[mapserver-commits] r10466 - sandbox/sdlime/common-expressions/mapserver
Mon Aug 23 23:03:18 EDT 2010
Author: sdlime
Date: 2010-08-24 03:03:18 +0000 (Tue, 24 Aug 2010)
New Revision: 10466
   sandbox/sdlime/common-expressions/mapserver/maplayer.c
   sandbox/sdlime/common-expressions/mapserver/mapserver.h
   sandbox/sdlime/common-expressions/mapserver/mapshape.c
Added msLayerSupportsCommonExpressions() vtable function.
Modified: sandbox/sdlime/common-expressions/mapserver/maplayer.c
--- sandbox/sdlime/common-expressions/mapserver/maplayer.c	2010-08-24 02:44:31 UTC (rev 10465)
+++ sandbox/sdlime/common-expressions/mapserver/maplayer.c	2010-08-24 03:03:18 UTC (rev 10466)
@@ -1083,9 +1083,13 @@
 int LayerDefaultAutoProjection(layerObj *layer, projectionObj* projection)
+  msSetError(MS_MISCERR, "This data driver does not implement AUTO projection support", "LayerDefaultAutoProjection()");
+  return MS_FAILURE;
-    msSetError(MS_MISCERR, "This data driver does not implement AUTO projection support", "LayerDefaultAutoProjection()");
-    return MS_FAILURE;
+int LayerDefaultSupportsCommonExpressions(layerObj *layer)
+  return MS_FALSE;
@@ -1122,6 +1126,7 @@
   assert(vtable != NULL);
+  vtable->LayerSupportsCommonExpressions = LayerDefaultSupportsCommonExpressions;
   vtable->LayerInitItemInfo = LayerDefaultInitItemInfo;
   vtable->LayerFreeItemInfo = LayerDefaultFreeItemInfo;
   vtable->LayerOpen = LayerDefaultOpen;
Modified: sandbox/sdlime/common-expressions/mapserver/mapserver.h
--- sandbox/sdlime/common-expressions/mapserver/mapserver.h	2010-08-24 02:44:31 UTC (rev 10465)
+++ sandbox/sdlime/common-expressions/mapserver/mapserver.h	2010-08-24 03:03:18 UTC (rev 10466)
@@ -1577,35 +1577,25 @@
 #ifndef SWIG
 struct layerVTable {
-    int (*LayerInitItemInfo)(layerObj *layer);
-    void (*LayerFreeItemInfo)(layerObj *layer);
-    int (*LayerOpen)(layerObj *layer);
-    int (*LayerIsOpen)(layerObj *layer);
-    int (*LayerWhichShapes)(layerObj *layer, rectObj rect);
-    int (*LayerNextShape)(layerObj *layer, shapeObj *shape);
-    int (*LayerResultsGetShape)(layerObj *layer, shapeObj *shape,
-                         int tile, long record);
-    int (*LayerGetShape)(layerObj *layer, shapeObj *shape,
-    int (*LayerClose)(layerObj *layer);
-    int (*LayerGetItems)(layerObj *layer);
-    int (*LayerGetExtent)(layerObj *layer, rectObj *extent);
-    int (*LayerGetAutoStyle)(mapObj *map, layerObj *layer, classObj *c,
-    int (*LayerCloseConnection)(layerObj *layer);
-    int (*LayerSetTimeFilter)(layerObj *layer,
-                              const char *timestring,
-                              const char *timefield);
-    int (*LayerApplyFilterToLayer)(FilterEncodingNode *psNode, mapObj *map,
-                                   int iLayerIndex,
-                                   int bOnlySpatialFilter);
-    int (*LayerCreateItems)(layerObj *layer, int nt);
-    int (*LayerGetNumFeatures)(layerObj *layer);
-    int (*LayerGetAutoProjection)(layerObj *layer, projectionObj *projection);
+  int (*LayerSupportsCommonExpressions)(layerObj *layer);
+  int (*LayerInitItemInfo)(layerObj *layer);
+  void (*LayerFreeItemInfo)(layerObj *layer);
+  int (*LayerOpen)(layerObj *layer);
+  int (*LayerIsOpen)(layerObj *layer);
+  int (*LayerWhichShapes)(layerObj *layer, rectObj rect);
+  int (*LayerNextShape)(layerObj *layer, shapeObj *shape);
+  int (*LayerResultsGetShape)(layerObj *layer, shapeObj *shape, int tile, long record);
+  int (*LayerGetShape)(layerObj *layer, shapeObj *shape, int tile, long record);
+  int (*LayerClose)(layerObj *layer);
+  int (*LayerGetItems)(layerObj *layer);
+  int (*LayerGetExtent)(layerObj *layer, rectObj *extent);
+  int (*LayerGetAutoStyle)(mapObj *map, layerObj *layer, classObj *c, int tile, long record);
+  int (*LayerCloseConnection)(layerObj *layer);
+  int (*LayerSetTimeFilter)(layerObj *layer, const char *timestring, const char *timefield);
+  int (*LayerApplyFilterToLayer)(FilterEncodingNode *psNode, mapObj *map, int iLayerIndex, int bOnlySpatialFilter);
+  int (*LayerCreateItems)(layerObj *layer, int nt);
+  int (*LayerGetNumFeatures)(layerObj *layer);
+  int (*LayerGetAutoProjection)(layerObj *layer, projectionObj *projection);
 #endif /*SWIG*/
Modified: sandbox/sdlime/common-expressions/mapserver/mapshape.c
--- sandbox/sdlime/common-expressions/mapserver/mapshape.c	2010-08-24 02:44:31 UTC (rev 10465)
+++ sandbox/sdlime/common-expressions/mapserver/mapshape.c	2010-08-24 03:03:18 UTC (rev 10466)
@@ -2585,11 +2585,17 @@
   return MS_SUCCESS;
+int msShapeFileLayerSupportsCommonExpressions(layerObj *layer)
+  return MS_TRUE;
 int msShapeFileLayerInitializeVirtualTable(layerObj *layer)
   assert(layer != NULL);
   assert(layer->vtable != NULL);
+  layer->vtable->LayerSupportsCommonExpressions = msShapeFileLayerSupportsCommonExpressions;
   layer->vtable->LayerInitItemInfo = msShapeFileLayerInitItemInfo;
   layer->vtable->LayerFreeItemInfo = msShapeFileLayerFreeItemInfo;
   layer->vtable->LayerOpen = msShapeFileLayerOpen;
