeShape(&nonClippedShape);
return(MS_SUCCESS);
msTransformShape(shape, map->extent, map->cellsize, image);
@@ -1795,7 +1775,7 @@
} else {
msOffsetShapeRelativeTo(shape, layer);
msOffsetShapeRelativeTo(&nonClippedShape, layer);
@@ -1814,11 +1794,11 @@
else if(style==-1 || s==style)
msDrawLineSymbol(&map->symbolset, image, shape, curStyle, layer->scalefactor);
/*RFC48: free non clipped shape if it was previously alloced/used*/
if(shape->text) {
/* Bug #1620 implementation */
@@ -1836,7 +1816,7 @@
} else {
/* FIXME: need to call msDrawTextLineGD() from here eventually */
/* msDrawLabel(image, label_line->point[0], shape->text, &label, &map->fontset, layer->scalefactor); */
msFreeLabelPathObj(annopath);
@@ -1845,7 +1825,7 @@
/* Use regular label algorithm if angle is AUTO or a number, or if ANGLE FOLLOW failed */
if ( layer->class[c]->label.autofollow == MS_FALSE || (!annopath && status != MS_FAILURE) ) {
- if((bLabelNoClip == MS_TRUE && annocallret == MS_SUCCESS) ||
+ if((bLabelNoClip == MS_TRUE && annocallret == MS_SUCCESS) ||
@@ -1872,7 +1852,7 @@
#ifdef USE_PROJ
if(layer->project && msProjectionsDiffer(&(layer->projection), &(map->projection))) {
if(msProjectShape(&layer->projection, &map->projection, shape) == MS_FAILURE ) {
-#ifdef notdef
+#ifdef notdef
msSetError(MS_PROJERR, "Reprojecting a shape failed.", "msDrawShape()" );
return MS_FAILURE;
#else
@@ -1918,7 +1898,7 @@
msClipPolygonRect(shape, cliprect);
return(MS_SUCCESS);
@@ -1974,21 +1954,21 @@
** Function to render an individual point, used as a helper function for mapscript only. Since a point
** can't carry attributes you can't do attribute based font size or angle.
-int msDrawPoint(mapObj *map, layerObj *layer, pointObj *point, imageObj *image,
+int msDrawPoint(mapObj *map, layerObj *layer, pointObj *point, imageObj *image,
int classindex, char *labeltext)
int s;
char *newtext;
classObj *theclass=layer->class[classindex];
labelObj *label=&(theclass->label);
#ifdef USE_PROJ
msProjectPoint(&layer->projection, &map->projection, point);
else
layer->project = MS_FALSE;
#endif
/*apply wrap character and encoding to the label text*/
if(labeltext &&(label->encoding || label->wrap || label->maxlength))
newtext = msTransformLabelText(map,image,label,labeltext);
@@ -2052,7 +2032,7 @@
default:
break; /* don't do anything with layer of other types */
if(newtext!=labeltext) /*free the transformed text if necessary*/
free(newtext);
@@ -2154,7 +2134,7 @@
int nReturnVal = MS_SUCCESS;
if(image) {
- if(MS_RENDERER_PLUGIN(image->format) || MS_RENDERER_GD(image->format) || MS_RENDERER_AGG(image->format)) {
+ if(MS_RENDERER_PLUGIN(image->format) || MS_RENDERER_GD(image->format) || MS_RENDERER_AGG(image->format)) {
pointObj p;
int i, l, priority;
@@ -2175,7 +2155,7 @@
const char *value;
#ifdef USE_AGG
- if(MS_RENDERER_AGG(image->format))
+ if(MS_RENDERER_AGG(image->format))
msAlphaGD2AGG(image);
else
#endif
@@ -2226,12 +2206,12 @@
return(-1);
marker_offset_x = MS_NINT(marker_width/2.0);
- marker_offset_y = MS_NINT(marker_height/2.0);
+ marker_offset_y = MS_NINT(marker_height/2.0);
marker_rect.minx = MS_NINT(cachePtr->point.x - .5 * marker_width);
marker_rect.miny = MS_NINT(cachePtr->point.y - .5 * marker_height);
marker_rect.maxx = marker_rect.minx + (marker_width-1);
- marker_rect.maxy = marker_rect.miny + (marker_height-1);
+ marker_rect.maxy = marker_rect.miny + (marker_height-1);
/* handle path following labels first (position does not matter) */
@@ -2305,7 +2285,7 @@
if(MS_VALID_COLOR(labelPtr->backgroundcolor))
get_metrics_line(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + labelPtr->offsetx), (marker_offset_y + labelPtr->offsety), labelPtr->angle, 1, billboard.line);
if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0)
msRectToPolygon(marker_rect, cachePtr->poly); /* save marker bounding polygon, part of overlap tests */
@@ -2330,7 +2310,7 @@
if(!cachePtr->labelpath && MS_VALID_COLOR(labelPtr->backgroundcolor)) {
styleObj style;
- initStyle(&style);
+ initStyle(&style);
if(MS_VALID_COLOR(labelPtr->backgroundshadowcolor)) {
MS_COPYCOLOR(&(style.color),&(labelPtr->backgroundshadowcolor));
style.offsetx = labelPtr->backgroundshadowsizex;
@@ -2376,7 +2356,7 @@
- * Generic function to tell the underline device that layer
+ * Generic function to tell the underline device that layer
* drawing is stating
@@ -2392,7 +2372,7 @@
#endif
#ifdef USE_PDF
- msImageStartLayerPDF(map, layer, image);
+ msImageStartLayerPDF(map, layer, image);
#endif
if( MS_RENDERER_SVG(image->format) )
msImageStartLayerSVG(map, layer, image);
@@ -2401,7 +2381,7 @@
* drawing is ending
@@ -2410,7 +2390,7 @@
- * Generic function to tell the underline device that shape
+ * Generic function to tell the underline device that shape
@@ -2428,22 +2408,22 @@
if( MS_RENDERER_PDF(map->outputformat) )
msDrawStartShapePDF(map, layer, image, shape);
#endif
* drawing is ending
-void msDrawEndShape(mapObj *map, layerObj *layer, imageObj *image,
+void msDrawEndShape(mapObj *map, layerObj *layer, imageObj *image,
shapeObj *shape)
- * take the value from the shape and use it to change the
+ * take the value from the shape and use it to change the
* color in the style to match the range map
int msShapeToRange(styleObj *style, shapeObj *shape)
@@ -2465,8 +2445,8 @@
- * Allow direct mapping of a value so that mapscript can use the
- * Ranges. The styls passed in is updated to reflect the right color
+ * Allow direct mapping of a value so that mapscript can use the
+ * Ranges. The styls passed in is updated to reflect the right color
* based on the fieldVal
int msValueToRange(styleObj *style, double fieldVal)
@@ -2476,7 +2456,7 @@
range = style->maxvalue - style->minvalue;
scaledVal = (fieldVal - style->minvalue)/range;
/*At this point, we know where on the range we need to be*/
/*However, we don't know how to map it yet, since RGB(A) can */
/*Go up or down*/
More information about the mapserver-commits
