[mapserver-commits] r9343 - trunk/mapserver
Thu Sep 24 14:40:03 EDT 2009
Author: dmorissette
Date: 2009-09-24 14:40:02 -0400 (Thu, 24 Sep 2009)
New Revision: 9343
   trunk/mapserver/MIGRATION_GUIDE.TXT
Added 5.2-5.4 and 5.4-5.6 sections
Modified: trunk/mapserver/MIGRATION_GUIDE.TXT
--- trunk/mapserver/MIGRATION_GUIDE.TXT	2009-09-24 17:17:40 UTC (rev 9342)
+++ trunk/mapserver/MIGRATION_GUIDE.TXT	2009-09-24 18:40:02 UTC (rev 9343)
@@ -1,8 +1,66 @@
+MapServer 5.4 to 5.6 Migration Guide
+This section documents the changes that must be made to MapServer
+applications when migrating from version 5.4.x (or earlier versions)
+to 5.6 (i.e. backwards incompatibilities), as well as information
+on some of the new features.
+MapScript changes related to single pass queries
+In RFC-52, MapServer was modified to perform queries using a single pass
+on the data instead of two passes. This is transparent for CGI applications,
+but MapScript scripts must be modified to use the layer.resultsGetShape()
+method instead of layer.getShape().
+See also: http://mapserver.org/development/rfc/ms-rfc-52.html
+(Note: the new resultsGetShape() method is not yet available for PHP MapScript
+in 5.6.0-beta1)
+MapServer 5.2 to 5.4 Migration Guide
+applications when migrating from version 5.2. (or earlier versions)
+to 5.4 (i.e. backwards incompatibilities), as well as information
+New requirements for mapfiles, symbolsets and templates
+Due to some potential security vulnerabilities that were uncovered in previous
+versions of MapServer, RFC-56 introduced a number of changes to tighten
+access control on mapfiles and templates and limit the risk of leaking
+arbitrary file contents. These changes were introduced in version 5.4.0,
+and were also backported to v5.2.2 and 4.10.4.
+The new requirements are as follows:
+* The MAP and SYMBOLSET keywords must be added to any mapfile and symbolset
+  that did not contain them already.
+* All MapServer templates must be updated to contain the "MapServer Template"
+  magic string on the first line. This string can be embedded
+  in a commment depending on the template formet and the whole line will
+  be skipped in the output generation. e.g.
+   * In HTML: <!-- MapServer Template -->
+   * In JavaScript: // MapServer Template
+See also: http://mapserver.org/development/rfc/ms-rfc-56.html
 MapServer 4.10 to 5.0 Migration Guide
-This page documents the changes that must be made to MapServer
 applications when migrating from version 4.10.x (or earlier versions)
 to 5.x (i.e. backwards incompatibilities), as well as information
