[mapserver-commits] r8844 - trunk/mapserver
Sat Mar 28 12:52:03 EDT 2009
Author: aboudreault
Date: 2009-03-28 12:52:03 -0400 (Sat, 28 Mar 2009)
New Revision: 8844
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapgd.c
   trunk/mapserver/mapimagemap.c
   trunk/mapserver/mapserver.h
To be consistent, changed imageObj::resolution type from unsigned int to double
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2009-03-28 16:22:23 UTC (rev 8843)
+++ trunk/mapserver/mapagg.cpp	2009-03-28 16:52:03 UTC (rev 8844)
@@ -857,7 +857,7 @@
 // Returns a pointer to a newly created imageObj structure.
 // a pointer to the AGG renderer is stored in the imageObj, used for caching
-imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution)
+imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution)
     imageObj *pNewImage = NULL;
@@ -904,7 +904,7 @@
 #ifdef USE_GD_RESOLUTION
    /* Set the resolution */
-    gdImageSetResolution(image->img.gd, image->resolution, image->resolution);
+    gdImageSetResolution(image->img.gd, (unsigned int)image->resolution, (unsigned int)image->resolution);
 #endif
     image->buffer_format=MS_RENDER_WITH_AGG;
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c	2009-03-28 16:22:23 UTC (rev 8843)
+++ trunk/mapserver/mapgd.c	2009-03-28 16:52:03 UTC (rev 8844)
@@ -269,7 +269,7 @@
  * Utility function to create a GD image. Returns
  * a pointer to an imageObj structure.
-imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution)
+imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution)
   imageObj  *image;
@@ -321,7 +321,7 @@
 #endif
   if(image->format->imagemode == MS_IMAGEMODE_PC256) {
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c	2009-03-28 16:22:23 UTC (rev 8843)
+++ trunk/mapserver/mapimagemap.c	2009-03-28 16:52:03 UTC (rev 8844)
@@ -293,7 +293,7 @@
 imageObj *msImageCreateIM(int width, int height, outputFormatObj *format,
-                          char *imagepath, char *imageurl, unsigned int resolution)
+                          char *imagepath, char *imageurl, double resolution)
     imageObj  *image=NULL;
     if (setvbuf(stdout, NULL, _IONBF , 0)){
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-03-28 16:22:23 UTC (rev 8843)
+++ trunk/mapserver/mapserver.h	2009-03-28 16:52:03 UTC (rev 8844)
@@ -1373,7 +1373,7 @@
 %immutable;
 #endif
   int width, height;
-  unsigned int resolution;
+  double resolution;
   char *imagepath, *imageurl;
   outputFormatObj *format;
@@ -1905,7 +1905,7 @@
 /*      Prototypes for functions in mapimagemap.c                       */
-MS_DLL_EXPORT imageObj *msImageCreateIM(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution);
+MS_DLL_EXPORT imageObj *msImageCreateIM(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution);
 MS_DLL_EXPORT imageObj *msImageLoadIM( const char *filename );
 MS_DLL_EXPORT imageObj *msImageLoadGD( const char *filename );
 MS_DLL_EXPORT imageObj *msImageLoadGDCtx( gdIOCtx *ctx, const char *driver );
@@ -1932,7 +1932,7 @@
 MS_DLL_EXPORT imageObj *msImageLoadGDCtx(gdIOCtx* ctx, const char *driver);
 MS_DLL_EXPORT int msCompareColors(colorObj *c1, colorObj *c2);
 MS_DLL_EXPORT void msPreAllocateColorsGD(imageObj *image, mapObj *map);
-MS_DLL_EXPORT imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution);
+MS_DLL_EXPORT imageObj *msImageCreateGD(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution);
 MS_DLL_EXPORT void msImageInitGD( imageObj *image, colorObj *background );
 MS_DLL_EXPORT int msImageSetPenGD(gdImagePtr img, colorObj *color);
@@ -1963,7 +1963,7 @@
 /*      Prototypes for functions in mapagg.cpp                          */
-MS_DLL_EXPORT imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, unsigned int resolution);
+MS_DLL_EXPORT imageObj *msImageCreateAGG(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution);
 MS_DLL_EXPORT void msImageInitAGG( imageObj *image, colorObj *background );
 MS_DLL_EXPORT int msSaveImageAGG(imageObj *img, char *filename, outputFormatObj *format);
