[mapserver-commits] r8828 - branches/branch-4-10/mapserver
Thu Mar 26 00:37:57 EDT 2009
Author: sdlime
Date: 2009-03-26 00:37:57 -0400 (Thu, 26 Mar 2009)
New Revision: 8828
   branches/branch-4-10/mapserver/map.h
   branches/branch-4-10/mapserver/mapserv.c
   branches/branch-4-10/mapserver/mapstring.c
   branches/branch-4-10/mapserver/maptemplate.c
RFC56 support.
Modified: branches/branch-4-10/mapserver/map.h
--- branches/branch-4-10/mapserver/map.h	2009-03-26 04:32:25 UTC (rev 8827)
+++ branches/branch-4-10/mapserver/map.h	2009-03-26 04:37:57 UTC (rev 8828)
@@ -137,8 +137,10 @@
 /* General defines, not wrapable */
 #ifndef SWIG
 #define MS_DEFAULT_MAPFILE_PATTERN "\\.map$"
-#define MS_TEMPLATE_EXPR "\\.(jsp|asp|cfm|xml|wml|html|htm|shtml|phtml|php|svg)$"
+#define MS_TEMPLATE_MAGIC_STRING "MapServer Template"
+#define MS_TEMPLATE_EXPR "\\.(xml|wml|html|htm|svg|kml|gml|js|tmpl)$"
 #define MS_INDEX_EXTENSION ".qix"
 #define MS_QUERY_EXTENSION ".qy"
@@ -1377,6 +1379,7 @@
 MS_DLL_EXPORT char *msJoinStrings(char **array, int arrayLength, const char *delimeter);
 MS_DLL_EXPORT char *msHashString(const char *pszStr);
 MS_DLL_EXPORT char *msCommifyString(char *str);
+MS_DLL_EXPORT const char *msCaseFindSubstring(const char *haystack, const char *needle);
 #ifdef NEED_STRDUP
 MS_DLL_EXPORT char *strdup(char *s);
Modified: branches/branch-4-10/mapserver/mapserv.c
--- branches/branch-4-10/mapserver/mapserv.c	2009-03-26 04:32:25 UTC (rev 8827)
+++ branches/branch-4-10/mapserver/mapserv.c	2009-03-26 04:37:57 UTC (rev 8828)
@@ -280,8 +280,21 @@
   } else {
     if(getenv(msObj->request->ParamValues[i])) /* an environment references the actual file to use */
       map = msLoadMap(getenv(msObj->request->ParamValues[i]), NULL);
-    else
+    else {
+      /* by here we know the request isn't for something in an environment variable */
+      if(getenv("MS_MAP_NO_PATH")) {
+        msSetError(MS_WEBERR, "Mapfile not found in environment variables and this server is not configured for full paths.", "loadMap()");
+	writeError();
+      if(getenv("MS_MAP_PATTERN") && msEvalRegex(getenv("MS_MAP_PATTERN"), msObj->request->ParamValues[i]) != MS_TRUE) {
+        msSetError(MS_WEBERR, "Parameter 'map' value fails to validate.", "loadMap()");
+        writeError();
+      /* ok to try to load now */
       map = msLoadMap(msObj->request->ParamValues[i], NULL);
   if(!map) writeError();
Modified: branches/branch-4-10/mapserver/mapstring.c
--- branches/branch-4-10/mapserver/mapstring.c	2009-03-26 04:32:25 UTC (rev 8827)
+++ branches/branch-4-10/mapserver/mapstring.c	2009-03-26 04:37:57 UTC (rev 8828)
@@ -933,3 +933,34 @@
   return str;
+/*                  case incensitive equivalent of strstr               */
+const char *msCaseFindSubstring(const char *haystack, const char *needle)
+  if ( !*needle )
+      return haystack;
+  for ( ; *haystack; ++haystack )
+      if ( toupper(*haystack) == toupper(*needle) )
+	  /*          * Matched starting char -- loop through remaining chars.          */
+	  const char *h, *n;
+	  for ( h = haystack, n = needle; *h && *n; ++h, ++n )
+	      if ( toupper(*h) != toupper(*n) )
+		  break;
+	  if ( !*n ) /* matched all of 'needle' to null termination */
+	      return haystack; /* return the start of the match */
+  return 0;
Modified: branches/branch-4-10/mapserver/maptemplate.c
--- branches/branch-4-10/mapserver/maptemplate.c	2009-03-26 04:32:25 UTC (rev 8827)
+++ branches/branch-4-10/mapserver/maptemplate.c	2009-03-26 04:37:57 UTC (rev 8828)
@@ -136,6 +136,20 @@
 char *processLine(mapservObj* msObj, char* instr, int mode);
+static int isValidTemplate(FILE *stream, const char *filename)
+  char buffer[MS_BUFFER_LENGTH];
+  if(fgets(buffer, MS_BUFFER_LENGTH, stream) != NULL) {
+    if(!msCaseFindSubstring(buffer, MS_TEMPLATE_MAGIC_STRING)) {
+      msSetError(MS_WEBERR, "Missing magic string, %s doesn't look like a MapServer template.", "isValidTemplate()", filename);
+      return MS_FALSE;
+  return MS_TRUE;
  * Redirect to (only use in CGI)
@@ -2452,6 +2466,11 @@
           return(NULL);
+        if(isValidTemplate(stream, join->header) != MS_TRUE) {
+          fclose(stream);
+          return NULL;
         /* echo file to the output buffer, no substitutions */
         while(fgets(line, MS_BUFFER_LENGTH, stream) != NULL) outbuf = strcatalloc(outbuf, line);
@@ -2461,8 +2480,13 @@
       if((stream = fopen(msBuildPath(szPath, msObj->Map->mappath, join->template), "r")) == NULL) {
         msSetError(MS_IOERR, "Error while opening join template file %s.", "processOneToManyJoin()", join->template);
         return(NULL);
+	fclose(stream);
+	return NULL;
       records = MS_TRUE;
@@ -2477,6 +2501,7 @@
     rewind(stream);
+    fgets(line, MS_BUFFER_LENGTH, stream); /* skip the first line since it's the magic string */
   } /* next record */
   if(records==MS_TRUE && join->footer) {
@@ -2485,6 +2510,11 @@
       return(NULL);
+    if(isValidTemplate(stream, join->footer) != MS_TRUE) {
+      fclose(stream);
+      return NULL;
@@ -3018,6 +3048,11 @@
     return MS_FAILURE;
+  if(isValidTemplate(stream, html) != MS_TRUE) {
+    fclose(stream);
+    return MS_FAILURE;
   if (papszBuffer)
       if ((*papszBuffer) == NULL)
