[mapserver-commits] r10055 - branches/branch-5-6/docs/en/tutorial
Tue Apr 6 14:55:21 EDT 2010
Author: jmckenna
Date: 2010-04-06 14:55:20 -0400 (Tue, 06 Apr 2010)
New Revision: 10055
   branches/branch-5-6/docs/en/tutorial/example1-4-map.txt
   branches/branch-5-6/docs/en/tutorial/example1-4.txt
   branches/branch-5-6/docs/en/tutorial/example1-5-map.txt
   branches/branch-5-6/docs/en/tutorial/example1-5.txt
   branches/branch-5-6/docs/en/tutorial/example1-6-map.txt
   branches/branch-5-6/docs/en/tutorial/example1-7-map.txt
various bad links pointing to gis.umn.edu
Modified: branches/branch-5-6/docs/en/tutorial/example1-4-map.txt
--- branches/branch-5-6/docs/en/tutorial/example1-4-map.txt	2010-04-06 18:47:35 UTC (rev 10054)
+++ branches/branch-5-6/docs/en/tutorial/example1-4-map.txt	2010-04-06 18:55:20 UTC (rev 10055)
@@ -76,7 +76,7 @@
         # MapServer has a very flexible labeling system.  With that flexibility
         # comes complexity, specially when using truetype fonts.  Please read
         # through the LABEL section of the MapServer map file documentation at
-        # http://ms.gis.umn.edu/docs/reference/mapfile for more information.
+        # http://www.mapserver.org/mapfile for more information.
         LABEL
           COLOR 132 31 31
           SHADOWCOLOR 218 218 218
Modified: branches/branch-5-6/docs/en/tutorial/example1-4.txt
--- branches/branch-5-6/docs/en/tutorial/example1-4.txt	2010-04-06 18:47:35 UTC (rev 10054)
+++ branches/branch-5-6/docs/en/tutorial/example1-4.txt	2010-04-06 18:55:20 UTC (rev 10055)
@@ -38,8 +38,8 @@
 **FONTSET**
           Here we specify the full path to our truetype fonts list (or fontset)
           file. This file lists each of the available fonts. See the file
-          itself and the `MapServer font set documentation
-          <http://mapserver.gis.umn.edu/doc/fontset.html>`_ for more info.
+          itself and the :ref:`MapServer fontset documentation
+          <fontset>` for more info.
           FONTSET is a parameter of the MAP object.
 **LABELITEM**
Modified: branches/branch-5-6/docs/en/tutorial/example1-5-map.txt
--- branches/branch-5-6/docs/en/tutorial/example1-5-map.txt	2010-04-06 18:47:35 UTC (rev 10054)
+++ branches/branch-5-6/docs/en/tutorial/example1-5-map.txt	2010-04-06 18:55:20 UTC (rev 10055)
@@ -142,7 +142,7 @@
 	      LABEL
 	        COLOR 132 31 31
Modified: branches/branch-5-6/docs/en/tutorial/example1-5.txt
--- branches/branch-5-6/docs/en/tutorial/example1-5.txt	2010-04-06 18:47:35 UTC (rev 10054)
+++ branches/branch-5-6/docs/en/tutorial/example1-5.txt	2010-04-06 18:55:20 UTC (rev 10055)
@@ -104,7 +104,7 @@
 **PROCESSING "BANDS=1,2,3"**
   This LAYER object parameter was added in MapServer 4.x. The
-  :ref:<PROCESSING> keyword has many values but in this case we are using it to
+  :ref:`PROCESSING <layer>` keyword has many values but in this case we are using it to
   select which bands in a multispectral image to display. The values here are
   strings that will be passed to the GDAL library.
Modified: branches/branch-5-6/docs/en/tutorial/example1-6-map.txt
--- branches/branch-5-6/docs/en/tutorial/example1-6-map.txt	2010-04-06 18:47:35 UTC (rev 10054)
+++ branches/branch-5-6/docs/en/tutorial/example1-6-map.txt	2010-04-06 18:55:20 UTC (rev 10055)
@@ -183,7 +183,7 @@
 	      LABEL
 	        COLOR 132 31 31
Modified: branches/branch-5-6/docs/en/tutorial/example1-7-map.txt
--- branches/branch-5-6/docs/en/tutorial/example1-7-map.txt	2010-04-06 18:47:35 UTC (rev 10054)
+++ branches/branch-5-6/docs/en/tutorial/example1-7-map.txt	2010-04-06 18:55:20 UTC (rev 10055)
@@ -243,7 +243,7 @@
 	      LABEL
 	        COLOR 132 31 31
