[mapserver-commits] r9316 - in trunk/mapserver: . mapscript/php3
Fri Sep 18 16:43:19 EDT 2009
Author: assefa
Date: 2009-09-18 16:43:18 -0400 (Fri, 18 Sep 2009)
New Revision: 9316
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapgraticule.c
   trunk/mapserver/mapscript/php3/php_mapscript.c
   trunk/mapserver/mapserver.h
get grid intersection points and labels #3101
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-09-17 19:45:26 UTC (rev 9315)
+++ trunk/mapserver/HISTORY.TXT	2009-09-18 20:43:18 UTC (rev 9316)
@@ -13,6 +13,7 @@
 Current Version (SVN trunk):
+- Get the intersection points and labels #3101
 - Fixed shp2img not to cause a crash when the map couldn't be loaded
Modified: trunk/mapserver/mapgraticule.c
--- trunk/mapserver/mapgraticule.c	2009-09-17 19:45:26 UTC (rev 9315)
+++ trunk/mapserver/mapgraticule.c	2009-09-18 20:43:18 UTC (rev 9316)
@@ -309,6 +309,9 @@
       dDeltaX = (pInfo->dwhichlongitude - pInfo->pboundinglines[1].point[0].x) / (pInfo->pboundinglines[1].point[1].x - pInfo->pboundinglines[1].point[0].x);
+      if (dDeltaX < 0)
+        dDeltaX=dDeltaX*-1;
       dStartY = (pInfo->pboundinglines[1].point[1].y - pInfo->pboundinglines[1].point[0].y) * dDeltaX + pInfo->pboundinglines[1].point[0].y;
       shape->line->numpoints = (int) 2;
       shape->line->point = (pointObj *) malloc( sizeof( pointObj ) * 2 );
@@ -333,6 +336,9 @@
       dDeltaX = (pInfo->dwhichlongitude - pInfo->pboundinglines[0].point[0].x) / (pInfo->pboundinglines[0].point[1].x - pInfo->pboundinglines[0].point[0].x );
+      if (dDeltaX < 0)
       dStartY = (pInfo->pboundinglines[0].point[1].y - pInfo->pboundinglines[0].point[0].y) * dDeltaX + pInfo->pboundinglines[0].point[1].y;
@@ -386,6 +392,9 @@
       dDeltaY = (pInfo->dwhichlatitude - pInfo->pboundinglines[2].point[0].y) / (pInfo->pboundinglines[2].point[1].y - pInfo->pboundinglines[2].point[0].y );
+      if (dDeltaY < 0)
+        dDeltaY= dDeltaY*-1;
       dStartX = (pInfo->pboundinglines[2].point[1].x - pInfo->pboundinglines[2].point[0].x) * dDeltaY + pInfo->pboundinglines[2].point[0].x;
@@ -410,6 +419,9 @@
       dDeltaY = (pInfo->dwhichlatitude - pInfo->pboundinglines[3].point[0].y) / (pInfo->pboundinglines[3].point[1].y - pInfo->pboundinglines[3].point[0].y );
+      if (dDeltaY < 0)
       dStartX = (pInfo->pboundinglines[3].point[1].x - pInfo->pboundinglines[3].point[0].x) * dDeltaY + pInfo->pboundinglines[3].point[0].x;
@@ -533,6 +545,477 @@
   return MS_SUCCESS;
+/*                  msGraticuleLayerFreeIntersectionPoints              */
+/*      Free intersection object.                                       */
+void msGraticuleLayerFreeIntersectionPoints( graticuleIntersectionObj *psValue)
+    int i=0;
+    if (psValue)
+        for (i=0; i<psValue->nTop; i++)
+          msFree(psValue->papszTopLabels[i]);
+        msFree(psValue->papszTopLabels);
+        msFree(psValue->pasTop);
+        for (i=0; i<psValue->nBottom; i++)
+          msFree(psValue->papszBottomLabels[i]);
+        msFree(psValue->papszBottomLabels);
+        msFree(psValue->pasBottom);
+        for (i=0; i<psValue->nLeft; i++)
+          msFree(psValue->papszLeftLabels[i]);
+        msFree(psValue->papszLeftLabels);
+        msFree(psValue->pasLeft);
+        for (i=0; i<psValue->nRight; i++)
+          msFree(psValue->papszRightLabels[i]);
+        msFree(psValue->papszRightLabels);
+        msFree(psValue->pasRight);
+        msFree(psValue);
+/*                  msGraticuleLayerInitIntersectionPoints              */
+/*      init intersection object.                                       */
+static void msGraticuleLayerInitIntersectionPoints( graticuleIntersectionObj *psValue)
+    if (psValue)
+        psValue->nTop = 0;
+        psValue->pasTop = NULL;
+        psValue->papszTopLabels = NULL;
+        psValue->nBottom = 0;
+        psValue->pasBottom = NULL;
+        psValue->papszBottomLabels = NULL;
+        psValue->nLeft = 0;
+        psValue->pasLeft = NULL;
+        psValue->papszLeftLabels = NULL;
+        psValue->nRight = 0;
+        psValue->pasRight = NULL;
+        psValue->papszRightLabels = NULL;
+/*                  msGraticuleLayerGetIntersectionPoints               */
+/*      Utility function thar returns all intersection positions and    */
+/*      labels (4 sides of the map) for a grid layer.                   */
+graticuleIntersectionObj *msGraticuleLayerGetIntersectionPoints(mapObj *map,
+        layerObj *layer)
+    shapeObj    shapegrid, tmpshape;
+    rectObj     searchrect;
+    int         status, retcode=MS_SUCCESS;
+    pointObj oFirstPoint;
+    pointObj oLastPoint;
+    lineObj oLineObj;
+    int bHori = 0;
+    rectObj cliprect;
+    graticuleObj   *pInfo  = NULL;
+    double dfTmp;
+    char *pszTmpText = NULL;
+    graticuleIntersectionObj *psValues = NULL;
+    int i=0;
+    if (layer->connectiontype != MS_GRATICULE)
+      return NULL;
+    pInfo  = (graticuleObj *) layer->layerinfo;
+    /*set cellsize if bnot already set*/
+    if (map->cellsize == 0)
+      map->cellsize = msAdjustExtent(&(map->extent),map->width,map->height);
+    psValues = (graticuleIntersectionObj *)malloc(sizeof(graticuleIntersectionObj));
+    msGraticuleLayerInitIntersectionPoints(psValues);
+    if(layer->transform == MS_TRUE)
+    searchrect = map->extent;
+    else {
+      searchrect.minx = searchrect.miny = 0;
+      searchrect.maxx = map->width-1;
+      searchrect.maxy = map->height-1;
+#ifdef USE_PROJ
+    if((map->projection.numargs > 0) && (layer->projection.numargs > 0))
+      msProjectRect(&map->projection, &layer->projection, &searchrect); /* project the searchrect to source coords */
+#endif
+    msLayerOpen(layer);
+    status = msLayerWhichShapes(layer, searchrect);
+    if(status == MS_DONE) { /* no overlap */
+      msLayerClose(layer);
+      return NULL;
+    } else if(status != MS_SUCCESS) {
+      return NULL;
+    /* step through the target shapes */
+    msInitShape(&shapegrid);
+    cliprect.minx = map->extent.minx- map->cellsize;
+    cliprect.miny = map->extent.miny- map->cellsize;
+    cliprect.maxx = map->extent.maxx + map->cellsize;
+    cliprect.maxy = map->extent.maxy + map->cellsize;
+    //clip using the layer projection
+    //msProjectRect(&map->projection , &layer->projection,  &cliprect);
+    while((status = msLayerNextShape(layer, &shapegrid)) == MS_SUCCESS)
+        /*don't really need a class here*/
+          shapegrid.classindex = msShapeGetClass(layer, &shapegrid, map->scaledenom, NULL, 0);
+          if((shapegrid.classindex == -1) || (layer->class[shapegrid.classindex]->status == MS_OFF)) {
+        msFreeShape(&shapegrid);
+        continue;
+      msInitShape(&tmpshape);
+      msCopyShape(&shapegrid, &tmpshape);
+      //status = msDrawShape(map, layer, &tmpshape, image, -1);
+      if(layer->project && msProjectionsDiffer(&(layer->projection), &(map->projection)))
+        msProjectShape(&layer->projection, &map->projection, &shapegrid);
+      msClipPolylineRect(&shapegrid, cliprect);
+#ifdef USE_AGG
+      if(MS_RENDERER_AGG(map->outputformat))
+        msTransformShapeAGG(&shapegrid, map->extent, map->cellsize);
+#else
+      msTransformShapeToPixel(&shapegrid, map->extent, map->cellsize);
+#endif
+      if(shapegrid.numlines <= 0 || shapegrid.line[0].numpoints < 2) { /* once clipped the shape didn't need to be drawn */
+        msFreeShape(&tmpshape);
+        continue;
+      if(shapegrid.numlines >= 1 && shapegrid.line[0].numpoints >=2)// && shapegrid.text)
+          int iTmpLine = 0;
+          int nNumPoints = 0;
+          /*grid code seems to retunr lines that can double cross the extenst??*/
+          /*creating a more than one clipped shape. Take the shape that has the most
+            points, which should be the most likley to be correct*/
+          if (shapegrid.numlines > 1)
+              for (i=0; i<shapegrid.numlines; i++)
+                  if (shapegrid.line[i].numpoints > nNumPoints)
+                      nNumPoints = shapegrid.line[i].numpoints;
+                      iTmpLine = i;
+          /* get the first and last point*/
+          oFirstPoint.x = shapegrid.line[iTmpLine].point[0].x;
+          oFirstPoint.y = shapegrid.line[iTmpLine].point[0].y;
+          oLineObj = shapegrid.line[iTmpLine];
+          oLastPoint.x = oLineObj.point[oLineObj.numpoints-1].x;
+          oLastPoint.y = oLineObj.point[oLineObj.numpoints-1].y;
+          //if (layer->numclasses > 0 && layer->class[0]->numstyles > 0)
+          /*horzontal or Vertical*/
+          //bHori = 0;
+          //if (abs(oFirstPoint.x - oLastPoint.x) > abs(oFirstPoint.y - oLastPoint.y))
+          //bHori = 1;
+          if ( pInfo->bvertical) /*vertical*/
+              /*SHAPES ARE DRAWN FROM BOTTOM TO TOP.*/
+              /*Normally lines are drawn FROM BOTTOM TO TOP but not always for some reason, so
+                make sure that firstpoint < lastpoint in y, We are in pixel coordinates so y increases as we
+              we go down*/
+              if (oFirstPoint.y < oLastPoint.y)
+                  dfTmp = oFirstPoint.x;
+                  oFirstPoint.x = oLastPoint.x;
+                  oLastPoint.x = dfTmp;
+                  dfTmp = oFirstPoint.y;
+                  oFirstPoint.y = oLastPoint.y;
+                  oLastPoint.y = dfTmp;
+              /*first point should cross the BOTTOM base where y== map->height*/
+              if (abs ((int)oFirstPoint.y - map->height)  <=1)
+                  char *pszLabel=NULL;
+                  oFirstPoint.y = map->height;
+                  /*validate point is in map width/height*/
+                  if (oFirstPoint.x < 0 || oFirstPoint.x > map->width)
+                    continue;
+                  if (oLastPoint.x < 0 || oLastPoint.x > map->width)
+                    continue;
+                  if (shapegrid.text)
+                    pszLabel =  strdup(shapegrid.text);
+                  else
+                      _FormatLabel(layer, &tmpshape, tmpshape.line[0].point[tmpshape.line[0].numpoints-1].x );
+                      if (tmpshape.text)
+                        pszLabel = strdup(tmpshape.text);
+                      else
+                        pszLabel = strdup("unknown");
+                  /*validate that the  value is not already in the array*/
+                  if ( psValues->nBottom > 0)
+                      //if (psValues->pasBottom[psValues->nBottom-1].x == oFirstPoint.x)
+                      //continue;
+                      for (i=0; i<psValues->nBottom; i++)
+                          if (psValues->pasBottom[i].x == oFirstPoint.x)
+                            break;
+                      if (i  < psValues->nBottom)
+                        continue;
+                  if (psValues->pasBottom == NULL)
+                      psValues->pasBottom = (pointObj *)malloc(sizeof(pointObj));
+                      psValues->papszBottomLabels = (char **)malloc(sizeof(char *));
+                      psValues->nBottom = 1;
+                  else
+                      psValues->nBottom++;
+                      psValues->pasBottom = (pointObj *)realloc(psValues->pasBottom, sizeof(pointObj)*psValues->nBottom);
+                      psValues->papszBottomLabels = (char **)realloc(psValues->papszBottomLabels, sizeof(char *)*psValues->nBottom);
+                  psValues->pasBottom[psValues->nBottom-1].x = oFirstPoint.x;
+                  psValues->pasBottom[psValues->nBottom-1].y = oFirstPoint.y;
+                  psValues->papszBottomLabels[psValues->nBottom-1] = strdup(pszLabel);
+                  msFree(pszLabel);
+              /*first point should cross the TOP base where y==0*/
+              if (abs((int)oLastPoint.y) <=1)
+                  oLastPoint.y = 0;
+                    continue;
+                  else
+                       else
+                  /*validate if same value is not already there*/
+                  if ( psValues->nTop > 0)
+                      //if (psValues->pasTop[psValues->nTop-1].x == oLastPoint.x)
+                      //continue;
+                      for (i=0; i<psValues->nTop; i++)
+                          if (psValues->pasTop[i].x == oLastPoint.x ||
+                              strcasecmp(pszLabel, psValues->papszTopLabels[i]) == 0)
+                            break;
+                      if (i < psValues->nTop)
+                        continue;
+                  if (psValues->pasTop == NULL)
+                      psValues->pasTop = (pointObj *)malloc(sizeof(pointObj));
+                      psValues->papszTopLabels = (char **)malloc(sizeof(char *));
+                      psValues->nTop = 1;
+                  else
+                      psValues->nTop++;
+                      psValues->pasTop = (pointObj *)realloc(psValues->pasTop, sizeof(pointObj)*psValues->nTop);
+                      psValues->papszTopLabels = (char **)realloc(psValues->papszTopLabels, sizeof(char *)*psValues->nTop);
+                  psValues->pasTop[psValues->nTop-1].x = oLastPoint.x;
+                  psValues->pasTop[psValues->nTop-1].y = oLastPoint.y;
+                  psValues->papszTopLabels[psValues->nTop-1] = strdup(pszLabel);
+                  msFree(pszLabel);
+          else /*horzontal*/
+              /*Normally lines are drawn from left to right but not always for some reason, so
+                make sure that firstpoint < lastpoint in x*/
+              if (oFirstPoint.x > oLastPoint.x)
+              /*first point should cross the LEFT base where x=0 axis*/
+              if (abs((int)oFirstPoint.x) <=1)
+                  oFirstPoint.x = 0;
+                  if (oFirstPoint.y < 0 || oFirstPoint.y > map->height)
+                    continue;
+                  else
+                      _FormatLabel(layer, &tmpshape, tmpshape.line[0].point[tmpshape.line[0].numpoints-1].y );
+                       else
+                  /*validate that the previous value is not the same*/
+                  if ( psValues->nLeft > 0)
+                      //if (psValues->pasLeft[psValues->nLeft-1].y == oFirstPoint.y)
+                      // continue;
+                      for (i=0; i<psValues->nLeft; i++)
+                          if (psValues->pasLeft[i].y == oFirstPoint.y)
+                            break;
+                      if (i < psValues->nLeft)
+                        continue;
+                  if (psValues->pasLeft == NULL)
+                      psValues->pasLeft = (pointObj *)malloc(sizeof(pointObj));
+                      psValues->papszLeftLabels = (char **)malloc(sizeof(char *));
+                      psValues->nLeft = 1;
+                  else
+                      psValues->nLeft++;
+                      psValues->pasLeft = (pointObj *)realloc(psValues->pasLeft, sizeof(pointObj)*psValues->nLeft);
+                      psValues->papszLeftLabels = (char **)realloc(psValues->papszLeftLabels, sizeof(char *)*psValues->nLeft);
+                  psValues->pasLeft[psValues->nLeft-1].x = oFirstPoint.x;
+                  psValues->pasLeft[psValues->nLeft-1].y = oFirstPoint.y;
+                  psValues->papszLeftLabels[psValues->nLeft-1] = strdup(pszLabel);
+                  msFree(pszLabel);
+              /*first point should cross the RIGHT base where x=map=>width axis*/
+              if (abs((int)oLastPoint.x - map->width) <=1)
+                  oLastPoint.x =  map->width;
+                  if (oLastPoint.y < 0 || oLastPoint.y > map->height)
+                    continue;
+                  else
+                       else
+                  if ( psValues->nRight > 0)
+                      //if (psValues->pasRight[psValues->nRight-1].y == oLastPoint.y)
+                      // continue;
+                      for (i=0; i<psValues->nRight; i++)
+                          if (psValues->pasRight[i].y == oLastPoint.y)
+                            break;
+                      if (i < psValues->nRight)
+                        continue;
+                  if (psValues->pasRight == NULL)
+                      psValues->pasRight = (pointObj *)malloc(sizeof(pointObj));
+                      psValues->papszRightLabels = (char **)malloc(sizeof(char *));
+                      psValues->nRight = 1;
+                  else
+                      psValues->nRight++;
+                      psValues->pasRight = (pointObj *)realloc(psValues->pasRight, sizeof(pointObj)*psValues->nRight);
+                      psValues->papszRightLabels = (char **)realloc(psValues->papszRightLabels, sizeof(char *)*psValues->nRight);
+                  psValues->pasRight[psValues->nRight-1].x = oLastPoint.x;
+                  psValues->pasRight[psValues->nRight-1].y = oLastPoint.y;
+                  psValues->papszRightLabels[psValues->nRight-1] = strdup(pszLabel);
+                  msFree(pszLabel);
+    return psValues;
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2009-09-17 19:45:26 UTC (rev 9315)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2009-09-18 20:43:18 UTC (rev 9316)
@@ -231,6 +231,7 @@
 DLEXPORT void php3_ms_lyr_removeClass(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_lyr_isVisible(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_lyr_setConnectionType(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_lyr_getGridIntersectionCoordinates(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_class_new(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_class_updateFromString(INTERNAL_FUNCTION_PARAMETERS);
@@ -840,6 +841,7 @@
     {"moveclassdown",   php3_ms_lyr_moveClassDown,      NULL},
     {"removeclass",     php3_ms_lyr_removeClass,        NULL},
     {"isvisible",       php3_ms_lyr_isVisible,          NULL},
+    {"getgridintersectioncoordinates",       php3_ms_lyr_getGridIntersectionCoordinates,          NULL},
     {NULL, NULL, NULL}
@@ -8953,6 +8955,158 @@
+ *                        layer->getGridIntersctionCoordinates()
+/* {{{ proto int layer.getGridIntersctionCoordinates()
+    pval        *pThis;
+    layerObj    *self=NULL;
+    mapObj      *parent_map = NULL;
+    graticuleIntersectionObj *pasValues=NULL;
+    HashTable   *list=NULL;
+    pval *tmp_arr, *tmp_arr1;
+    int i=0;
+    pThis = getThis();
+    if (pThis == NULL || ARG_COUNT(ht) > 0)
+        WRONG_PARAM_COUNT;
+    if (array_init(return_value) == FAILURE)
+      RETURN_FALSE;
+    self = (layerObj *)_phpms_fetch_handle(pThis, PHPMS_GLOBAL(le_mslayer),
+                                           list TSRMLS_CC);
+    parent_map = (mapObj*)_phpms_fetch_property_handle(pThis, "_map_handle_",
+                                                       PHPMS_GLOBAL(le_msmap),
+                                                       list TSRMLS_CC, E_ERROR);
+    if (self->connectiontype != MS_GRATICULE)
+        php3_error(E_ERROR, "GetGridIntersectionCoordinates failed: Layer is not of graticule type");
+        RETURN_FALSE;
+    if (self != NULL && parent_map != NULL)
+        pasValues = msGraticuleLayerGetIntersectionPoints(parent_map, self);
+        if (pasValues == NULL)
+          RETURN_FALSE;
+        /*TOP*/
+        add_assoc_double(return_value, "topnumpoints", pasValues->nTop);
+        MAKE_STD_ZVAL(tmp_arr1);
+        array_init(tmp_arr1);
+        for (i=0; i<pasValues->nTop; i++)
+            add_next_index_string(tmp_arr1, pasValues->papszTopLabels[i],1);
+        zend_hash_update(Z_ARRVAL_P(return_value), "toplabels", strlen("toplabels")+1, &tmp_arr1,
+                         sizeof(tmp_arr1), NULL);
+            add_next_index_double(tmp_arr1, pasValues->pasTop[i].x);
+            add_next_index_double(tmp_arr1, pasValues->pasTop[i].y);
+        zend_hash_update(Z_ARRVAL_P(return_value), "toppoints", strlen("toppoints")+1, &tmp_arr1,
+        /*BOTTOM*/
+        add_assoc_double(return_value, "bottomnumpoints", pasValues->nBottom);
+        for (i=0; i<pasValues->nBottom; i++)
+            add_next_index_string(tmp_arr1, pasValues->papszBottomLabels[i],1);
+        zend_hash_update(Z_ARRVAL_P(return_value), "bottomlabels", strlen("bottomlabels")+1, &tmp_arr1,
+            add_next_index_double(tmp_arr1, pasValues->pasBottom[i].x);
+            add_next_index_double(tmp_arr1, pasValues->pasBottom[i].y);
+        zend_hash_update(Z_ARRVAL_P(return_value), "bottompoints", strlen("bottompoints")+1, &tmp_arr1,
+        /*LEFT*/
+        add_assoc_double(return_value, "leftnumpoints", pasValues->nLeft);
+        for (i=0; i<pasValues->nLeft; i++)
+            add_next_index_string(tmp_arr1, pasValues->papszLeftLabels[i],1);
+        zend_hash_update(Z_ARRVAL_P(return_value), "leftlabels", strlen("leftlabels")+1, &tmp_arr1,
+            add_next_index_double(tmp_arr1, pasValues->pasLeft[i].x);
+            add_next_index_double(tmp_arr1, pasValues->pasLeft[i].y);
+        zend_hash_update(Z_ARRVAL_P(return_value), "leftpoints", strlen("leftpoints")+1, &tmp_arr1,
+        /*RIGHT*/
+        add_assoc_double(return_value, "rightnumpoints", pasValues->nRight);
+        for (i=0; i<pasValues->nRight; i++)
+            add_next_index_string(tmp_arr1, pasValues->papszRightLabels[i],1);
+        zend_hash_update(Z_ARRVAL_P(return_value), "rightlabels", strlen("rightlabels")+1, &tmp_arr1,
+            add_next_index_double(tmp_arr1, pasValues->pasRight[i].x);
+            add_next_index_double(tmp_arr1, pasValues->pasRight[i].y);
+        zend_hash_update(Z_ARRVAL_P(return_value), "rightpoints", strlen("rightpoints")+1, &tmp_arr1,
+        msGraticuleLayerFreeIntersectionPoints(pasValues);
+    else
+      RETURN_FALSE;
  *                 PHP function wrappers - labelObj class
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-09-17 19:45:26 UTC (rev 9315)
+++ trunk/mapserver/mapserver.h	2009-09-18 20:43:18 UTC (rev 9316)
@@ -1126,6 +1126,22 @@
   char    *labelformat;
 } graticuleObj;
+typedef struct
+  int nTop;
+  pointObj *pasTop;
+  char  **papszTopLabels;
+  int nBottom;
+  pointObj *pasBottom;
+  char  **papszBottomLabels;
+  int nLeft;
+  pointObj *pasLeft;
+  char  **papszLeftLabels;
+  int nRight;
+  pointObj *pasRight;
+  char  **papszRightLabels;
+}graticuleIntersectionObj;
 struct layerVTable;
 typedef struct layerVTable layerVTableObj;
@@ -2431,6 +2447,17 @@
 /*      end of prototypes for functions in mapgeomtransform.c                 */
+/*      prototypes for functions in mapgraticule.c                      */
+MS_DLL_EXPORT graticuleIntersectionObj *msGraticuleLayerGetIntersectionPoints(mapObj *map, layerObj *layer);
+MS_DLL_EXPORT void msGraticuleLayerFreeIntersectionPoints( graticuleIntersectionObj *psValue);
+/*      end of prototypes for functions in mapgraticule.c               */
 #endif
