[mapserver-commits] r10075 - trunk/mapserver
Wed Apr 7 17:21:29 EDT 2010
Author: warmerdam
Date: 2010-04-07 17:21:27 -0400 (Wed, 07 Apr 2010)
New Revision: 10075
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdrawgdal.c
   trunk/mapserver/mapraster.c
   trunk/mapserver/maprasterquery.c
   trunk/mapserver/mapserver.h
improve support for [red/green/blue] classification in raster query (#1021)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-04-07 21:05:03 UTC (rev 10074)
+++ trunk/mapserver/HISTORY.TXT	2010-04-07 21:21:27 UTC (rev 10075)
@@ -14,6 +14,9 @@
 Current Version (SVN trunk):
+- Improve support for [red/green/blue] classification expressions for
+  raster query (#1021)
 - Fixed imageObj->saveImage() sends unnecessary headers (#3418)
 - Avoid automatically regenerating maplexer.c (#2310)
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c	2010-04-07 21:05:03 UTC (rev 10074)
+++ trunk/mapserver/mapdrawgdal.c	2010-04-07 21:21:27 UTC (rev 10075)
@@ -2515,7 +2515,7 @@
         dfOriginalValue = (i+0.5) / dfScaleRatio + dfScaleMin;
-        c = msGetClass_Float(layer, (float) dfOriginalValue);
+        c = msGetClass_FloatRGB(layer, (float) dfOriginalValue, -1, -1, -1);
         if( c != -1 )
             int s;
Modified: trunk/mapserver/mapraster.c
--- trunk/mapserver/mapraster.c	2010-04-07 21:05:03 UTC (rev 10074)
+++ trunk/mapserver/mapraster.c	2010-04-07 21:21:27 UTC (rev 10075)
@@ -129,13 +129,14 @@
-/*                          msGetClass_Float()                          */
+/*                          msGetClass_FloatRGB()                       */
 /*      Returns the class based on classification of a floating         */
 /*      pixel value.                                                    */
-int msGetClass_Float(layerObj *layer, float fValue)
+int msGetClass_FloatRGB(layerObj *layer, float fValue,
+                        int red, int green, int blue )
     int i;
     char *tmpstr1=NULL;
@@ -171,6 +172,16 @@
           case(MS_EXPRESSION):
             tmpstr1 = strdup(layer->class[i]->expression.string);
+            if( red != -1 && green != -1 && blue != -1 )
+                sprintf(tmpstr2, "%d", red);
+                tmpstr1 = msReplaceSubstring(tmpstr1, "[red]", tmpstr2);
+                sprintf(tmpstr2, "%d", green);
+                tmpstr1 = msReplaceSubstring(tmpstr1, "[green]", tmpstr2);
+                sprintf(tmpstr2, "%d", blue);
+                tmpstr1 = msReplaceSubstring(tmpstr1, "[blue]", tmpstr2);
             sprintf(tmpstr2, "%18g", fValue);
             tmpstr1 = msReplaceSubstring(tmpstr1, "[pixel]", tmpstr2);
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c	2010-04-07 21:05:03 UTC (rev 10074)
+++ trunk/mapserver/maprasterquery.c	2010-04-07 21:21:27 UTC (rev 10075)
@@ -301,39 +301,9 @@
-/*      Handle classification.                                          */
-/*      NOTE: The following is really quite inadequate to deal with     */
-/*      classifications based on [red], [green] and [blue] as           */
-/*      described in:                                                   */
-/*       http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1021         */
-    if( rlinfo->qc_class != NULL )
-        p_class = msGetClass_Float(layer, values[0] );
-        if( p_class == -1 )
-            nodata = TRUE;
-        else
-            rlinfo->qc_class[rlinfo->query_results] = p_class;
-            if( layer->class[p_class]->numstyles > 0 )
-                red   = layer->class[p_class]->styles[0]->color.red;
-                green = layer->class[p_class]->styles[0]->color.green;
-                blue  = layer->class[p_class]->styles[0]->color.blue;
-            else
-                red = green = blue = 0;
 /*      Handle colormap                                                 */
-    else if( rlinfo->hCT != NULL )
+    if( rlinfo->hCT != NULL )
         int pct_index = (int) floor(values[0]);
         GDALColorEntry sEntry;
@@ -369,6 +339,38 @@
+/*      Handle classification.                                          */
+/*      NOTE: The following is really quite inadequate to deal with     */
+/*      classifications based on [red], [green] and [blue] as           */
+/*      described in:                                                   */
+/*       http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1021         */
+    if( rlinfo->qc_class != NULL )
+        p_class = msGetClass_FloatRGB(layer, values[0],
+                                      red, green, blue );
+        if( p_class == -1 )
+            nodata = TRUE;
+        else
+            nodata = FALSE;
+            rlinfo->qc_class[rlinfo->query_results] = p_class;
+            if( layer->class[p_class]->numstyles > 0 )
+                red   = layer->class[p_class]->styles[0]->color.red;
+                green = layer->class[p_class]->styles[0]->color.green;
+                blue  = layer->class[p_class]->styles[0]->color.blue;
+            else
+                red = green = blue = 0;
 /*      Record the color.                                               */
     rlinfo->qc_red[rlinfo->query_results] = red;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-04-07 21:05:03 UTC (rev 10074)
+++ trunk/mapserver/mapserver.h	2010-04-07 21:21:27 UTC (rev 10075)
@@ -2176,7 +2176,8 @@
 MS_DLL_EXPORT int msAddColorAGG(mapObj *map, gdImagePtr img, int cmt, int r, int g, int b);
 #endif
 MS_DLL_EXPORT int msGetClass(layerObj *layer, colorObj *color);
-MS_DLL_EXPORT int msGetClass_Float(layerObj *layer, float fValue);
+MS_DLL_EXPORT int msGetClass_FloatRGB(layerObj *layer, float fValue,
+                                      int red, int green, int blue );
 /* in mapdrawgdal.c */
 MS_DLL_EXPORT int msDrawRasterLayerGDAL(mapObj *map, layerObj *layer, imageObj *image, rasterBufferObj *rb, void *hDSVoid );
