[mapserver-commits] r10451 - trunk/docs/en/mapfile
Tue Aug 10 16:23:37 EDT 2010
Author: jmckenna
Date: 2010-08-10 20:23:36 +0000 (Tue, 10 Aug 2010)
New Revision: 10451
   trunk/docs/en/mapfile/label.txt
   trunk/docs/en/mapfile/labelencoding.txt
more changes related to label encoding
Modified: trunk/docs/en/mapfile/label.txt
--- trunk/docs/en/mapfile/label.txt	2010-08-10 20:21:53 UTC (rev 10450)
+++ trunk/docs/en/mapfile/label.txt	2010-08-10 20:23:36 UTC (rev 10451)
@@ -87,8 +87,7 @@
     the system, but if not the label will not be drawn.
     Required for displaying international characters in MapServer. More
-    information can be found at:
-    http://www.foss4g.org/FOSS4G/MAPSERVER/mpsnf-i18n-en.html.
+    information can be found in the :ref:`Label Encoding document <labelencoding>`.
 FONT [name|attribute]
     - Font alias (as defined in the FONTSET) to use for labeling.
Modified: trunk/docs/en/mapfile/labelencoding.txt
--- trunk/docs/en/mapfile/labelencoding.txt	2010-08-10 20:21:53 UTC (rev 10450)
+++ trunk/docs/en/mapfile/labelencoding.txt	2010-08-10 20:23:36 UTC (rev 10451)
@@ -1,4 +1,4 @@
-.. _debugging:
+.. _labelencoding:
  Display of International Characters in MapServer
@@ -184,5 +184,5 @@
 Notes
-During initial implementation, this was was tested using the different Japanese encoding systems:
+During initial implementation, this functionality was was tested using the different Japanese encoding systems:
 Shift-JIS, EUC-JP, UTF-8, as well as Thai's TIS-620 encoding system.
\ No newline at end of file
