[mapserver-commits] r8848 - trunk/mapserver/mapscript/php3
Tue Mar 31 16:30:46 EDT 2009
Author: dmorissette
Date: 2009-03-31 16:30:46 -0400 (Tue, 31 Mar 2009)
New Revision: 8848
   trunk/mapserver/mapscript/php3/php_mapscript.c
Get rid of last call to msSaveImageBufferGD() in php_mapscript.c (#2326)
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2009-03-30 17:48:25 UTC (rev 8847)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2009-03-31 20:30:46 UTC (rev 8848)
@@ -6340,22 +6340,15 @@
         int   b;
         FILE *tmp = NULL;
         char  buf[4096];
-#if !defined(USE_GD_GIF) || defined(GD_HAS_GDIMAGEGIFPTR)
         void *iptr=NULL;
-#endif
         retVal = 0;
         php_header(TSRMLS_C);
-        if( MS_DRIVER_GD(im->format) )
-          iptr = (void *)msSaveImageBufferGD(im->img.gd, &size, im->format);
-#ifdef USE_AGG
-        else if( MS_DRIVER_AGG(im->format) )
+        if( MS_DRIVER_GD(im->format) || MS_DRIVER_AGG(im->format))
           iptr = (void *)msSaveImageBuffer(im, &size, im->format);
-#endif
         else if (im->format->name && strcasecmp(im->format->name, "imagemap")==0)
             iptr = im->img.imagemap;
@@ -6411,37 +6404,7 @@
             gdFree(iptr);
-#else  /* No gdImageGifPtr(): GD 1.2/1.3 */
-        /* there is no gdImageGifPtr function */
-        tmp = tmpfile(); /* temporary file */
-        if (tmp == NULL)
-            php3_error(E_WARNING, "Unable to open temporary file");
-            retVal = -1;
-        else
-            gdImageGif (im->img.gd, tmp); //TODO
-            size = ftell(tmp);
-            fseek(tmp, 0, SEEK_SET);
-#if APACHE && defined(CHARSET_EBCDIC)
-            /* This is a binary file already: avoid EBCDIC->ASCII conversion */
-            ap_bsetflag(php3_rqst->connection->client, B_EBCDIC2ASCII, 0);
-#endif
-            while ((b = fread(buf, 1, sizeof(buf), tmp)) > 0)
-                php_write(buf, b TSRMLS_CC);
-            fclose(tmp); /* the temporary file is automatically deleted */
-            retVal = size;
-#endif
     RETURN_LONG(retVal);
