[mapserver-commits] r10099 - trunk/mapserver
Mon Apr 12 20:00:32 EDT 2010
Author: warmerdam
Date: 2010-04-12 20:00:31 -0400 (Mon, 12 Apr 2010)
New Revision: 10099
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapgdal.c
   trunk/mapserver/maputil.c
   trunk/mapserver/mapwcs.c
   trunk/mapserver/mapwcs11.c
implement wcs_rangeset_nullvalue and NULLVALUE formatoption support (#1709, #655)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-04-12 23:58:05 UTC (rev 10098)
+++ trunk/mapserver/HISTORY.TXT	2010-04-13 00:00:31 UTC (rev 10099)
@@ -14,6 +14,12 @@
 Current Version (SVN trunk):
+- Implement support for raw imagemodes to use NULLVALUE formatoption to set
+  the background value of result images, and to try and mark nodata (#1709)
+- Implement support for wcs_rangeset_nullvalue to set NULLVALUE and
+  return null value definition in describe coverage result (#655)
 - Try to avoid exhausting the color table when rendering 24bit key
   images into 8bit results (#1594)
Modified: trunk/mapserver/mapgdal.c
--- trunk/mapserver/mapgdal.c	2010-04-12 23:58:05 UTC (rev 10098)
+++ trunk/mapserver/mapgdal.c	2010-04-13 00:00:31 UTC (rev 10099)
@@ -398,6 +398,22 @@
+/*      Possibly assign a nodata value.                                 */
+    if( msGetOutputFormatOption(format,"NULLVALUE",NULL) != NULL )
+        int iBand;
+        const char *nullvalue = msGetOutputFormatOption(format,
+                                                        "NULLVALUE",NULL);
+        for( iBand = 0; iBand < nBands; iBand++ )
+            GDALRasterBandH hBand = GDALGetRasterBand( hMemDS, iBand+1 );
+            GDALSetRasterNoDataValue( hBand, atof(nullvalue) );
 /*  Try to save resolution in the output file.                          */
     if( image->resolution > 0 )
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2010-04-12 23:58:05 UTC (rev 10098)
+++ trunk/mapserver/maputil.c	2010-04-13 00:00:31 UTC (rev 10099)
@@ -1468,7 +1468,36 @@
             image->imagepath = strdup(imagepath);
         if (imageurl)
             image->imageurl = strdup(imageurl);
+        /* initialize to requested nullvalue if there is one */
+        if( msGetOutputFormatOption(image->format,"NULLVALUE",NULL) != NULL )
+            int i = image->width * image->height * format->bands;
+            const char *nullvalue = msGetOutputFormatOption(image->format,
+            if( atof(nullvalue) == 0.0 )
+                /* nothing to do */;
+            else if( format->imagemode == MS_IMAGEMODE_INT16 )
+                short nv = atoi(nullvalue);
+                for( ; i > 0; )
+                    image->img.raw_16bit[--i] = nv;
+            else if( format->imagemode == MS_IMAGEMODE_FLOAT32 )
+                float nv = atoi(nullvalue);
+                for( ; i > 0; )
+                    image->img.raw_float[--i] = nv;
+            else if( format->imagemode == MS_IMAGEMODE_BYTE )
+                unsigned char nv = (unsigned char) atoi(nullvalue);
+                memset( image->img.raw_byte, nv, i );
         return image;
     else if( MS_RENDERER_IMAGEMAP(format) )
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2010-04-12 23:58:05 UTC (rev 10098)
+++ trunk/mapserver/mapwcs.c	2010-04-13 00:00:31 UTC (rev 10099)
@@ -940,8 +940,6 @@
   msIO_printf("            </values>\n");
-  /* TODO: add NullValues (optional) */
   msIO_printf("          </AxisDescription>\n");
   msIO_printf("        </axisDescription>\n");
@@ -1078,6 +1076,12 @@
        msFreeCharArray(tokens, numtokens);
+  if((value = msOWSLookupMetadata(&(layer->metadata), "COM", "rangeset_nullvalue")) != NULL) {
+     msIO_printf("        <nullValues>\n");
+     msIO_printf("          <singleValue>%s</singleValue>\n", value);
+     msIO_printf("        </nullValues>\n");
   msIO_printf("      </RangeSet>\n");
   msIO_printf("    </rangeSet>\n");
@@ -1722,7 +1726,12 @@
     for(i = 1; i < cm.bandcount; i++)
       sprintf(bandlist+strlen(bandlist),",%d", i+1);
+  /* apply nullvalue to the output format object if we have it */
+  if((value = msOWSLookupMetadata(&(lp->metadata), "COM", "rangeset_nullvalue")) != NULL) {
+      msSetOutputFormatOption( map->outputformat, "NULLVALUE", value );
   msLayerSetProcessingKey(lp, "BANDS", bandlist);
   sprintf(numbands, "%d", msCountChars(bandlist, ',')+1);
   msSetOutputFormatOption(map->outputformat, "BAND_COUNT", numbands);
Modified: trunk/mapserver/mapwcs11.c
--- trunk/mapserver/mapwcs11.c	2010-04-12 23:58:05 UTC (rev 10098)
+++ trunk/mapserver/mapwcs11.c	2010-04-13 00:00:31 UTC (rev 10099)
@@ -764,7 +764,15 @@
             xmlNewChild(
                 xmlNewChild( psField, NULL, BAD_CAST "Definition", NULL ),
                 psOwsNs, BAD_CAST "AnyValue", NULL );
+        /* NullValue */
+        value = msOWSGetEncodeMetadata( &(layer->metadata), "COM",
+                                        "rangeset_nullvalue", NULL);
+        if( value )
+            xmlNewChild( psField, NULL, BAD_CAST "NullValue",
+                         BAD_CAST value );
+        /* InterpolationMethods */
         psInterpMethods =
             xmlNewChild( psField, NULL, BAD_CAST "InterpolationMethods", NULL );
@@ -772,7 +780,6 @@
         xmlNewChild( psInterpMethods, NULL,
                      BAD_CAST "Default", BAD_CAST "nearest neighbor" );
 /*      Bands axis.                                                     */
