[mapserver-commits] r10102 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Apr 13 10:08:12 EDT 2010
Author: assefa
Date: 2010-04-13 10:08:11 -0400 (Tue, 13 Apr 2010)
New Revision: 10102
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapogcfilter.c
OGC Filters for spatial dbs should be enclosed in parentheses (#3430)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2010-04-13 02:59:44 UTC (rev 10101)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2010-04-13 14:08:11 UTC (rev 10102)
@@ -15,6 +15,8 @@
Version 5.6.4 (????-??-??):
+- OGC Filters for spatial dbs should be enclosed in parentheses (#3430)
- Improve the handling of simple string comparisons for raster classified
values (#3425)
Modified: branches/branch-5-6/mapserver/mapogcfilter.c
--- branches/branch-5-6/mapserver/mapogcfilter.c 2010-04-13 02:59:44 UTC (rev 10101)
+++ branches/branch-5-6/mapserver/mapogcfilter.c 2010-04-13 14:08:11 UTC (rev 10102)
@@ -975,6 +975,7 @@
int bConcatWhere = 0;
int bHasAWhere =0;
char *pszFilterItem=NULL;
+ char *pszTmp = NULL;
lp = (GET_LAYER(map, iLayerIndex));
@@ -1044,7 +1045,17 @@
bHasAWhere = 0;
if (lp->connectiontype == MS_POSTGIS || lp->connectiontype == MS_ORACLESPATIAL ||
lp->connectiontype == MS_SDE || lp->connectiontype == MS_PLUGIN)
- szExpression = FLTGetSQLExpression(psNode, lp);
+ szExpression = FLTGetSQLExpression(psNode, lp);
+ if (szExpression)
+ pszTmp = strdup("(");
+ pszTmp = msStringConcatenate(pszTmp, szExpression);
+ pszTmp = msStringConcatenate(pszTmp, ")");
+ msFree(szExpression);
+ szExpression = pszTmp;
/* concatenates the WHERE clause for OGR layers. This only applies if
the expression was empty or not of an expression string. If there
is an sql type expression, it is assumed to have the WHERE clause.
More information about the mapserver-commits
