[mapserver-commits] r10774 - in trunk/docs/en: images input/vector
Wed Dec 1 13:39:49 EST 2010
Author: jmckenna
Date: 2010-12-01 10:39:49 -0800 (Wed, 01 Dec 2010)
New Revision: 10774
Added:
   trunk/docs/en/images/circularstring.png
   trunk/docs/en/images/compoundcurve.png
   trunk/docs/en/images/curvepolygon.png
   trunk/docs/en/images/multicurve.png
   trunk/docs/en/images/multisurface.png
   trunk/docs/en/input/vector/postgis.txt
document upcoming curvepolygon support (ticket#3621)
Added: trunk/docs/en/images/circularstring.png
(Binary files differ)
Property changes on: trunk/docs/en/images/circularstring.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/docs/en/images/compoundcurve.png
Property changes on: trunk/docs/en/images/compoundcurve.png
Added: trunk/docs/en/images/curvepolygon.png
Property changes on: trunk/docs/en/images/curvepolygon.png
Added: trunk/docs/en/images/multicurve.png
Property changes on: trunk/docs/en/images/multicurve.png
Added: trunk/docs/en/images/multisurface.png
Property changes on: trunk/docs/en/images/multisurface.png
Modified: trunk/docs/en/input/vector/postgis.txt
--- trunk/docs/en/input/vector/postgis.txt	2010-12-01 06:26:22 UTC (rev 10773)
+++ trunk/docs/en/input/vector/postgis.txt	2010-12-01 18:39:49 UTC (rev 10774)
@@ -4,10 +4,14 @@
  PostGIS/PostgreSQL
+.. contents:: Table of Contents
+    :depth: 3
+    :backlinks: top
 PostGIS/PostgreSQL
-`PostGIS <http://postgis.refractions.net/>`_ spatially enables the
+`PostGIS <http://postgis.org/>`_ spatially enables the
 Open Source `PostgreSQL`_ database.
 .. _`PostgreSQL`: http://www.postgresql.org/
@@ -140,4 +144,205 @@
     END
   END
-For more info about PostGIS and MapServer see the PostGIS docs: http://postgis.refractions.net/docs/
+For more info about PostGIS and MapServer see the PostGIS docs: http://postgis.org/documentation/
+Support for SQL/MM Curves
+PostGIS is able to store circular interpolated curves, as part of the SQL Multimedia Applications
+Spatial specification (read about the `SQL/MM specification <http://subs.emis.de/LNI/Proceedings/Proceedings26/GI-Proceedings.26-17.pdf>`__).
+For more information about PostGIS' support, see the *SQL-MM Part 3* section in the PostGIS documentation, such
+as `here <http://www.postgis.org/documentation/manual-1.5/ch04.html#SQL_MM_Part3>`__.
+As of MapServer 6.0, the PostGIS features CircularString, CompoundCurve, CurvePolygon, MultiCurve, and MultiSurface can be
+drawn through MapServer directly.
+Example#1: CircularString in MapServer
+The following is the Well Known Text of the feature loading into PostGIS:
+  INSERT INTO test ( g, id ) VALUES ( ST_GeomFromText('CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0)', -1), 2);
+An example MapServer layer might look like:
+  LAYER
+    NAME "curves_poly"
+    STATUS DEFAULT
+    TYPE POLYGON
+    CONNECTIONTYPE postgis
+    CONNECTION "user=postgres password=postgres dbname=curves host=localhost port=5432"
+    DATA "g from test using SRID=-1 using unique id"
+    CLASS
+      STYLE
+        COLOR 128 128 128
+        ANTIALIAS true
+      END
+    END
+  END
+And testing with :ref:`shp2img` should produce a map image of:
+.. image:: ../../images/circularstring.png
+Example#2: CompoundCurve in MapServer
+  INSERT INTO test ( g, id ) VALUES ( ST_GeomFromText('COMPOUNDCURVE(CIRCULARSTRING(0 0, 1 1, 1 0),(1 0, 0 1))', -1), 3);
+  LAYER
+    STATUS DEFAULT
+    TYPE POLYGON
+    CLASS
+      STYLE
+        COLOR 128 128 128
+        ANTIALIAS true
+      END
+    END
+  END
+.. image:: ../../images/compoundcurve.png
+Example#3: CurvePolygon in MapServer
+  INSERT INTO test ( g, id ) VALUES ( ST_GeomFromText('CURVEPOLYGON(CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0),(1 1, 3 3, 3 1, 1 1))', -1), 4);
+  LAYER
+    STATUS DEFAULT
+    TYPE POLYGON
+    CLASS
+      STYLE
+        COLOR 128 128 128
+        ANTIALIAS true
+      END
+    END
+  END
+.. image:: ../../images/curvepolygon.png
+Example#4: MultiCurve in MapServer
+  INSERT INTO test ( g, id ) VALUES ( ST_GeomFromText('MULTICURVE((0 0, 5 5),CIRCULARSTRING(4 0, 4 4, 8 4))', -1), 6);
+  LAYER
+    STATUS DEFAULT
+    TYPE POLYGON
+    CLASS
+      STYLE
+        COLOR 128 128 128
+        ANTIALIAS true
+      END
+    END
+  END
+.. image:: ../../images/multicurve.png
+Example#5: MultiSurface in MapServer
+  INSERT INTO test ( g, id ) VALUES ( ST_GeomFromText('MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0),(1 1, 3 3, 3 1, 1 1)),((10 10, 14 12, 11 10, 10 10),(11 11, 11.5 11, 11 11.5, 11 11)))', -1), 7);
+  LAYER
+    STATUS DEFAULT
+    TYPE POLYGON
+    CLASS
+      STYLE
+        COLOR 128 128 128
+        ANTIALIAS true
+      END
+    END
+  END
+.. image:: ../../images/multisurface.png
+Using MapServer < 6.0
+If you cannot upgrade to MapServer 6.0, then you can use the PostGIS function *ST_CurveToLine()* in your
+MapServer LAYER to draw the curves (note that this is much slower however):
+  LAYER
+    STATUS DEFAULT
+    TYPE POLYGON
+    DATA "wkb_geometry from (select c.id, ST_CurveToLine(c.g) as wkb_geometry from c) as subquery using unique id using SRID=-1"
+    CLASS
+      STYLE
+        COLOR 128 128 128
+        ANTIALIAS true
+      END
+    END
+  END
\ No newline at end of file
