[mapserver-commits] r8798 - sandbox/graphics
Sat Mar 14 05:42:51 EDT 2009
Author: tbonfort
Date: 2009-03-14 05:42:51 -0400 (Sat, 14 Mar 2009)
New Revision: 8798
   sandbox/graphics/mapoutput.c
formatting
Modified: sandbox/graphics/mapoutput.c
--- sandbox/graphics/mapoutput.c	2009-03-14 09:38:14 UTC (rev 8797)
+++ sandbox/graphics/mapoutput.c	2009-03-14 09:42:51 UTC (rev 8798)
@@ -15,7 +15,7 @@
  * and/or sell copies of the Software, and to permit persons to whom the
  * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
+ * The above copyright notice and this permission notice shall be included in
  * all copies of this Software or works derived from this Software.
  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
@@ -32,7 +32,7 @@
 MS_CVSID("$Id$")
-static outputFormatObj *msAllocOutputFormat( mapObj *map, const char *name,
+static outputFormatObj *msAllocOutputFormat( mapObj *map, const char *name,
                                              const char *driver );
@@ -58,32 +58,32 @@
             will be derived from the DRIVER or default to the value for
             untyped binary data will be used.  (optional - may be NULL)
- DRIVER - This indicates which internal driver mechanism is to be used.
+ DRIVER - This indicates which internal driver mechanism is to be used.
           Anything prefixed by "GDAL/" will be handled by the GDAL driver, with
           the remainder taken as the GDAL format name. (required)
  IMAGEMODE - Has one of "PC256", "RGB", or "RGBA" indicating whether
              the imaging should be done to a 256 pseudo-colored, 24bit RGB, or
-             32bit RGBA (A=alpha/transparency) result image.  Note that the
-             IMAGEMODE actually affects how all the rendering for the map is
-             done, long before it is output to a particular output format.
-             The default value is the traditional "PC256".  Some output
+             32bit RGBA (A=alpha/transparency) result image.  Note that the
+             IMAGEMODE actually affects how all the rendering for the map is
+             done, long before it is output to a particular output format.
+             The default value is the traditional "PC256".  Some output
              formats can only support some IMAGEMODE values. (optional)
-             Translate as MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB and
-             MS_IMAGEMODE_RGBA.
+             Translate as MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB and
+             MS_IMAGEMODE_RGBA.
              Not too sure what this should be set to for output formats like
              flash and SVG.
- TRANSPARENT - A value of "ON" or "OFF" indicating whether transparency
+ TRANSPARENT - A value of "ON" or "OFF" indicating whether transparency
                support should be enabled.  Same as the old TRANSPARENT flag
                at the MAP level.
- FORMATOPTION - Contains an argument for the specific driver used.  There may
-                be any number of format options for a given OUTPUTFORMAT
+ FORMATOPTION - Contains an argument for the specific driver used.  There may
+                be any number of format options for a given OUTPUTFORMAT
                 declaration.  FORMATOPTION will be used to encode the older
-                INTERLACE, and QUALITY values.
+                INTERLACE, and QUALITY values.
                 Handled as a MapServer style CharArray.
@@ -107,16 +107,16 @@
     /* select the current outputformat into map->outputformat */
     format = msSelectOutputFormat( map, map->imagetype );
-    if( format == NULL )
+    if( format == NULL )
-        msSetError(MS_MISCERR,
-                   "Unable to select IMAGETYPE `%s'.",
+        msSetError(MS_MISCERR,
+                   "Unable to select IMAGETYPE `%s'.",
                    "msPostMapParseOutputFormatSetup()",
                    map->imagetype ? map->imagetype : "(null)" );
         return MS_FAILURE;
-    msApplyOutputFormat( &(map->outputformat), format,
+    msApplyOutputFormat( &(map->outputformat), format,
                          map->transparent, map->interlace, map->imagequality );
     return MS_SUCCESS;
@@ -126,7 +126,7 @@
 /*                    msCreateDefaultOutputFormat()                     */
-outputFormatObj *msCreateDefaultOutputFormat( mapObj *map,
+outputFormatObj *msCreateDefaultOutputFormat( mapObj *map,
@@ -219,7 +219,7 @@
         format->renderer = MS_RENDER_WITH_AGG;
 #endif
 #if defined(USE_CAIRO)
     if( strcasecmp(driver,"CAIRO/PNG") == 0 )
@@ -257,19 +257,23 @@
 		format->renderer = MS_RENDER_WITH_CAIRO;
 		format->r = msCreateRenderer(MS_RENDER_WITH_CAIRO);
 #endif
-#if defined(USE_OGL)
-    if( strcasecmp(driver,"OGL/PNG") == 0 )
-        format = msAllocOutputFormat( map, "oglpng24", driver );
-        format->mimetype = strdup("image/png; mode=24bit");
-        format->imagemode = MS_IMAGEMODE_RGB;
-        format->extension = strdup("png");
-        format->renderer = MS_RENDER_WITH_OGL;
-        format->r = msCreateRenderer(MS_RENDER_WITH_OGL);
-#endif
+#if defined(USE_OGL)
+    if( strcasecmp(driver,"OGL/PNG") == 0 )
+        format = msAllocOutputFormat( map, "oglpng24", driver );
+        format->mimetype = strdup("image/png; mode=24bit");
+        format->imagemode = MS_IMAGEMODE_RGB;
+        format->extension = strdup("png");
+        format->renderer = MS_RENDER_WITH_OGL;
+        format->r = msCreateRenderer(MS_RENDER_WITH_OGL);
+#endif
 #ifdef USE_MING_FLASH
     if( strcasecmp(driver,"swf") == 0 )
@@ -417,7 +421,7 @@
 /*                        msAllocOutputFormat()                         */
@@ -459,7 +463,7 @@
         map->outputformatlist[map->numoutputformats-1] = format;
         format->refcount++;
     return format;
@@ -469,7 +473,7 @@
 /*      Add an output format  .                                         */
 /*      http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=511           */
-int msAppendOutputFormat(mapObj *map, outputFormatObj *format)
+int msAppendOutputFormat(mapObj *map, outputFormatObj *format)
 /*      Attach to map.                                                  */
@@ -487,7 +491,7 @@
         format->refcount++;
     return map->numoutputformats;
@@ -513,7 +517,7 @@
         else
             i = msGetOutputFormatIndex(map, name);
-            if (i >= 0)
+            if (i >= 0)
                 map->numoutputformats--;
                 if( map->outputformatlist[i]->refcount-- < 1 )
@@ -553,7 +557,7 @@
                           map->outputformatlist[i]->mimetype) == 0 )
             return i;
     for( i = 0; i < map->numoutputformats; i++ )
         if( strcasecmp(imagetype,map->outputformatlist[i]->name) == 0 )
@@ -567,7 +571,7 @@
 /*                        msSelectOutputFormat()                        */
-outputFormatObj *msSelectOutputFormat( mapObj *map,
+outputFormatObj *msSelectOutputFormat( mapObj *map,
                                        const char *imagetype )
@@ -576,7 +580,7 @@
     if( map == NULL || imagetype == NULL || strlen(imagetype) == 0 )
         return NULL;
     index = msGetOutputFormatIndex(map, imagetype);
     if (index >= 0)
         format = map->outputformatlist[index];
@@ -592,13 +596,13 @@
             format = map->outputformatlist[i];
     for( i = 0; i < map->numoutputformats && format == NULL; i++ )
     if (format)
         if (map->imagetype)
@@ -616,10 +620,10 @@
 /*                        msApplyOutputFormat()                         */
-void msApplyOutputFormat( outputFormatObj **target,
+void msApplyOutputFormat( outputFormatObj **target,
                           outputFormatObj *format,
-                          int transparent,
-                          int interlaced,
+                          int transparent,
+                          int interlaced,
                           int imagequality )
@@ -629,7 +633,7 @@
     assert( target != NULL );
     if( *target != NULL && --((*target)->refcount) < 1 )
         formatToFree = *target;
@@ -656,7 +660,7 @@
     if( imagequality != MS_NOOVERRIDE && old_imagequality != imagequality )
         change_needed = MS_TRUE;
-    old_interlaced =
+    old_interlaced =
         strcasecmp(msGetOutputFormatOption( format, "INTERLACE", "ON"),
                    "OFF") != 0;
     if( interlaced != MS_NOOVERRIDE && !interlaced != !old_interlaced )
@@ -725,12 +729,12 @@
     dst->imagemode = src->imagemode;
     dst->renderer = src->renderer;
     dst->r = src->r;
     dst->transparent = src->transparent;
     dst->bands = src->bands;
     dst->numformatoptions = src->numformatoptions;
-    dst->formatoptions = (char **)
+    dst->formatoptions = (char **)
         malloc(sizeof(char *) * src->numformatoptions );
     for( i = 0; i < src->numformatoptions; i++ )
@@ -748,8 +752,8 @@
 /*      options are in "KEY=VALUE" format.                              */
-const char *msGetOutputFormatOption( outputFormatObj *format,
-                                     const char *optionkey,
+const char *msGetOutputFormatOption( outputFormatObj *format,
+                                     const char *optionkey,
                                      const char *defaultresult )
@@ -787,7 +791,7 @@
     sprintf( newline, "%s=%s", key, value );
 /*      Does this key already occur?  If so replace it.                 */
@@ -808,8 +812,8 @@
 /*      otherwise, we need to grow the list.                            */
     format->numformatoptions++;
-    format->formatoptions = (char **)
-        realloc( format->formatoptions,
+    format->formatoptions = (char **)
+        realloc( format->formatoptions,
                  sizeof(char*) * format->numformatoptions );
     format->formatoptions[format->numformatoptions-1] = newline;
@@ -833,7 +837,7 @@
     for( i = 0; i < map->numoutputformats && mime_count < max_mime; i++ )
         int  j;
         if( map->outputformatlist[i]->mimetype == NULL )
             continue;
@@ -864,7 +868,7 @@
         int  j;
             continue;
@@ -897,7 +901,7 @@
         int  j;
             continue;
@@ -911,7 +915,7 @@
         if( j == mime_count && map->outputformatlist[i]->driver &&
             (strncasecmp(map->outputformatlist[i]->driver, "GD/", 3)==0 ||
              strncasecmp(map->outputformatlist[i]->driver, "GDAL/", 5)==0 ||
-             strcasecmp(map->outputformatlist[i]->driver, "svg")==0))
+             strcasecmp(map->outputformatlist[i]->driver, "svg")==0))
             mime_list[mime_count++] = map->outputformatlist[i]->mimetype;
@@ -932,24 +936,24 @@
     int result = MS_TRUE;
-    format->bands =
+    format->bands =
             atoi(msGetOutputFormatOption( format, "BAND_COUNT", "1" ));
     /* Enforce the requirement that GD/JPEG be RGB and TRANSPARENT=OFF */
     if( strcasecmp(format->driver,"GD/JPEG") == 0 && format->transparent )
         msDebug( "GD/JPEG OUTPUTFORMAT %s has TRANSPARENT set ON, but this is not supported.\n"
-                 "It has been disabled.\n",
+                 "It has been disabled.\n",
                  format->name );
         format->transparent = MS_FALSE;
         result = MS_FALSE;
-    if( strcasecmp(format->driver,"GD/JPEG") == 0
+    if( strcasecmp(format->driver,"GD/JPEG") == 0
         && format->imagemode == MS_IMAGEMODE_RGBA )
         msDebug( "GD/JPEG OUTPUTFORMAT %s has IMAGEMODE RGBA, but this is not supported.\n"
-                 "IMAGEMODE forced to RGB.\n",
+                 "IMAGEMODE forced to RGB.\n",
                  format->name );
         result = MS_FALSE;
@@ -958,15 +962,15 @@
     if( format->transparent && format->imagemode == MS_IMAGEMODE_RGB )
         msDebug( "OUTPUTFORMAT %s has TRANSPARENT set ON, but an IMAGEMODE\n"
-                 " of RGB instead of RGBA.  Changing imagemode to RGBA.\n",
+                 " of RGB instead of RGBA.  Changing imagemode to RGBA.\n",
                  format->name );
         format->imagemode = MS_IMAGEMODE_RGBA;
         result = MS_FALSE;
     /* see bug 724 */
-    if( ( format->imagemode == MS_IMAGEMODE_INT16
-          || format->imagemode == MS_IMAGEMODE_FLOAT32
+    if( ( format->imagemode == MS_IMAGEMODE_INT16
+          || format->imagemode == MS_IMAGEMODE_FLOAT32
           || format->imagemode == MS_IMAGEMODE_BYTE )
         && format->renderer != MS_RENDER_WITH_RAWDATA )
         format->renderer = MS_RENDER_WITH_RAWDATA;
