[mapserver-commits] r9356 - trunk/mapserver
Tue Sep 29 17:34:13 EDT 2009
Author: assefa
Date: 2009-09-29 17:34:13 -0400 (Tue, 29 Sep 2009)
New Revision: 9356
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogr.cpp
   trunk/mapserver/mapwfslayer.c
WFS Client seg fault (OGR layer not opened) (#3136)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-09-29 15:29:34 UTC (rev 9355)
+++ trunk/mapserver/HISTORY.TXT	2009-09-29 21:34:13 UTC (rev 9356)
@@ -14,9 +14,11 @@
 Current Version (SVN trunk):
+- WFS Client seg fault (OGR layer not opened) (#3136)
 - Reduce use of sqrt() calls when determining distances (#3134)
-- support axis odering for WFS 1.1 (#2899)
+- support axis ordering for WFS 1.1 (#2899)
 - const changes to avoid warnings with msLoadProjectionString()
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp	2009-09-29 15:29:34 UTC (rev 9355)
+++ trunk/mapserver/mapogr.cpp	2009-09-29 21:34:13 UTC (rev 9356)
@@ -2262,6 +2262,13 @@
 #ifdef USE_OGR
   msOGRFileInfo *psInfo =(msOGRFileInfo*)layer->layerinfo;
+  if (psInfo == NULL || psInfo->hLayer == NULL)
+    msSetError(MS_MISCERR, "Assertion failed: OGR layer not opened!!!",
+               "msOGRLayerGetItems()");
+    return(MS_FAILURE);
   if( layer->tileindex != NULL )
       if( psInfo->poCurTile == NULL
Modified: trunk/mapserver/mapwfslayer.c
--- trunk/mapserver/mapwfslayer.c	2009-09-29 15:29:34 UTC (rev 9355)
+++ trunk/mapserver/mapwfslayer.c	2009-09-29 21:34:13 UTC (rev 9356)
@@ -331,7 +331,8 @@
     if (strncmp(pszVersion, "0.0.14", 6) != 0 &&
-        strncmp(pszVersion, "1.0.0", 5) != 0 )
+        strncmp(pszVersion, "1.0.0", 5) != 0 &&
+         strncmp(pszVersion, "1.1", 3) != 0)
         msSetError(MS_WFSCONNERR, "MapServer supports only WFS 1.0.0 or 0.0.14 (please verify the version metadata wfs_version).", "msBuildWFSLayerGetURL()");
         return NULL;
@@ -779,6 +780,11 @@
             (psInfo->pszGMLFilename && pszGMLFilename &&
              strcmp(psInfo->pszGMLFilename, pszGMLFilename) == 0) )
+            if (lp->layerinfo == NULL)
+                if (msWFSLayerWhichShapes(lp, psInfo->rect) == MS_FAILURE)
+                  return MS_FAILURE;
             return MS_SUCCESS;  /* Nothing to do... layer is already opened */
         else
@@ -975,8 +981,9 @@
         msProjectRect(&(lp->map->latlon), &(lp->projection), &ext);
         if (!msRectOverlap(&rect, &ext))
-            /* No overlap... nothing to do */
-            return MS_DONE;  /* No overlap. */
+            /* No overlap... nothing to do. If layer was never opened, go open it.*/
+            if (lp->layerinfo)
+              return MS_DONE;  /* No overlap. */
