[mapserver-commits] r10448 - branches/branch-5-6/docs/en/mapfile
Tue Aug 10 16:10:47 EDT 2010
Author: jmckenna
Date: 2010-08-10 20:10:47 +0000 (Tue, 10 Aug 2010)
New Revision: 10448
Added:
   branches/branch-5-6/docs/en/mapfile/labelencoding.txt
   branches/branch-5-6/docs/en/mapfile/index.txt
add label encoding document (for international character support)
Modified: branches/branch-5-6/docs/en/mapfile/index.txt
--- branches/branch-5-6/docs/en/mapfile/index.txt	2010-08-08 05:06:39 UTC (rev 10447)
+++ branches/branch-5-6/docs/en/mapfile/index.txt	2010-08-10 20:10:47 UTC (rev 10448)
@@ -37,6 +37,7 @@
    grid
    join
    label
+   labelencoding
    layer
    legend
    map
Added: branches/branch-5-6/docs/en/mapfile/labelencoding.txt
--- branches/branch-5-6/docs/en/mapfile/labelencoding.txt	                        (rev 0)
+++ branches/branch-5-6/docs/en/mapfile/labelencoding.txt	2010-08-10 20:10:47 UTC (rev 10448)
@@ -0,0 +1,188 @@
+.. _debugging:
+ Display of International Characters in MapServer
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
+:Last Updated: 2010-08-10
+.. contents:: Table of Contents
+    :depth: 3
+    :backlinks: top
+Credit
+The following functionality was added to MapServer 4.4.0 as a part of a project sponsored by the
+Information-technology Promotion Agency (IPA), in Japan.  Project members included: Venkatesh Raghavan,
+Masumoto Shinji, Nonogaki Susumu, Nemoto Tatsuya, Hirai Naoki (Osaka City University, Japan),
+Mario Basa, Hagiwara Akira, Niwa Makoto, Mori Toru (Orkney Inc., Japan), and Hattori Norihiro
+(E-Solution Service, Inc., Japan).
+Related Links
+- MapServer `ticket:858 <http://trac.osgeo.org/mapserver/ticket/858/>`__
+Requirements
+- MapServer >= 4.4.0
+- MapServer compiled with the libiconv library
+How to Enable in Your Mapfile
+The mapfile :ref:`LABEL <label>` object's parameter named *ENCODING* can be used to convert strings from its original
+encoding system into one that can be understood by the True Type Fonts.
+The *ENCODING* parameter accepts the encoding name as its parameter.
+This uses GNU's libiconv ( http://www.gnu.org/software/libiconv/ ) so theoretically, every string
+with an encoding system supported by libiconv can be displayed as labels in MapServer as long as
+it has a matching font-set.
+Step 1: Verify ICONV Support and MapServer Version
+Execute ''mapserv -v' at the commandline, and verify that your MapServer version >= 4.4.0 and it includes ''SUPPORTS=ICONV'', such as:
+   > mapserv -v
+     MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG
+     SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
+     SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
+     SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG SUPPORTS=TILECACHE INPUT=JPEG
+     INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
+Step 2: Verify That Your Files' Encoding is Supported by ICONV
+Since MapServer uses the libiconv library to handle encodings, you can check the list of supported encodings
+here: http://www.gnu.org/software/libiconv/
+Unix users can also use the *iconv -l* command on a system with
+libiconv installed to get the complete list of supported encodings on
+that specific system.
+Step 3: Add ENCODING Parameter to your LABEL Object
+Now you can simply add the ENCODING parameter to your mapfile LAYER object, such as:
+.. code-block:: mapfile
+   MAP
+    LAYER
+      CLASS
+        LABEL
+          ENCODING "SHIFT_JIS"
+        END
+      END
+    END
+   END
+One of the benefits of having an "ENCODING" parameter within the LABEL object is that different LAYERS with different encoding systems can be combined together and display labels within a single map.  For example, labels from a Layer using Shapefile as it source which contains attributes in SHIFT-JIS can be combined with a Layer from a PostGIS database server with EUC-JP attributes.
+A sample Mapfile can look like this:
+   LAYER
+     NAME "chimei"
+     DATA chimei
+     STATUS DEFAULT
+     TYPE POINT
+     LABELITEM "NAMAE"
+     CLASS
+       NAME "CHIMEI"
+       STYLE
+         COLOR 10 100 100
+       END
+       LABEL
+         TYPE TRUETYPE
+         FONT kochi-gothic
+         COLOR 220 20 20
+         SIZE 10
+         POSITION CL
+         PARTIALS FALSE
+         BUFFER 0
+         ENCODING SJIS
+       END
+     END
+   END
+   LAYER
+     NAME "chimeipg"
+     CONNECTION "user=username password=password dbname=gis host=localhost port=5432"
+     CONNECTIONTYPE postgis
+     DATA "the_geom from chimei"
+     STATUS DEFAULT
+     TYPE POINT
+     LABELITEM "NAMAE"
+     CLASS
+       NAME "CHIMEI PG"
+       STYLE
+         COLOR 10 100 100
+       END
+       LABEL
+         TYPE TRUETYPE
+         FONT kochi-mincho
+         COLOR 20 220 20
+         SIZE 10
+         POSITION CL
+         PARTIALS FALSE
+         BUFFER 0
+         ENCODING EUC-JP
+       END
+     END
+   END
+Step 4: Test with the shp2img utility
+- see :ref:`shp2img commandline utility <shp2img>`
+Example Using PHP MapScript
+For PHP Mapscript, the *Encoding* parameter is included in the LabelObj Class, so that the
+encoding parameter of a layer can be modified such as:
+    // Loading the php_mapscript library
+    dl("php_mapscript.so");
+    // Loading the map file
+    $map = ms_newMapObj("example.map");
+    // get the desired layer
+    $layer = $map->getLayerByName("chimei");
+    // get the layer's class object
+    $class = $layer->getClass(0);
+    // get the class object's label object
+    $clabel= $class->label;
+    // get encoding parameter
+    $encode_str = $clabel->encoding;
+    print "Encoding = ".$encode_str."\n";
+    // set encoding parameter
+    $clabel->set("encoding","UTF-8");
+Notes
+During initial implementation, this was was tested using the different Japanese encoding systems:
+Shift-JIS, EUC-JP, UTF-8, as well as Thai's TIS-620 encoding system.
\ No newline at end of file
