[mapserver-commits] r8854 - branches/branch-5-4/mapserver
Tue Mar 31 23:13:28 EDT 2009
Author: sdlime
Date: 2009-03-31 23:13:28 -0400 (Tue, 31 Mar 2009)
New Revision: 8854
   branches/branch-5-4/mapserver/mapfile.c
   branches/branch-5-4/mapserver/mapsymbol.c
Make sure map and symbol files are well-formed to minimize chance of leaking sensitive data. (#2941)
Modified: branches/branch-5-4/mapserver/mapfile.c
--- branches/branch-5-4/mapserver/mapfile.c	2009-04-01 03:03:55 UTC (rev 8853)
+++ branches/branch-5-4/mapserver/mapfile.c	2009-04-01 03:13:28 UTC (rev 8854)
@@ -4708,11 +4708,20 @@
 static int loadMapInternal(mapObj *map)
   int i,j,k;
+  int foundMapToken=MS_FALSE;
+  int token;
   for(;;) {
-    switch(msyylex()) {
+    token = msyylex();
+    if(!foundMapToken && token != MAP) {
+      msSetError(MS_IDENTERR, "First token must be MAP, this doesn't look like a mapfile.", "msLoadMap()");
+      return(MS_FAILURE);
+    switch(token) {
     case(CONFIG):
         char *key=NULL, *value=NULL;
@@ -4838,6 +4847,7 @@
       if(loadLegend(&(map->legend), map) == -1) return MS_FAILURE;
       break;
     case(MAP):
+      foundMapToken = MS_TRUE;
       break;
     case(MAXSIZE):
       if(getInteger(&(map->maxsize)) == -1) return MS_FAILURE;
@@ -4895,8 +4905,7 @@
       if(loadWeb(&(map->web), map) == -1) return MS_FAILURE;
       break;
     default:
-      msSetError(MS_IDENTERR, "Parsing error near (%s):(line %d)", "msLoadMap()",
-                 msyytext, msyylineno);
+      msSetError(MS_IDENTERR, "Parsing error near (%s):(line %d)", "msLoadMap()", msyytext, msyylineno);
       return MS_FAILURE;
   } /* next token */
Modified: branches/branch-5-4/mapserver/mapsymbol.c
--- branches/branch-5-4/mapserver/mapsymbol.c	2009-04-01 03:03:55 UTC (rev 8853)
+++ branches/branch-5-4/mapserver/mapsymbol.c	2009-04-01 03:13:28 UTC (rev 8854)
@@ -631,11 +631,12 @@
 int loadSymbolSet(symbolSetObj *symbolset, mapObj *map)
-/* char old_path[MS_PATH_LENGTH]; */
-/* char *symbol_path; */
   int status=1;
   char szPath[MS_MAXPATHLEN], *pszSymbolPath=NULL;
+  int foundSymbolSetToken=MS_FALSE;
+  int token;
   if(!symbolset) {
     msSetError(MS_SYMERR, "Symbol structure unallocated.", "loadSymbolSet()");
     return(-1);
@@ -662,7 +663,14 @@
   ** Read the symbol file
   for(;;) {
+    if(!foundSymbolSetToken && token != SYMBOLSET) {
+      msSetError(MS_IDENTERR, "First token must be SYMBOLSET, this doesn't look like a symbol file.", "msLoadSymbolSet()");
+      return(-1);
+    switch(token) {
     case(END):
     case(EOF):
       status = 0;
@@ -678,6 +686,7 @@
           symbolset->numsymbols++;
       break;
     case(SYMBOLSET):
+      foundSymbolSetToken = MS_TRUE;
       break;
     default:
       msSetError(MS_IDENTERR, "Parsing error near (%s):(line %d)", "loadSymbolSet()", msyytext, msyylineno);
