[mapserver-commits] r9476 - sandbox/aggplugin/mapserver
Sat Oct 17 06:04:02 EDT 2009
Author: tbonfort
Date: 2009-10-17 06:04:01 -0400 (Sat, 17 Oct 2009)
New Revision: 9476
   sandbox/aggplugin/mapserver/mapagg2.cpp
   sandbox/aggplugin/mapserver/mapdraw.c
   sandbox/aggplugin/mapserver/maplabel.c
   sandbox/aggplugin/mapserver/maprendering.c
apply resolution factor for plugin renderers
Modified: sandbox/aggplugin/mapserver/mapagg2.cpp
--- sandbox/aggplugin/mapserver/mapagg2.cpp	2009-10-16 21:37:04 UTC (rev 9475)
+++ sandbox/aggplugin/mapserver/mapagg2.cpp	2009-10-17 10:04:01 UTC (rev 9476)
@@ -147,7 +147,8 @@
          if (i < style->patternlength - 1) {
-            dash.add_dash(MS_NINT(style->pattern[i]), MS_NINT(style->pattern[i + 1]));
+            dash.add_dash(MS_MAX(1,MS_NINT(style->pattern[i])),
+                    MS_MAX(1,MS_NINT(style->pattern[i + 1])));
          stroke_dash.width(style->width);
          applyCJC(stroke_dash, style->linecap, style->linejoin);
@@ -193,7 +194,7 @@
    mapserver::trans_affine mtx;
    mtx *= mapserver::trans_affine_translation(-x, -y);
    /*agg angles are antitrigonometric*/
-   mtx *= mapserver::trans_affine_rotation(style->rotation);
+   mtx *= mapserver::trans_affine_rotation(-style->rotation);
    mtx *= mapserver::trans_affine_translation(x, y);
    double fx = x, fy = y;
Modified: sandbox/aggplugin/mapserver/mapdraw.c
--- sandbox/aggplugin/mapserver/mapdraw.c	2009-10-16 21:37:04 UTC (rev 9475)
+++ sandbox/aggplugin/mapserver/mapdraw.c	2009-10-17 10:04:01 UTC (rev 9476)
@@ -157,6 +157,9 @@
 		image->format->refcount++;
 		image->width = map->width;
 		image->height = map->height;
+      image->resolution = map->resolution;
+      image->resolutionfactor = map->resolution/map->defresolution;
 		if (map->web.imagepath)
 			image->imagepath = strdup(map->web.imagepath);
 		if (map->web.imageurl)
Modified: sandbox/aggplugin/mapserver/maplabel.c
--- sandbox/aggplugin/mapserver/maplabel.c	2009-10-16 21:37:04 UTC (rev 9475)
+++ sandbox/aggplugin/mapserver/maplabel.c	2009-10-17 10:04:01 UTC (rev 9476)
@@ -668,13 +668,13 @@
 #ifdef USE_GD_FT
 	if(img!=NULL && MS_RENDERER_PLUGIN(img->format)) {
 		img->format->vtable->getTruetypeTextBBox(img,font,size,string,rect,advances);
-		//printf("%s: %f %f %f %f\n",string,rect->minx,rect->miny,rect->maxx,rect->maxy);
+		//printf("%s (%f): %f %f %f %f\n",string,size,rect->minx,rect->miny,rect->maxx,rect->maxy);
 		return MS_SUCCESS;
 	} else
 #ifdef USE_AGG
 	if(img!=NULL && MS_RENDERER_AGG(img->format)) {
         msGetTruetypeTextBBoxAGG(img,font,size,string,rect,advances);
         return MS_SUCCESS;
     } else
 #endif
@@ -777,7 +777,6 @@
   if(label->type == MS_TRUETYPE) {
 #ifdef USE_GD_FT
     char *font=NULL;
     size = label->size*scalefactor;
     if (img != NULL) {
       size = MS_MAX(size, label->minsize*img->resolutionfactor);
Modified: sandbox/aggplugin/mapserver/maprendering.c
--- sandbox/aggplugin/mapserver/maprendering.c	2009-10-16 21:37:04 UTC (rev 9475)
+++ sandbox/aggplugin/mapserver/maprendering.c	2009-10-17 10:04:01 UTC (rev 9476)
@@ -418,8 +418,8 @@
             symbol->renderer = renderer;
 			width = style->width * scalefactor;
-            width = MS_MIN(width,style->maxwidth);
-            width = MS_MAX(width,style->minwidth);
+            width = MS_MIN(width,style->maxwidth*image->resolutionfactor);
+            width = MS_MAX(width,style->minwidth*image->resolutionfactor);
             if(style->offsety==-99) {
 				offsetLine = msOffsetPolyline(p,style->offsetx * width,-99);
