[mapserver-commits] r10445 - trunk/msautotest/wxs
Fri Aug 6 08:44:12 EDT 2010
Author: assefa
Date: 2010-08-06 12:44:12 +0000 (Fri, 06 Aug 2010)
New Revision: 10445
   trunk/msautotest/wxs/wfs_simple.map
add test for geometry name passed using the WFS propertyname parameter #3506
Modified: trunk/msautotest/wxs/wfs_simple.map
--- trunk/msautotest/wxs/wfs_simple.map	2010-08-06 12:43:39 UTC (rev 10444)
+++ trunk/msautotest/wxs/wfs_simple.map	2010-08-06 12:44:12 UTC (rev 10445)
@@ -29,6 +29,9 @@
 # Generate layer info using property name.
 # RUN_PARMS: wfs_get_feature_propertyname.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=province&propertyname=(name_e)" > [RESULT]
+# Generate layer info using property name and a geoemtry property.
+# RUN_PARMS: wfs_get_feature_propertyname_geometry.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=province&propertyname=(name_e,msGeometry)" > [RESULT]
 # Get Feature by id
 # RUN_PARMS: wfs_get_feature_id.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=province&featureid=province.Quebec" > [RESULT]
