[mapserver-commits] r10044 - trunk/mapserver
Mon Apr 5 23:53:52 EDT 2010
Author: sdlime
Date: 2010-04-05 23:53:51 -0400 (Mon, 05 Apr 2010)
New Revision: 10044
   trunk/mapserver/mapgd2.c
Added format specific ifdefs for GD2. Added gdImagePtr accessor macro.
Modified: trunk/mapserver/mapgd2.c
--- trunk/mapserver/mapgd2.c	2010-04-01 19:47:55 UTC (rev 10043)
+++ trunk/mapserver/mapgd2.c	2010-04-06 03:53:51 UTC (rev 10044)
@@ -35,6 +35,8 @@
 #include <io.h>
 #endif
+#define MS_IMAGE_GET_GDIMAGEPTR(image) ((gdImagePtr) image->img.plugin)
 void startNewLayerGD(imageObj *img, double opacity) {
@@ -67,8 +69,8 @@
   fprintf(stderr, "in saveImageGD()\n");
-  if(!img || !fp) return NULL;
-  ip = (gdImagePtr) img->img.plugin;
+  if(!img || !fp) return MS_FAILURE;
+  ip = MS_IMAGE_GET_GDIMAGEPTR(img);
   if(strcasecmp("ON", msGetOutputFormatOption(format, "INTERLACE", "ON")) == 0)
     gdImageInterlace(ip, 1);
@@ -76,21 +78,43 @@
   if(format->transparent)
     gdImageColorTransparent(ip, 0);
-  if(strcasecmp(format->driver, "gd2/gif") == 0)
+  if(strcasecmp(format->driver, "gd2/gif") == 0) {
+#ifdef USE_GD_GIF
     gdImageGif(ip, fp);
-  else if(strcasecmp(format->driver, "gd2/png") == 0)
+#else
+    msSetError(MS_MISCERR, "GIF output is not available.", "saveImageGD()");
+    return(MS_FAILURE);
+#endif
+  } else if(strcasecmp(format->driver, "gd2/png") == 0) {
+#ifdef USE_GD_PNG
     gdImagePng(ip, fp);
-  else if(strcasecmp(format->driver, "gd2/jpeg") == 0)
+#else
+    msSetError(MS_MISCERR, "PNG output is not available.", "saveImageGD()");
+#endif
+  } else if(strcasecmp(format->driver, "gd2/jpeg") == 0) {
+#ifdef USE_GD_JPEG
     gdImageJpeg(ip, fp, atoi(msGetOutputFormatOption( format, "QUALITY", "75")));
-  else
-    return MS_FAILURE; /* unsupported format */
+#else
+    msSetError(MS_MISCERR, "JPEG output is not available.", "saveImageGD()");
+#endif
+  } else {
+    msSetError(MS_MISCERR, "Unknown or unsupported format.", "saveImageGD()");
   return MS_SUCCESS;
 void freeImageGD(imageObj *img)
-  if(img->img.plugin) gdImageDestroy((gdImagePtr)img->img.plugin);
+  gdImagePtr ip;
+  if(img) {
+    if(ip) gdImageDestroy(ip);
@@ -290,7 +314,7 @@
   int c;
   if(!img || !p || !stroke) return;
   if(stroke->color.pen == MS_PEN_UNSET) setPen(ip, &stroke->color);
   c = stroke->color.pen;
@@ -303,7 +327,7 @@
   gdImagePtr ip;
   if(!img || !p || !color) return;
   if(color->pen == MS_PEN_UNSET) setPen(ip, color);
   imageFilledPolygon(ip, p, color->pen, 0, 0);
