[mapserver-commits] r8796 - sandbox/graphics
Sat Mar 14 05:20:21 EDT 2009
Author: tbonfort
Date: 2009-03-14 05:20:19 -0400 (Sat, 14 Mar 2009)
New Revision: 8796
   sandbox/graphics/mapprimitive.c
   sandbox/graphics/mapprimitive.h
more formatting reverts
Modified: sandbox/graphics/mapprimitive.c
--- sandbox/graphics/mapprimitive.c	2009-03-14 09:09:55 UTC (rev 8795)
+++ sandbox/graphics/mapprimitive.c	2009-03-14 09:20:19 UTC (rev 8796)
@@ -15,7 +15,7 @@
  * and/or sell copies of the Software, and to permit persons to whom the
  * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
+ * The above copyright notice and this permission notice shall be included in
  * all copies of this Software or works derived from this Software.
  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
@@ -46,7 +46,7 @@
 #endif
 #define NEARZERO (1.0e-30) /* 1/INFINITY */
-void msPrintShape(shapeObj *p)
+void msPrintShape(shapeObj *p)
   int i,j;
@@ -91,7 +91,7 @@
   shape->type = MS_SHAPE_NULL;
   shape->bounds.minx = shape->bounds.miny = -1;
   shape->bounds.maxx = shape->bounds.maxy = -1;
   /* attribute component */
   shape->values = NULL;
   shape->numvalues = 0;
@@ -128,7 +128,7 @@
   to->index = from->index;
   to->tileindex = from->tileindex;
-  if(from->values) {
+  if(from->values) {
     to->values = (char **)malloc(sizeof(char *)*from->numvalues);
     for(i=0; i<from->numvalues; i++)
       to->values[i] = strdup(from->values[i]);
@@ -152,7 +152,7 @@
   if(shape->values) msFreeCharArray(shape->values, shape->numvalues);
   if(shape->text) free(shape->text);
 #ifdef USE_GEOS
   msGEOSFreeGeometry(shape);
 #endif
@@ -177,8 +177,8 @@
   free( shape->line[line].point );
   if( line < shape->numlines - 1 ) {
-    memmove( shape->line + line,
-             shape->line + line + 1,
+    memmove( shape->line + line,
+             shape->line + line + 1,
              sizeof(lineObj) * (shape->numlines - line - 1) );
   shape->numlines--;
@@ -193,7 +193,7 @@
   shape->bounds.minx = shape->bounds.maxx = shape->line[0].point[0].x;
   shape->bounds.miny = shape->bounds.maxy = shape->line[0].point[0].y;
   for( i=0; i<shape->numlines; i++ ) {
     for( j=0; j<shape->line[i].numpoints; j++ ) {
       shape->bounds.minx = MS_MIN(shape->bounds.minx, shape->line[i].point[j].x);
@@ -205,9 +205,9 @@
 /* checks to see if ring r is an outer ring of shape */
-static int isOuterRing(shapeObj *shape, int r)
+static int isOuterRing(shapeObj *shape, int r)
-  int i, status=MS_TRUE;
+  int i, status=MS_TRUE;
   int result1, result2;
   if(shape->numlines == 1) return(MS_TRUE);
@@ -235,10 +235,10 @@
-** Returns a list of outer rings for shape (the list has one entry for each ring,
+** Returns a list of outer rings for shape (the list has one entry for each ring,
 ** MS_TRUE for outer rings).
-int *msGetOuterList(shapeObj *shape)
+int *msGetOuterList(shapeObj *shape)
   int i;
   int *list;
@@ -255,7 +255,7 @@
 ** Returns a list of inner rings for ring r in shape (given a list of outer rings).
-int *msGetInnerList(shapeObj *shape, int r, int *outerlist)
+int *msGetInnerList(shapeObj *shape, int r, int *outerlist)
   int i;
   int *list;
@@ -280,15 +280,15 @@
 ** Add point to a line object.
 ** Note that reallocating the point array larger for each point can
-** be pretty inefficient, so use this function sparingly.  Mostly
-** geometries creators should create their own working lineObj and
+** be pretty inefficient, so use this function sparingly.  Mostly
+** geometries creators should create their own working lineObj and
 ** then call msAddLine() to add it to a shape.
 int msAddPointToLine(lineObj *line, pointObj *point )
   line->numpoints += 1;
   line->point = (pointObj *) realloc(line->point, sizeof(pointObj) * line->numpoints);
   line->point[line->numpoints-1] = *point;
@@ -305,7 +305,7 @@
     msSetError(MS_MEMERR, NULL, "msAddLine()");
     return(MS_FAILURE);
   memcpy( lineCopy.point, new_line->point, sizeof(pointObj) * new_line->numpoints );
   return msAddLineDirectly( p, &lineCopy );
@@ -313,7 +313,7 @@
 ** Same as msAddLine(), except that this version "seizes" the points
-** array from the passed in line and uses it instead of copying it.
+** array from the passed in line and uses it instead of copying it.
 int msAddLineDirectly(shapeObj *p, lineObj *new_line)
@@ -331,7 +331,7 @@
   /* Copy the new line onto the end of the extended line array */
   c= p->numlines;
-  p->line[c].numpoints = new_line->numpoints;
+  p->line[c].numpoints = new_line->numpoints;
   p->line[c].point = new_line->point;
   /* strip points reference off the passed in lineObj */
@@ -357,7 +357,7 @@
   lineObj line={0,NULL};
   line.point = (pointObj *)malloc(sizeof(pointObj)*5);
   line.point[0].x = rect.minx;
   line.point[0].y = rect.miny;
   line.point[1].x = rect.minx;
@@ -368,9 +368,9 @@
   line.point[3].y = rect.miny;
   line.point[4].x = line.point[0].x;
   line.point[4].y = line.point[0].y;
   line.numpoints = 5;
   msAddLine(poly, &line);
   if(poly->numlines == 1) { /* poly was empty to begin with */
     poly->type = MS_SHAPE_POLYGON;
@@ -456,7 +456,7 @@
 ** Routine for clipping a polyline, stored in a shapeObj struct, to a
-** rectangle. Uses clipLine() function to create a new shapeObj.
+** rectangle. Uses clipLine() function to create a new shapeObj.
 void msClipPolylineRect(shapeObj *shape, rectObj rect)
@@ -472,7 +472,7 @@
   ** Don't do any clip processing of shapes completely within the
-  ** clip rectangle based on a comparison of bounds.   We could do
+  ** clip rectangle based on a comparison of bounds.   We could do
   ** something similar for completely outside, but that rarely occurs
   ** since the spatial query at the layer read level has generally already
   ** discarded all shapes completely outside the rect.
@@ -506,7 +506,7 @@
         } else { /* add just the last point */
           line.point[line.numpoints].x = x2;
           line.point[line.numpoints].y = y2;
-          line.numpoints++;
+          line.numpoints++;
         if((x2 != shape->line[i].point[j].x) || (y2 != shape->line[i].point[j].y)) {
@@ -524,7 +524,7 @@
     free(line.point);
     line.numpoints = 0; /* new line */
   for (i=0; i<shape->numlines; i++) free(shape->line[i].point);
   free(shape->line);
@@ -546,13 +546,13 @@
   msInitShape(&tmp);
   if(shape->numlines == 0) /* nothing to clip */
     return;
@@ -571,12 +571,12 @@
     line.numpoints = 0;
     for (i = 0; i < shape->line[j].numpoints-1; i++) {
       x1 = shape->line[j].point[i].x;
       y1 = shape->line[j].point[i].y;
       x2 = shape->line[j].point[i+1].x;
       y2 = shape->line[j].point[i+1].y;
       deltax = x2-x1;
       if (deltax == 0) { /* bump off of the vertical */
         deltax = (x1 > rect.minx) ? -NEARZERO : NEARZERO ;
@@ -585,7 +585,7 @@
       if (deltay == 0) { /* bump off of the horizontal */
         deltay = (y1 > rect.miny) ? -NEARZERO : NEARZERO ;
       if (deltax > 0) { /*  points to right */
         xin = rect.minx;
         xout = rect.maxx;
@@ -600,10 +600,10 @@
         yin = rect.maxy;
         yout = rect.miny;
       tinx = (xin - x1)/deltax;
       tiny = (yin - y1)/deltay;
       if (tinx < tiny) { /* hits x first */
         tin1 = tinx;
         tin2 = tiny;
@@ -611,7 +611,7 @@
         tin1 = tiny;
         tin2 = tinx;
       if (1 >= tin1) {
         if (0 < tin1) {
           line.point[line.numpoints].x = xin;
@@ -621,9 +621,9 @@
         if (1 >= tin2) {
           toutx = (xout - x1)/deltax;
           touty = (yout - y1)/deltay;
           tout = (toutx < touty) ? toutx : touty ;
           if (0 < tin2 || 0 < tout) {
             if (tin2 <= tout) {
               if (0 < tin2) {
@@ -677,7 +677,7 @@
     free(line.point);
   } /* next line */
   free(shape->line);
@@ -695,8 +695,8 @@
   double x=0, y=0;
   if ( msCheckParentPointer(layer->map,"map")==MS_FAILURE )
     return;
   if(layer->transform == MS_TRUE) return; /* nothing to do */
   if(layer->units == MS_PERCENTAGES) {
@@ -750,7 +750,7 @@
 ** offsets a shape relative to an image position
-void msOffsetShapeRelativeTo(shapeObj *shape, layerObj *layer)
+void msOffsetShapeRelativeTo(shapeObj *shape, layerObj *layer)
   int i, j;
   double x=0, y=0;
@@ -758,8 +758,8 @@
     return;
     for (i=0; i<shape->numlines; i++) {
       for (j=0; j<shape->line[i].numpoints; j++) {
@@ -859,7 +859,7 @@
   if(shape->type == MS_SHAPE_LINE || shape->type == MS_SHAPE_POLYGON) { /* remove co-linear vertices */
-    for(i=0; i<shape->numlines; i++) { /* for each part */
+    for(i=0; i<shape->numlines; i++) { /* for each part */
       for(j=0; j < shape->line[i].numpoints; j++ ) {
         shape->line[i].point[j].x = MS_IMAGE2MAP_X(shape->line[i].point[j].x, extent.minx, cellsize);
         shape->line[i].point[j].y = MS_IMAGE2MAP_Y(shape->line[i].point[j].y, extent.maxy, cellsize);
@@ -882,7 +882,7 @@
 ** Not a generic intersection test, we KNOW the lines aren't parallel or coincident. To be used with the next
 ** buffering code only. See code in mapsearch.c for a boolean test for intersection.
-static pointObj generateLineIntersection(pointObj a, pointObj b, pointObj c, pointObj d)
+static pointObj generateLineIntersection(pointObj a, pointObj b, pointObj c, pointObj d)
   pointObj p;
   double r;
@@ -890,8 +890,8 @@
   if(b.x == c.x && b.y == c.y) return(b);
-  numerator = ((a.y-c.y)*(d.x-c.x) - (a.x-c.x)*(d.y-c.y));
-  denominator = ((b.x-a.x)*(d.y-c.y) - (b.y-a.y)*(d.x-c.x));
+  numerator = ((a.y-c.y)*(d.x-c.x) - (a.x-c.x)*(d.y-c.y));
+  denominator = ((b.x-a.x)*(d.y-c.y) - (b.y-a.y)*(d.x-c.x));
   r = numerator/denominator;
@@ -907,13 +907,13 @@
   pointObj a;
   lineObj inside, outside;
   double angle;
-  double dx, dy;
+  double dx, dy;
   for (i = 0; i < p->numlines; i++) {
     inside.point = (pointObj *)malloc(sizeof(pointObj)*p->line[i].numpoints);
     outside.point = (pointObj *)malloc(sizeof(pointObj)*p->line[i].numpoints);
-    inside.numpoints = outside.numpoints = p->line[i].numpoints;
+    inside.numpoints = outside.numpoints = p->line[i].numpoints;
     angle = asin(MS_ABS(p->line[i].point[1].x - p->line[i].point[0].x)/sqrt((pow((p->line[i].point[1].x - p->line[i].point[0].x),2.0) + pow((p->line[i].point[1].y - p->line[i].point[0].y),2.0))));
     if(p->line[i].point[0].x < p->line[i].point[1].x)
@@ -929,7 +929,7 @@
     inside.point[1].x = p->line[i].point[1].x + dx;
     inside.point[0].y = p->line[i].point[0].y + dy;
     inside.point[1].y = p->line[i].point[1].y + dy;
     outside.point[0].x = p->line[i].point[0].x - dx;
     outside.point[1].x = p->line[i].point[1].x - dx;
     outside.point[0].y = p->line[i].point[0].y - dy;
@@ -951,7 +951,7 @@
       inside.point[j].x = p->line[i].point[j].x + dx;
       a.y = p->line[i].point[j-1].y + dy;
       inside.point[j].y = p->line[i].point[j].y + dy;
-      inside.point[j-1] = generateLineIntersection(inside.point[j-2], inside.point[j-1], a, inside.point[j]);
+      inside.point[j-1] = generateLineIntersection(inside.point[j-2], inside.point[j-1], a, inside.point[j]);
       a.x = p->line[i].point[j-1].x - dx;
       outside.point[j].x = p->line[i].point[j].x - dx;
@@ -968,7 +968,7 @@
     free(inside.point);
     free(outside.point);
   return;
@@ -983,7 +983,7 @@
   return (MS_ABS(s/2));
-double msGetPolygonArea(shapeObj *p)
+double msGetPolygonArea(shapeObj *p)
   int i;
   double area=0;
@@ -1001,7 +1001,7 @@
 ** Computes the center of gravity for a polygon based on it's largest outer ring only.
-static int getPolygonCenterOfGravity(shapeObj *p, pointObj *lp)
+static int getPolygonCenterOfGravity(shapeObj *p, pointObj *lp)
   int i, j;
   double area=0;
@@ -1058,7 +1058,7 @@
   lp->x = cent_weight_x / total_len;
   lp->y = cent_weight_y / total_len;
   return(MS_SUCCESS);
@@ -1095,7 +1095,7 @@
     lp->y = cp.y;
     break;
   case 1: /* centroid */
-    if(getPolygonCentroid(p, lp, &miny, &maxy) != MS_SUCCESS) return(MS_FAILURE);
+    if(getPolygonCentroid(p, lp, &miny, &maxy) != MS_SUCCESS) return(MS_FAILURE);
     break;
   case 2: /* center of gravity */
     if(getPolygonCenterOfGravity(p, lp) != MS_SUCCESS) return(MS_FAILURE);
@@ -1137,16 +1137,16 @@
     y = lp->y;
-    /* need to find a y that won't intersect any vertices exactly */
+    /* need to find a y that won't intersect any vertices exactly */
     max = y - 1; /* first initializing min, max to be any 2 pnts on either side of y */
     min = y + 1;
     for(j=0; j<p->numlines; j++) {
       if((min < y) && (max >= y))  break;
       for(i=0; i < p->line[j].numpoints; i++) {
-        if(p->line[j].point[i].y < y)
+        if(p->line[j].point[i].y < y)
           min = p->line[j].point[i].y;
-        if(p->line[j].point[i].y >= y)
+        if(p->line[j].point[i].y >= y)
           max = p->line[j].point[i].y;
@@ -1161,33 +1161,33 @@
-    if(min == max)
+    if(min == max)
       return (MS_FAILURE);
-    else
-      y = (max + min)/2.0;
+    else
+      y = (max + min)/2.0;
     nfound = 0;
     for(j=0; j<p->numlines; j++) { /* for each line */
       point1 = &( p->line[j].point[p->line[j].numpoints-1] );
         point2 = &( p->line[j].point[i] );
         if(EDGE_CHECK(point1->y, y, point2->y) == CLIP_MIDDLE) {
           if(point1->y == point2->y)
             continue; /* ignore horizontal edges */
-          else
+          else
             slope = (point2->x - point1->x) / (point2->y - point1->y);
           x = point1->x + (y - point1->y)*slope;
           intersect[nfound++] = x;
         } /* end checking this edge */
         point1 = point2; /* next edge */
     } /* finished line */
     /* sort the intersections */
     do {
       wrong_order = 0;
@@ -1198,7 +1198,7 @@
     } while(wrong_order);
     /* find longest span */
     for(i=0; i < nfound; i += 2) {
       len = fabs(intersect[i] - intersect[i+1]);
@@ -1211,16 +1211,16 @@
   } else { /* center vertically, fix x */
     x = lp->x;
-    /* need to find a x that won't intersect any vertices exactly */
+    /* need to find a x that won't intersect any vertices exactly */
     max = x - 1; /* first initializing min, max to be any 2 pnts on either side of x */
     min = x + 1;
       if((min < x) && (max >= x))  break;
-        if(p->line[j].point[i].x < x)
+        if(p->line[j].point[i].x < x)
           min = p->line[j].point[i].x;
-        if(p->line[j].point[i].x >= x)
+        if(p->line[j].point[i].x >= x)
           max = p->line[j].point[i].x;
@@ -1235,20 +1235,20 @@
-    if(min == max)
+    if(min == max)
-    else
+    else
       x = (max + min)/2.0;
     nfound = 0;
         if(EDGE_CHECK(point1->x, x, point2->x) == CLIP_MIDDLE) {
           if(point1->x == point2->x)
             continue; /* ignore vertical edges */
           else if(point1->y == point2->y)
@@ -1260,11 +1260,11 @@
           intersect[nfound++] = y;
     do {
       wrong_order = 0;
@@ -1275,11 +1275,11 @@
-      if(len > max_len) {
+      if(len > max_len) {
         max_len = len;
         lp->y = (intersect[i] + intersect[i+1])/2;
         // lp->x = x;
@@ -1306,7 +1306,7 @@
   int segment_index, line_index, temp_segment_index;
   int i, j;
   double theta;
   temp_segment_index = segment_index = line_index = 0;
   total_length = 0;
@@ -1347,19 +1347,19 @@
   lp->x = (p->line[i].point[j].x + p->line[i].point[j-1].x)/2.0;
   lp->y = (p->line[i].point[j].y + p->line[i].point[j-1].y)/2.0;
   theta = asin(MS_ABS(p->line[i].point[j].x - p->line[i].point[j-1].x)/sqrt((pow((p->line[i].point[j].x - p->line[i].point[j-1].x),2.0) + pow((p->line[i].point[j].y - p->line[i].point[j-1].y),2.0))));
   if(p->line[i].point[j-1].x < p->line[i].point[j].x) { /* i.e. to the left */
     if(p->line[i].point[j-1].y < p->line[i].point[j].y) /* i.e. below */
       *angle = -(90.0 - MS_RAD_TO_DEG*theta);
     else
-      *angle = (90.0 - MS_RAD_TO_DEG*theta);
+      *angle = (90.0 - MS_RAD_TO_DEG*theta);
   } else {
     else
-      *angle = -(90.0 - MS_RAD_TO_DEG*theta);
+      *angle = -(90.0 - MS_RAD_TO_DEG*theta);
   return(MS_SUCCESS);
@@ -1379,7 +1379,7 @@
   int segment_index, line_index;
   int numchars;
   int i,j,k, inc, final_j;
   double direction;
   rectObj bbox;
@@ -1387,7 +1387,7 @@
   double *offsets;
   double size, t;
   double cx, cy; /* centre of a character, x & y values. */
   double theta;
   double dx, dy, w, cos_t, sin_t;
@@ -1404,7 +1404,7 @@
   offsets = NULL;
-  /* assume success */
+  /* assume success */
   *status = MS_SUCCESS;
 #ifndef GD_HAS_FTEX_XSHOW
@@ -1412,30 +1412,30 @@
 #else
   numchars = msGetNumGlyphs(string);
   /* skip the label and use the normal algorithm if it has fewer than 2 characters */
   if(numchars < 2)
     goto FAILURE;
   total_length = max_line_length = 0.0;
   /* determine longest line segment */
   segment_lengths = (double **) malloc(sizeof(double *) * p->numlines);
   for(i=0; i<p->numlines; i++) {
-    segment_lengths[i] = (double*) malloc(sizeof(double) * p->line[i].numpoints);
+    segment_lengths[i] = (double*) malloc(sizeof(double) * p->line[i].numpoints);
     line_length = 0;
     for (j=1; j<p->line[i].numpoints; j++) {
       segment_length = sqrt( pow((p->line[i].point[j].x - p->line[i].point[j-1].x), 2.0) +
                              pow((p->line[i].point[j].y - p->line[i].point[j-1].y), 2.0) );
       line_length += segment_length;
-      segment_lengths[i][j-1] = segment_length;
+      segment_lengths[i][j-1] = segment_length;
     total_length += line_length;
     if(line_length > max_line_length) {
       line_index = i;
       max_line_length = line_length;
@@ -1443,7 +1443,7 @@
   i = line_index;
   if (((min_length != -1) && (total_length < min_length))) { /* too short */
     *status = MS_FAILURE;
     goto FAILURE;
@@ -1456,7 +1456,7 @@
   if(p->line[i].numpoints == 2) /* use the regular angled text algorithm */
     goto FAILURE;
   /* determine the total length of the text */
   if (msGetLabelSize(img,string, label, &bbox, fontset, scalefactor, MS_FALSE, &offsets) == MS_FAILURE) {
@@ -1469,19 +1469,19 @@
   font = msLookupHashTable(&(fontset->fonts), label->font);
   if(!font) {
-    if(label->font)
+    if(label->font)
       msSetError(MS_TTFERR, "Requested font (%s) not found.", "msPolylineLabelPath()", label->font);
     else
       msSetError(MS_TTFERR, "Requested font (NULL) not found.", "msPolylineLabelPath()");
     goto FAILURE;
   text_length = letterspacing * (bbox.maxx - bbox.minx);
   ** if the text length is way longer than the line, skip adding the
-  ** label if it isn't forced (long extrapolated labels tend to be ugly)
+  ** label if it isn't forced (long extrapolated labels tend to be ugly)
   if ( text_length > 1.5 * max_line_length && label->force == MS_FALSE ) {
@@ -1495,7 +1495,7 @@
   labelpath->angles = (double *) malloc(sizeof(double) * (labelpath->path.numpoints));
   msInitShape(&(labelpath->bounds));
   ** The bounds will have two points for each character plus an endpoint:
   ** the UL corners of each bbox will be tied together and the LL corners
   ** will be tied together.
@@ -1507,7 +1507,7 @@
   text_start_length = (max_line_length - text_length) / 2.0;
   /* the text is longer than the line: extrapolate the first and last segments */
-  if(text_start_length < 0.0) {
+  if(text_start_length < 0.0) {
     j = 0;
     final_j = p->line[i].numpoints - 1;
     fwd_line_length = rev_line_length = 0;
@@ -1520,7 +1520,7 @@
     j--;
-    /* determine the last segment */
+    /* determine the last segment */
     while(rev_line_length < text_start_length) {
@@ -1532,8 +1532,8 @@
   if(final_j == 0)
     final_j = 1;
-  /* determine if the line is mostly left to right or right to left,
+  /* determine if the line is mostly left to right or right to left,
      see bug 1620 discussion by Steve Woodbridge */
   direction = 0;
   k = j;
@@ -1542,7 +1542,7 @@
     k++;
-  if(direction > 0) {
+  if(direction > 0) {
     inc = 1; /* j is already correct */
     /* length of the segment containing the starting point */
@@ -1556,22 +1556,22 @@
     segment_length = segment_lengths[i][j-1];
-    t = 1 - (rev_line_length - text_start_length) / segment_length;
+    t = 1 - (rev_line_length - text_start_length) / segment_length;
   distance_along_segment = t * segment_length; /* starting point */
   theta = 0;
   k = 0;
   w = 0;
   while ( k < labelpath->path.numpoints ) {
     int m;
     double x,y;
     x = t * (p->line[i].point[j+inc].x - p->line[i].point[j].x) + p->line[i].point[j].x;
     y = t * (p->line[i].point[j+inc].y - p->line[i].point[j].y) + p->line[i].point[j].y;
     ** This used to be a series of if-then-else's, but that fails for short (length < 4)
     ** labels. There may be small speed-ups possible here. (bug 1921)
@@ -1580,68 +1580,68 @@
     if ( k == 0) {
       labelpath->path.point[k].x += (kernel[0] + kernel[1]) * x;
       labelpath->path.point[k].y += (kernel[0] + kernel[1]) * y;
     if ( k == 1) {
       labelpath->path.point[k].x += kernel[0] * x;
       labelpath->path.point[k].y += kernel[0] * y;
     if ( k == labelpath->path.numpoints - 2) {
       labelpath->path.point[k].x += kernel[4] * x;
-      labelpath->path.point[k].y += kernel[4] * y;
+      labelpath->path.point[k].y += kernel[4] * y;
     if ( k == labelpath->path.numpoints - 1) {
       labelpath->path.point[k].x += (kernel[3] + kernel[4]) * x;
       labelpath->path.point[k].y += (kernel[3] + kernel[4]) * y;
     for(m = 0; m < kernel_size; m++) {
       if(m + k - 2 < 0 || m + k - 2 > labelpath->path.numpoints - 1)
         continue;
       labelpath->path.point[k+m-2].x += kernel[m]*x;
       labelpath->path.point[k+m-2].y += kernel[m]*y;
     w = letterspacing*offsets[k];
     /* add the character's width to the distance along the line */
     distance_along_segment += w;
-    /* if we still have segments left and we've past the current segment, move to the next one */
-    if(inc == 1 && j < p->line[i].numpoints - 2) {
+    /* if we still have segments left and we've past the current segment, move to the next one */
+    if(inc == 1 && j < p->line[i].numpoints - 2) {
       while ( j < p->line[i].numpoints - 2 && distance_along_segment > segment_lengths[i][j] ) {
-        distance_along_segment -= segment_lengths[i][j];
+        distance_along_segment -= segment_lengths[i][j];
         j += inc; /* move to next segment */
       segment_length = segment_lengths[i][j];
     } else if( inc == -1 && j > 1 ) {
       while ( j > 1 && distance_along_segment > segment_lengths[i][j-1] ) {
         distance_along_segment -= segment_lengths[i][j-1];
     /* Recalculate interpolation parameter */
     t = distance_along_segment / segment_length;
     k++;
   /* pre-calc the character's centre y value.  Used for rotation adjustment. */
   cy = -size / 2.0;
   labelpath->path.point[0].x /= kernel_normal;
   labelpath->path.point[0].y /= kernel_normal;
   /* Average the points and calculate each angle */
   for (k = 1; k <= labelpath->path.numpoints; k++) {
-    if ( k < labelpath->path.numpoints ) {
+    if ( k < labelpath->path.numpoints ) {
       labelpath->path.point[k].x /= kernel_normal;
       labelpath->path.point[k].y /= kernel_normal;
       dx = labelpath->path.point[k].x - labelpath->path.point[k-1].x;
@@ -1660,23 +1660,23 @@
       goto FAILURE;
     /* msDebug("s: %c (x,y): (%0.2f,%0.2f) t: %0.2f\n", string[k-1], labelpath->path.point[k-1].x, labelpath->path.point[k-1].y, theta); */
     labelpath->angles[k-1] = theta;
     /* Move the previous point so that when the character is rotated and
        placed it is centred on the line */
     cos_t = cos(theta);
     sin_t = sin(theta);
     w = letterspacing*offsets[k-1];
     cx = 0; /* Center the character vertically only */
     dx = - (cx * cos_t + cy * sin_t);
     dy = - (cy * cos_t - cx * sin_t);
     labelpath->path.point[k-1].x += dx;
     labelpath->path.point[k-1].y += dy;
@@ -1691,7 +1691,7 @@
     bbox.maxy += label->buffer;
     bbox.minx -= label->buffer;
     bbox.miny -= label->buffer;
       /* Transform the bbox too.  We take the UL and LL corners and rotate
          then translate them. */
@@ -1703,12 +1703,12 @@
       bounds.point[bounds.numpoints - k - 1].y = (bbox.miny * cos_t - bbox.minx * sin_t) + labelpath->path.point[k-1].y;
     } else {
       /* This is the last character in the string so we take the UR and LR
          corners of the bbox */
       bounds.point[k-1].x = (bbox.maxx * cos_t + bbox.maxy * sin_t) + labelpath->path.point[k-1].x;
       bounds.point[k-1].y = (bbox.maxy * cos_t - bbox.maxx * sin_t) + labelpath->path.point[k-1].y;
       bounds.point[bounds.numpoints - k - 1].x = (bbox.maxx * cos_t + bbox.miny * sin_t) + labelpath->path.point[k-1].x;
       bounds.point[bounds.numpoints - k - 1].y = (bbox.miny * cos_t - bbox.maxx * sin_t) + labelpath->path.point[k-1].y;
@@ -1718,13 +1718,13 @@
   /* Close the bounds */
   bounds.point[bounds.numpoints - 1].x = bounds.point[0].x;
   bounds.point[bounds.numpoints - 1].y = bounds.point[0].y;
   /* Convert the bounds to a shape and store them in the labelpath */
   if ( msAddLineDirectly(&(labelpath->bounds), &bounds) == MS_FAILURE ) {
     goto FAILURE;
   msComputeBounds(&(labelpath->bounds));
   if ( segment_lengths ) {
@@ -1732,9 +1732,9 @@
       free(segment_lengths[i]);
     free(segment_lengths);
   free(offsets);
   return labelpath;
 #endif
@@ -1744,15 +1744,15 @@
   if ( offsets )
     free(offsets);
   if ( labelpath ) {
     msFreeLabelPathObj(labelpath);
     labelpath = NULL;
   return NULL;
@@ -1760,12 +1760,12 @@
    Pretty printing of primitive objects
-void msRectToFormattedString(rectObj *rect, char *format, char *buffer, int buffer_length)
+void msRectToFormattedString(rectObj *rect, char *format, char *buffer, int buffer_length)
   snprintf(buffer, buffer_length, format, rect->minx, rect->miny, rect->maxx, rect->maxy);
-void msPointToFormattedString(pointObj *point, const char *format, char *buffer, int buffer_length)
+void msPointToFormattedString(pointObj *point, const char *format, char *buffer, int buffer_length)
 #ifdef USE_POINT_Z_M
   snprintf(buffer, buffer_length, format, point->x, point->y, point->z, point->m);
Modified: sandbox/graphics/mapprimitive.h
--- sandbox/graphics/mapprimitive.h	2009-03-14 09:09:55 UTC (rev 8795)
+++ sandbox/graphics/mapprimitive.h	2009-03-14 09:20:19 UTC (rev 8796)
@@ -15,7 +15,7 @@
@@ -46,8 +46,8 @@
   double x;
   double y;
-  double z;
-  double m;
+  double z;
+  double m;
 #endif
 } pointObj;
@@ -86,7 +86,7 @@
   int tileindex;
   int classindex;
   char *text;
 } shapeObj;
 typedef lineObj multipointObj;
@@ -105,7 +105,7 @@
 #ifndef SWIG
 typedef struct {
   int  need_geotransform;
-  double rotation_angle;
+  double rotation_angle;
   double geotransform[6];    /* Pixel/line to georef. */
   double invgeotransform[6]; /* georef to pixel/line */
 } geotransformObj;
